LPC55S06 RTC status following nRESET event
1,204 次查看
pg8v
I need to use the RTC feature on the LPC55S06, and after reading this previous forum post (https://community.nxp.com/t5/LPC-Microcontrollers/LPC55xx-Power-consumption-when-in-RESET/m-p/100875...) it appears that an external nRESET event causes the RTC to reset. Can anyone clarify whether this means that the RTC time value is wiped entirely, or whether the RTC just halts during the duration of the reset event, and then carries on. Many thanks for any help.
1,184 次查看
PabloAvalos
Hi @pg8v
Thank you so much for reaching us in our community. I would like to apologize for the delay, but we are experimenting a high volume of questions these days. I really appreciate your patience.
Regarding your question, the RTC time value is not wiped entirely for LPC55S06. I just checked the UM, and I found this:
Hope this could help, please let me know if you have more questions.
Best Regards.
Pablo Avalos.
PD: A suggestion is to check firstly User Manual and Datasheet for the specific part number that you have.
