LPC55 PLU tool
LPC55 PLU tool
1,506 次查看
_Ferrari_
Dear all,
I'm developing a project using LPC55xx processor and I have to use the PLU feature of the processor.
I'm using MCUXpresso IDE v11.6.1 [Build 8255] [2022-10-03] to develope the project and I selected the Peripherals configuration to configure PLU.
I selected the PLU tabs and I copy the link (https://www.nxp.com/mcu-plu-config-tool) suggested by MCUXpresso to download the proper tool.
Unfortunately the requested page (https://www.nxp.com/mcu-plu-config-tool) is not found in your site.
Did you have similar problem ?
How did you fix it ?
Thank you for your help and cooperation
best regards
1,481 次查看
RaRo
Hello @_Ferrari_,
Please follow the next steps to access the PLU Configuration Tool in MCUXpresso IDE:
  1. Download MCUXpresso IDE v11.7.0, this is because PLU Tool in MCUXpresso IDE v11.6.1 is not working properly.
  2. Download the LPC55xx appropriate SDKv2.13.
  3. Create a new project or import an SDK example.
  4. Open ConfigTools -> Peripherals.
  5. Then, in Components section, go to Register initialization.
  1. A new window will open, please select PLU
  1. Now the Peripherals window should look as below:
    Click on the Open Schematic View.
  1. Finally, go ahead and create your schematic.
Best regards, Raul.
