Hi Alexis, Thanks for your answer. I have checked bios, and there are no options for the remote wake.
This laptop can be waked up by different devices from any USB port, so I assume that remote wakeup is enabled by default.
I have also checked power settings.
I read the readme.pdf and followed every single step, but the problem still appears.
suspend_resume_hid_mouse_bm example works fine with other ports of this laptop, and with other ports of hub.
But it doesn't work in charging ports. Pictures below.
I have tested 7 USB keyboards and mice and they were able to wake host in charging port. The problem appears only with LPC546.
