LPC55S28 UART RX IDLE INTERRUPT
playbear
Junior Contributor I
Hello,NXP!
 I'm using LPC55S28 in my project,and I find that LPC55S28 DO NOT SUPPORT uart rx idle interrupt or Character Time-out Indicator (CTI) like LPC1768???
 for example , if I set 15 to rx fifo trig level , I send only 1 bytes to LPC55S28, how do I know there is 1 byte data in rx fifo?No way to notice/trig user application to know there is 1 byte in rx fifo?What I can do is polling the fifo stat all the time?
Please help me, give me some better ideas?Thank you.
danielholala
Senior Contributor II
With LPC55xx having no support for RX TIMEOUT, you are best of with reading single bytes only. I'm successfully using USART_TransferReceiveNonBlocking() requesting only 1 byte at at time.
%3CLINGO-SUB%20id%3D%22lingo-sub-2294943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S28%20UART%20RX%20IDLE%20INTERRUPT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2294943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2CNXP!%3C%2FP%3E%3CP%3E%26nbsp%3BI'm%20using%20LPC55S28%20in%20my%20project%2Cand%20I%20find%20that%20LPC55S28%20DO%20NOT%20SUPPORT%20uart%20rx%20idle%20interrupt%20or%26nbsp%3BCharacter%20Time-out%20Indicator%20(CTI)%26nbsp%3Blike%20LPC1768%3F%3F%3F%3C%2FP%3E%3CP%3E%26nbsp%3Bfor%20example%20%2C%20if%20I%20set%2015%20to%20rx%20fifo%20trig%20level%20%2C%20I%20send%20only%201%20bytes%20to%20LPC55S28%2C%20how%20do%20I%20know%20there%20is%201%20byte%20data%20in%20rx%20fifo%3FNo%20way%20to%20notice%2Ftrig%20user%20application%20to%20know%20there%20is%201%20byte%20in%20rx%20fifo%3FWhat%20I%20can%20do%20is%20polling%20the%20fifo%20stat%20all%20the%20time%3F%3C%2FP%3E%3CP%3EPlease%20help%20me%2C%20give%20me%20some%20better%20ideas%3FThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2294943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S28%20UART%20RX%20IDLE%20INTERRUPT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWith%20LPC55xx%20having%20no%20support%20for%20%3CSTRONG%3ERX%20TIMEOUT%3C%2FSTRONG%3E%2C%20you%20are%20best%20of%20with%20reading%20single%20bytes%20only.%20I'm%20successfully%20using%26nbsp%3B%3CSPAN%3EUSART_TransferReceiveNonBlocking()%20requesting%20only%201%20byte%20at%20at%20time.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
