LPC5528 SWD not working
3,382 次查看
alex__
Hello, community.
I have a board with LPC5528JBD64K and for configuring it I use MCUXpresso IDE. MCU is ok (UART, ADC and other peripherals work), but I cannot flash and debug it using J-link, cuz error "Wrong DM-AP IDCODE detected" appears.
SWD clock is configured in MCUXpresso. Connection between MCU and SWD pins is ok. I tried to pull ISP entry pin to VCC and GND, nothing changes.
It is my first time with LPC, so, maybe, I forget to set some bits or anything else to turn debugging on.
3,374 次查看
Hello alex__,
About the SWD hardware design, you can refer to LPCxpresso55s28 board:
https://www.nxp.com/design/software/development-software/lpcxpresso55s28-development-board:LPC55S28-...
In MCUXpresso IDE, Just click  "Debug" button under Quickstart Panel:
If still can't work, please take a video or take screenshot to show  your steps.
Alice
3,363 次查看
alex__
SWD connected directly to the programmer:
Clock configuration:
And the error code(in SEGGER J-flash, MCUXpresso returnes the same code):
3,333 次查看
Hello alex,
You can have a look at this thread:
https://forum.segger.com/index.php/Thread/4302-SOLVED-Target-Connect-J-Link-Error-Check-connection-a...
And about the J-link debug, recommend you also ask help on Segger support, they know the j-link deep.
https://www.segger.com/
Regard,
Alice
