LPC55S16 ADC b channel configuration
ソリューションへジャンプ
3,722件の閲覧回数
Sukumar_M
Now I'm working on LPC55S16 evk. I couldn't able to configure ADC 8th channel anyone help with me.
3,687件の閲覧回数
Yes, you can!
Alice
5 返答(返信)
3,711件の閲覧回数
Sukumar_M
Hi Alice,
I have some configuration problem on ADC.
How we can configure multiple channels.
i) Is any relation between ADC channel and SWTRIG
 How we can choose the value of ADC0->SWTRIG = ?
ii) Is any relation between TCTRL and SWTRIG
 How we can choose the element and value of  of ADC0->TCTRL[?] = ?
Kindly give the solution to solve the problem
3,700件の閲覧回数
There is a demo about multi channel ADC, you can refer to:
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/ADC-multi-channel-sampling-and-DMA-trans...
After read it, you will know the question you mentioned above.
Alice
3,696件の閲覧回数
Sukumar_M
Thanks for your answer. if I use multiple channels can able  to use single software Trigger.
3,688件の閲覧回数
Yes, you can!
Alice
3,713件の閲覧回数
Hello Sukumar_M,
How about the problem?
You can try to use MCUXpresso config tool for peripheral to config ADC.
Alice
