LPC55S28 SDK composite_cdc_vcom_cdc_vcom_freertos
mschmid
I'm running the LPC55S28 SDK composite_cdc_vcom_cdc_vcom_freertos  sample code. I'd like to change the naming of the VCOM ports.  It  looks like  the PC  has the following Device friendly Names for the 2 ports,  "USB Serial Device" and "Virtual Com Port"   I am assuming these names come from the SDK sample code, but I can not find where this is defined or setup in the code.
Does someone know where this is or how I can alter the names form the eval board software?
RaRo
Hello @mschmid,
In the example, before the driver is updated you will have the device named after USBDeviceString2 in usb_device_descriptor.c. You could look the device named like the USBDeviceString2 in the readme Step 1., before doing the Update.
Best regards, Raul.
