LPC54608 BACKLIGHT PWM
1,815 次查看
enricobe
Hi all,
I'm working on a custom project based on LPC54608 reference eva board.
I've got a question regarding PWM generation over SCT0_OUT5 (PIO3_31) signals: SDK's demo projects init this channel without starting the timer through SCTIMER_StartTimer(), and the IOMUX for that signal is not configured (FUNC2).
Trying to fix this missing points we lead anyway to a fixed '1' level at that pin.
Do you have any hints?
1,706 次查看
enricobe
I've tested another board with IOMUX and SCT timer start and everything is working. I guess the eva board could be damaged at dc/dc converter (to be checked).
1,707 次查看
enricobe
