LPC54618J512 GPIO Pin Initial State Issue
11,726 次查看
nithin3200
Hello everyone,
I have a custom PCB mounted with an LPC54618J512 controller. I have initially configured the GPIO pin (PIO4_16) as a digital output with an initial state set to low. This pin is used to switch an N-channel MOSFET.
During the booting period, the GPIO pin should remain low, but I am observing a 250 ms high pulse before it goes to the low state. I need the GPIO state to remain low throughout the booting period. This issue is not specific to any particular GPIO pin; it occurs across all GPIO pins. I am unsure why I am getting this 250 ms high pulse.
For reference, I am attaching the GPIO configuration screenshot. The yellow pulse represents the GPIO (PIO4_16) signals.
Any suggestions to resolve this issue would be greatly appreciated.
Thank you!
11,622 次查看
nithin3200
@xiangjun_rong ,
Thanks for your prompt replay. As per your suggestion I connected the 5K ohm pull down resistor. The noise has been removed, and the issue is solved.
Thank you very much for your guidance.
Nithin
4 回复数
11,705 次查看
xiangjun_rong
As you know that the GPIO pin is in input mode in default after Reset, so the pin is subject to noise.
Pls try to connect a pull-down resistor on the pin and check if the pulse appears or not after reset.
If the pulse still appears after you connect a pull-down resistor, it is a tough issue.
Xiangjun Rong
11,692 次查看
nithin3200
Hi@ xiangjun_rong
Thanks for the reply. We have already connected the pull-down resistor in the hardware. Are there any other issues we should check?
Nithin
11,658 次查看
xiangjun_rong
Pls connect a 5K ohm pull-down resistor on the PIO4_16 pin. If you still see the high pulse during the start-up process, at this time, because the software has not begun to be executed, so software can not solve it. For hardware, the pull-down resistor is the only way I suppose.
As I said it is a tough issue.
XiangJun Rong
11,623 次查看
nithin3200
@xiangjun_rong ,
Nithin
%3CLINGO-SUB%20id%3D%22lingo-sub-1947319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC54618J512%20GPIO%E5%BC%95%E8%84%9A%E5%88%9D%E5%A7%8B%E7%8A%B6%E6%80%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%AE%89%E8%A3%85%E4%BA%86%20LPC54618J512%20%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E5%AE%9A%E5%88%B6%20PCB%E3%80%82%E6%88%91%E5%B7%B2%E5%B0%86%20GPIO%20%E5%BC%95%E8%84%9A%EF%BC%88PIO4_16%EF%BC%89%E5%88%9D%E5%A7%8B%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%95%B0%E5%AD%97%E8%BE%93%E5%87%BA%EF%BC%8C%E5%88%9D%E5%A7%8B%E7%8A%B6%E6%80%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%8E%E3%80%82%E6%AD%A4%E5%BC%95%E8%84%9A%E7%94%A8%E4%BA%8E%E5%88%87%E6%8D%A2%20N%20%E6%B2%9F%E9%81%93%20MOSFET%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%9C%9F%E9%97%B4%EF%BC%8CGPIO%20%E5%BC%95%E8%84%9A%E5%BA%94%E4%BF%9D%E6%8C%81%E4%BD%8E%E7%94%B5%E5%B9%B3%EF%BC%8C%E4%BD%86%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%E5%AE%83%E5%9C%A8%E8%BF%9B%E5%85%A5%E4%BD%8E%E7%94%B5%E5%B9%B3%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%E6%9C%89%E4%B8%80%E4%B8%AA%20250%20%E6%AF%AB%E7%A7%92%E7%9A%84%E9%AB%98%E8%84%89%E5%86%B2%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%20GPIO%20%E7%8A%B6%E6%80%81%E5%9C%A8%E6%95%B4%E4%B8%AA%E5%90%AF%E5%8A%A8%E6%9C%9F%E9%97%B4%E4%BF%9D%E6%8C%81%E4%BD%8E%E7%94%B5%E5%B9%B3%E3%80%82%E8%AF%A5%E9%97%AE%E9%A2%98%E5%B9%B6%E4%B8%8D%E7%89%B9%E5%AE%9A%E4%BA%8E%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E7%9A%84%20GPIO%20%E5%BC%95%E8%84%9A%EF%BC%9B%E5%AE%83%E5%8F%91%E7%94%9F%E5%9C%A8%E6%89%80%E6%9C%89%20GPIO%20%E5%BC%95%E8%84%9A%E4%B8%8A%E3%80%82%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E8%BF%99%E4%B8%AA%20250%20%E6%AF%AB%E7%A7%92%E7%9A%84%E9%AB%98%E8%84%89%E5%86%B2%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%20GPIO%20%E9%85%8D%E7%BD%AE%E6%88%AA%E5%9B%BE%E3%80%82%E9%BB%84%E8%89%B2%E8%84%89%E5%86%B2%E4%BB%A3%E8%A1%A8%20GPIO%EF%BC%88PIO4_16%EF%BC%89%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
