LPC546 MCANRxFifo assert
2,381件の閲覧回数
Hector_Jimenez
I'm using MCAN module in LPC54616 MCU in a very unstable environment, which causes assertion in MCAN_ReadRxFifo function when receiving null frames (rxFrame = NULL).
fsl_mcan.c
status_t MCAN_ReadRxFifo(CAN_Type *base, uint8_t fifoBlock, mcan_rx_buffer_frame_t *rxFrame)
/* Assertion. */
assert((0U == fifoBlock) || (1U == fifoBlock));
assert(NULL != rxFrame);
leading into MCU continiously stalling.
Is this a real assertion reason or could it be sorted out by skipping that reading?
Perhaps it's already been solved in later versions of SDK, can anyone confirm this? My SDK version is 2.10.
Thank you!
2,308件の閲覧回数
Harry_Zhang
Hi @Hector_Jimenez
Yes, you can add related code.
Or  you can add a new function.
status_t CheckFrame(CAN_Type *base, uint8_t fifoBlock, mcan_rx_buffer_frame_t *rxFrame)
    /* Assertion. */
    if (NULL == rxFrame) {
    	/* Acknowledge the read. */
        if (0U == fifoBlock)
            base->RXF0A = (base->RXF0S & CAN_RXF0S_F0GI_MASK) >> CAN_RXF0S_F0GI_SHIFT;
        else
            base->RXF1A = (base->RXF1S & CAN_RXF1S_F1GI_MASK) >> CAN_RXF1S_F1GI_SHIFT;
        return kStatus_Fail;
    else {
         MCAN_ReadRxFifo(base, fifoBlock, rxFrame);
Harry
4 返答(返信)
2,343件の閲覧回数
Harry_Zhang
Hi @Hector_Jimenez
In the MCAN_ReadRxFifo function,
assert(NULL != rxFrame)  is a necessary condition.
So it could not be sorted out by skipping that reading.
Harry
2,338件の閲覧回数
Hector_Jimenez
Hello @Harry_Zhang.
What if we ack the read and return failure? This return value could be checked when calling to MCAN_ReadRxFifo function and set a different status for CAN bus, like kStatus_MCAN_RxFifo0Lost.
    /* Assertion. */
        else
Kind regards
2,309件の閲覧回数
Harry_Zhang
Hi @Hector_Jimenez
    /* Assertion. */
        else
    else {
Harry
2,280件の閲覧回数
Hector_Jimenez
Hi, @Harry_Zhang .
We are testing the code I posted and it seems to work fine in these unstable conditions. Some frames are lost, but MCU doesn't get stalled.
Thanks for your help.
Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2049106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC546%20MCANRxFifo%20assert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E7%92%B0%E5%A2%83%E3%81%A7LPC54616%20MCU%E3%81%AEMCAN%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%8C%E3%83%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0(rxFrame%20%3D%20NULL)%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%ABMCAN_ReadRxFifo%E9%96%A2%E6%95%B0%E3%81%A7%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Efsl_mcan.c%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%5B...%5D%3C%2FP%3E%3CP%3Estatus_t%20%3CSTRONG%3EMCAN_ReadRxFifo%3C%2FSTRONG%3E(CAN_Type%20*base%2C%20uint8_t%20fifoBlock%2C%20mcan_rx_buffer_frame_t%20*rxFrame)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%E4%B8%BB%E5%BC%B5%E3%80%82*%2F%3CBR%20%2F%3Eassert((0U%20%3D%3D%20fifoBlock)%20%7C%7C(1U%20%3D%3D%20fifoBlock))%3B%3CBR%20%2F%3E%3CSTRONG%3Eassert(NULL%20!%3D%20rxFrame)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%5B...%5D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EMCU%E3%81%8C%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E5%A4%B1%E9%80%9F%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AE%E4%B8%BB%E5%BC%B5%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%9D%E3%81%AE%E8%AA%AD%E3%81%BF%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFSDK%E3%81%AE%E5%BE%8C%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%81%A7%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AESDK%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF2.10%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC546%20MCANRxFifo%20assert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81MCU%E3%81%AF%E5%A4%B1%E9%80%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2051305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC546%20MCANRxFifo%20assert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196227%22%20target%3D%22_blank%22%3E%40Hector_Jimenez%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E9%96%A2%E9%80%A3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E9%96%A2%E6%95%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Estatus_t%20CheckFrame(CAN_Type%20*base%2C%20uint8_t%20fifoBlock%2C%20mcan_rx_buffer_frame_t%20*rxFrame)%0A%7B%0A%20%20%20%20%2F*%20Assertion.%20*%2F%0A%20%20%20%20assert((0U%20%3D%3D%20fifoBlock)%20%7C%7C%20(1U%20%3D%3D%20fifoBlock))%3B%0A%20%20%20%20if%20(NULL%20%3D%3D%20rxFrame)%20%7B%0A%20%20%20%20%09%2F*%20Acknowledge%20the%20read.%20*%2F%0A%20%20%20%20%20%20%20%20if%20(0U%20%3D%3D%20fifoBlock)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20base-%26gt%3BRXF0A%20%3D%20(base-%26gt%3BRXF0S%20%26amp%3B%20CAN_RXF0S_F0GI_MASK)%20%26gt%3B%26gt%3B%20CAN_RXF0S_F0GI_SHIFT%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20base-%26gt%3BRXF1A%20%3D%20(base-%26gt%3BRXF1S%20%26amp%3B%20CAN_RXF1S_F1GI_MASK)%20%26gt%3B%26gt%3B%20CAN_RXF1S_F1GI_SHIFT%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20return%20kStatus_Fail%3B%0A%20%20%20%20%7D%0A%20%20%20%20else%20%7B%0A%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20MCAN_ReadRxFifo(base%2C%20fifoBlock%2C%20rxFrame)%3B%0A%20%20%20%20%0A%7D%0A%5B...%5D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2049713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC546%20MCANRxFifo%20assert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%AE%E5%A4%B1%E6%95%97%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AF%3CSTRONG%3E%3CEM%3E%E3%80%81MCAN_ReadRxFifo%3C%2FEM%3E%3C%2FSTRONG%3E%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%3CFONT%20color%3D%22%230000FF%22%3E%3CEM%3EkStatus_MCAN_RxFifo0Lost%3C%2FEM%3E%3C%2FFONT%3E%E3%81%AA%E3%81%A9%E3%81%AECAN%E3%83%90%E3%82%B9%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Estatus_t%20MCAN_ReadRxFifo(CAN_Type%20*base%2C%20uint8_t%20fifoBlock%2C%20mcan_rx_buffer_frame_t%20*rxFrame)%0A%7B%0A%20%20%20%20%2F*%20Assertion.%20*%2F%0A%20%20%20%20assert((0U%20%3D%3D%20fifoBlock)%20%7C%7C%20(1U%20%3D%3D%20fifoBlock))%3B%0A%20%20%20%20if%20(NULL%20%3D%3D%20rxFrame)%20%7B%0A%20%20%20%20%09%2F*%20Acknowledge%20the%20read.%20*%2F%0A%20%20%20%20%20%20%20%20if%20(0U%20%3D%3D%20fifoBlock)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20base-%26gt%3BRXF0A%20%3D%20(base-%26gt%3BRXF0S%20%26amp%3B%20CAN_RXF0S_F0GI_MASK)%20%26gt%3B%26gt%3B%20CAN_RXF0S_F0GI_SHIFT%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20base-%26gt%3BRXF1A%20%3D%20(base-%26gt%3BRXF1S%20%26amp%3B%20CAN_RXF1S_F1GI_MASK)%20%26gt%3B%26gt%3B%20CAN_RXF1S_F1GI_SHIFT%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20return%20kStatus_Fail%3B%0A%20%20%20%20%7D%0A%5B...%5D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2049706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC546%20MCANRxFifo%20assert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196227%22%20target%3D%22_blank%22%3E%40Hector_Jimenez%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMCAN_ReadRxFifo%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3Eassert(NULL%20!%3D%20rxFrame)%20%E3%81%AF%E5%BF%85%E9%A0%88%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorHarry_Zhang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2025-02-24_16-03-00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2025-02-24_16-03-00.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325308i84E70AD98EBDD98E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2025-02-24_16-03-00.png%22%20alt%3D%22Snipaste_2025-02-24_16-03-00.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESnipaste_2025-02-24_16-03-00.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%3CSPAN%3E%E3%81%9D%E3%81%AE%E8%AA%AD%E3%81%BF%E3%82%92%E9%A3%9B%E3%81%B0%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
