LPC54018 I2s Config
LPC54018 I2s Config
3,932 次查看
Sukumar_M
I'm newly working on I2s I should try to do demo driver flash to evk but it not work how can achieve configration. please any one help me.
7 回复数
3,915 次查看
Sukumar_M
i2s interrupt transfer demo if any other option to use polling method
3,907 次查看
Hello Sukumar_M,
I test the I2S demo on my side, it can works well. So recommend you first do not change anything with demo.
Alice
3,905 次查看
Sukumar_M
ok how to choose frequency divider value as per music. I can choose same frequency divider value multiple music is it possible
3,873 次查看
Hello ,
About I2S sample rate configuration, you can refer to:
UM11060 -> 29.8.3.2 Rate calculations
3,920 次查看
Sukumar_M
already one demo are there in MCUxpresso but it not work only noise are occur no sound data should be transfer.
3,918 次查看
Hello ,
Which demo you used? Have you configure well refer to readme? Do you use DEMO board from NXP?
Alice
标记 (1)
3,926 次查看
Recommend download SDK , there is I2s demo, and there is  readme.txt under project folder about how to use demo:
https://mcuxpresso.nxp.com/en/builder?hw=LPCXpresso54018
Alice
