LPC54608 and DFU
LPC54608 and DFU
1,780 次查看
giannigrondona
I use an LPC54608 microprocessor and I would like to know if I can program external serial flash memory with DFU utility. My code program stay in serial flash memory.
Best Regards
Giovanni
1,379 次查看
benmao
We wanted to use the LPC54608 but it seems that we cannot use the lpcscrypt software in order to update the firmware, as there will no debug probe be on the final device. It looks that we have to choose a board with LPC43XX instead? Is it planned to update the LPCScrypt in a way the LPC54608 can be used?
1,379 次查看
jeremyzhou
Hi Ernst Murnleitner
As I know, there's no plan for update the LPCScrypt to support the LPC546xxx now.
TIC
1,379 次查看
jeremyzhou
Hi Giovanni Grondona ,
for the opportunity to serve you.
DFU programmer hasn't supported any series of LPC except the LPC43xx and LPC18xx until now.
TIC
