LPC546xx unused ISP pins
1,905 次查看
terence_kong
Hi NXP,
I would like to know if In System Programming is not used, do we need to external pull high those ISP pins (ISP0-ISP2)?
Or we can just leave them floating?
Thanks in advance.
标签 (1)
3 回复数
1,814 次查看
ZhangJennie
terence K
To have your board secure designed, I suggest you set all unused ISP pin as high externally, to have a pull up resistor on those pins.
If you see the demo board schematic, you would find that those ISP pins are floating. As I know some of customers' board can still work normally even those pins are floating. But we also have minority customers meet problem.
So I suggest you have all unused ISP pins set to 1 externally to guarantee the board ISP design function well.
Jun Zhang
1,814 次查看
terence_kong
Thanks Jun
1,814 次查看
ZhangJennie
welcome.
Jun Zhang
