LPC54608 library
LPC54608 library
corboksem
I am looking for LPC54608 board libraries which contains ethernet library.
Labels (3)
Carlos_Mendoza
Hi Cor,
As mentioned on your other thread you can download the SDK for LPC54608. there is a directory under "\middleware\lwip\src\core", there is the LWIP stack which has both TCP and UDP support.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
