LPC551x flash by MCU boot utility(via USB-serial download mode) can't work.
3,050件の閲覧回数
StephenYeh
Hi Sir
If we modify the bootloader VID/PID,  and use MCU_boot utility to update the FW will fail.
Does the MCU_boot utility will check the VID/PID by USB?
6 返答(返信)
2,978件の閲覧回数
jay_heng
If you modify the bootloader VID/PID, you need to adjust below args in \NXP-MCUBootUtility\src\targets\LPC55S16\bltargetconfig.py
romUsbVid = '0x1FC9'
romUsbPid = '0x0022'
2,973件の閲覧回数
StephenYeh
Hi Jay
Thank for your support, Grandmaster.
タグ(1)
3,026件の閲覧回数
StephenYeh
Our customer use their EVT board, we provid the method(how to change bootloader VID/PID).
Their platform is LPC5514.
3,025件の閲覧回数
StephenYeh
Add MCU BOOT Utility version.
Does the tool will check the VID/PID?(I know that there are at least 3 types)?
2,993件の閲覧回数
CarlosGarabito
Does the tool will check the VID/PID? yes, it can check it
3,027件の閲覧回数
CarlosGarabito
What board evk are you using? What are the steps you are following? Are you using any SDK examples?
Have a good day
