LPC43XX HSADC DMA how to
3,131 次查看
robberpen
After seup hsadc’s descriptor0, It can sampling data to FIFOOUTPUT register by software trigger.
And set FIFO_LEVEL register to 7. Then it successfully interrupts to ADCHS_IRQHandler().
Based on programming guide, it should also trigger DMA_HSADC_read signal to trigger DMA channel activation.
However, DMA channel 7 never work.(did not copy src:FIFOOUTPUT to dst:Memory)
Is something wrong for DMA setup here? Or how to check/debug this.
PS: DMAMUXER8 already set in this case.
LPC_CREG->DMAMUX = (LPC_CREG->DMAMUX | (0x3 << 16)); //16b(DMAMUXER8) = 0x3
Ref - https://community.nxp.com/t5/LPC-Microcontrollers/DMA-keep-getting-quot-Empty-FIFO-empty-quot-0x8000...
https://community.nxp.com/t5/LPC-Microcontrollers/LPC-Link2-High-Speed-ADC-and-DMA-Interrupt/td-p/15...
  • Setup HSADC is working.
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 0, (HSADC_DESC_CH(1) |
	 HSADC_DESC_BRANCH_NEXT | HSADC_DESC_MATCH(1) |
	 HSADC_DESC_THRESH_NONE | HSADC_DESC_RESET_TIMER ));
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 1, (HSADC_DESC_CH(1) |
	 HSADC_DESC_THRESH_NONE | HSADC_DESC_RESET_TIMER));
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 2, (HSADC_DESC_CH(1) |
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 3, (HSADC_DESC_CH(1) |
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 4, (HSADC_DESC_CH(1) |
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 5, (HSADC_DESC_CH(1) |
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 6, (HSADC_DESC_CH(1) |
	 Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 7, (HSADC_DESC_CH(1) |
	 HSADC_DESC_MATCH(1) | HSADC_DESC_THRESH_NONE |HSADC_DESC_BRANCH_FIRST |
	 HSADC_DESC_RESET_TIMER | HSADC_DESC_HALT |HSADC_DESC_INT));
  • DMA not work
static void App_DMA_Init(void)
	/* Initialize GPDMA controller */
	Chip_GPDMA_Init(LPC_GPDMA);
	/* Setting GPDMA interrupt */
	NVIC_DisableIRQ(DMA_IRQn);
	NVIC_SetPriority(DMA_IRQn, ((0x01 << 3) | 0x01));
	NVIC_EnableIRQ(DMA_IRQn);
void Setup_DMA_J(void) //copy from https://community.nxp.com/t5/LPC-Microcontrollers/DMA-keep-getting-quot-Empty-FIFO-empty-quot-0x8000-from-HSADC/m-p/734753
uint8_t DMA_CH = 7
	App_DMA_Init();
	/* Clear all DMA interrupt and error flag */
	LPC_GPDMA->CONFIG = 0x00;
#if 0 /* PTM duplicated */
	LPC_GPDMA->INTTCCLEAR = 0xFF; //clears channel terminal count interrupt
	LPC_GPDMA->INTERRCLR = 0xFF; //clears channel error interrupt.
#endif
	LPC_GPDMA->CONFIG = 0x01;
	while (!(LPC_GPDMA->CONFIG & 0x01))
	LPC_GPDMA->CH[DMA_CH].SRCADDR = (uint32_t) &LPC_ADCHS->FIFO_OUTPUT[0];
	LPC_GPDMA->CH[DMA_CH].DESTADDR = ((uint32_t) gluData);
	//LPC_GPDMA->CH[DMA_CH].DESTADDR = ((uint32_t) &sample);
	//LPC_GPDMA->CH[DMA_CH].CONTROL = (DMA_TRANSFER_SIZE << 0) // transfer size
	LPC_GPDMA->CH[DMA_CH].CONTROL = (FIFO_OUTPUT_LEVEL << 0)
			| (0x0 << 12) // src burst size
			| (0x0 << 15) // dst burst size
			| (0x2 << 18) // src transfer width
			| (0x2 << 21) // dst transfer width
			| (0x1 << 24) // src AHB master select
			| (0x0 << 25) // dst AHB master select
			| (0x0 << 26) // src increment: 0, src address not increment after each trans
			| (0x1 << 27) // dst increment: 1, dst address increment after each trans
			| (0x1 << 31); // terminal count interrupt enable bit: 1, enabled, (0x0UL << 31); // Terminal count interrupt disabled
	LPC_GPDMA->CH[DMA_CH].CONFIG = (0x1 << 0) // enable bit: 1 enable, 0 disable
	| (HSADC_DMA_READ << 1) // src peripheral: set to 8 - HSADC
			| (0x0 << 6) // dst peripheral: no setting - memory
			| (0x0 << 11) // flow control: peripheral to memory - DMA control
			| (0x1 << 14) // IE - interrupt error mask
			| (0x1 << 15) // ITC - terminal count interrupt mask
			| (0x0 << 16) // lock: when set, this bit enables locked transfer
			| (0x1 << 18); // Halt: 1, enable DMA requests; 0, ignore further src DMA req
	LPC_GPDMA->CH[DMA_CH].LLI = 0;
	NVIC_SetPriority(DMA_IRQn,0x00);
	NVIC_ClearPendingIRQ(DMA_IRQn);
标签 (2)
2,979 次查看
robberpen
Seems 0x06 << 11 is for burst DMA.
I am keep more testing. thanks
	LPC_GPDMA->CH[DMA_CH].CONFIG = (0x1 << 0) // enable bit: 1 enable, 0 ...
	| (0x6 << 11) // flow control: peripheral to memory - DMA control
3,102 次查看
robberpen
I can work hsadc with DMA transfer, but I need more future feature by DMA_read REQ signal.
Here some keys need confirm
Based on  48.7.4.1 DMA read
  • hsadc only support DMA channel 8 for read?
  • My workaround solution is set bit 1 on IRQ handler.
    >LPC_GPDMA->CH[DMA_CH].CONFIG = LPC_GPDMA->CH[DMA_CH].CONFIG |  0x1;
  • But I wand to active DMA by  DMA_read REQ siganl, so I also set DMAMUXER8, But it still not working as I expect that DMA_read signal should be trigger when FIFO_LEVEL or FIFO_FULL occur.
void ADCHS_IRQHandler(void) {
	Chip_HSADC_ClearIntStatus(LPC_ADCHS, 1, Chip_HSADC_GetIntStatus(LPC_ADCHS, 1) & Chip_HSADC_GetEnabledInts(LPC_ADCHS, 1));
	Chip_HSADC_ClearIntStatus(LPC_ADCHS, 0, Chip_HSADC_GetIntStatus(LPC_ADCHS, 0) & Chip_HSADC_GetEnabledInts(LPC_ADCHS, 0));
3,085 次查看
xiangjun_rong
I suppose that you can use the following code and have a try.
#define TICKRATE_HZ1 (1000) /* 10 ticks per second */
#define DGEC 0xE
#define HSADC_DMA_READ 8
#define DMA_CH 7
#define DMA_TRANSFER_SIZE 1024 // max. 4095
#define NUM_SAMPLE DMA_TRANSFER_SIZE
uint32_t descrip0,descrip1,config;
uint32_t freqHSADC;
uint32_t sample[NUM_SAMPLE];
void ADCHS_DMA_init(void)
//uint8_t DGEC = 0xE;
////////////////////////////////// ADCHS采样频率设置///// ///////////////////////////////////////////////////// ///////// /*80M*/
//CLK_M4_ADCHS uses BASE_M4_CLK
Chip_USB0_Init();/*将USB0 PLL初始化为480 MHz */
Chip_Clock_SetDivider(CLK_IDIV_A,CLKIN_USBPLL,2); /*来自USB0PLL的DIV_A源,并将分频器设置为2(支持的最大div值为4)[IN 480 MHz;输出240 MHz */
Chip_Clock_SetDivider(CLK_IDIV_B,CLKIN_IDIVA,3); /*来自DIV_A的源DIV_B,[IN 240 MHz;输出80 MHz */
Chip_Clock_SetBaseClock(CLK_BASE_ADCHS, CLKIN_IDIVB, true, false); /* Source ADHCS base clock from DIV_B */
freqHSADC = Chip_HSADC_GetBaseClockRate(LPC_ADCHS);
Chip_Clock_EnableOpts(CLK_MX_ADCHS, true, true, 1);/*启用寄存器时钟*/
Chip_Clock_Enable(CLK_ADCHS); /*启用时钟*/
////////////////////////////////// HSADC设置///// ///////////////////////////////////////////////////// /////////
/* 中断设置 */
// LPC_ADCHS-> INTS [0] .CLR_EN = 0x7F; //禁用中断0
// LPC_ADCHS-> INTS [0] .CLR_STAT = 0x7F; //清除中断状态
// while(LPC_ADCHS-> INTS [0] .STATUS&0x7D); //等待状态清除,必须排除FIFO_EMPTY
// LPC_ADCHS-> INTS [1] .CLR_EN = 0x7F;
// LPC_ADCHS-> INTS [1] .CLR_STAT = 0x7F;
// while(LPC_ADCHS-> INTS [1] .STATUS&0x1E);
/*初始化HSADC */
Chip_RGU_TriggerReset(RGU_ADCHS_RST);//复位HADC
while (Chip_RGU_InReset(RGU_ADCHS_RST)){}
LPC_ADCHS-> POWER_DOWN = 0; //禁用电源关闭模式
/* FIFO 中断 1, 无 打包模式 */
//Chip_HSADC_SetupFIFO(LPC_ADCHS, 1, false);
LPC_ADCHS-> FIFO_CFG =(8 << 1); /* FIFO_LEVEL大小PACKED_READ 数据保存在FIFO的方式,1表示两个采样数据打包存放 */
LPC_ADCHS-> DSCR_STS = (1 << 1)| 0; //设置活动的描述符表与描述符
/* 设置描述符表0中的描述符0*/
LPC_ADCHS->DESCRIPTOR[0][0] = (1 << 24) /* RESET_TIMER 复位定时器*/
| (0 << 22) /* THRESH 未添加比较器*/
| (0 << /* MATCH 描述符计时器值等于MATC时,转换描述符*/
| (1 << 6) /* BRANCH to First 转换完成后跳转到该表第一个描述符*/;
descrip0 =LPC_ADCHS->DESCRIPTOR[0][0] ;
/* Set descriptor 1 to take a measurement after 0x9A clocks and branch to first descriptor*/
LPC_ADCHS->DESCRIPTOR[0][1] =(1 << 31) /* UPDATE TABLE*/ //最高位配置不上
| (1 << 24) /* RESET_TIMER*/
| (0 << 22) /* THRESH*/
| (0 << /* MATCH*/
| (0x01 << 6) /* BRANCH to first*/;
descrip1 =LPC_ADCHS->DESCRIPTOR[0][1] ;
LPC_ADCHS-> CONFIG =(0x90 << 6)/*恢复时间,建议值*/
| (0 << 5)/* CHANNEL_ID_EN ,0表示不将通道ID输入到FIFO中*/
| (0x01)/* TRIGGER_MASK 01 表示仅使用软件触发*/;
/* CRS设置为0x4,所以SPEED所有DGEC应该被设置为0xE */
LPC_ADCHS-> ADC_SPEED =(DGEC << 20)
| (DGEC << 16)
| (DGEC << 12)
| (DGEC <<
| (DGEC << 4)
| (DGEC);
//未设置阈值寄存器,因为未使用它们
LPC_ADCHS->POWER_CONTROL =(1 << 18)/* BGAP */
|(1 << 17)/*电源 ADC保持供电*/
|(0 << 4) /* DCINNEG在ADC0 No dc bias 当 DCINNEG 设置为 0 时,提供 ADCHS_NEG 引脚上的电压(ADCHS 用于真差分模式):*/
|(0 << 10)/* DC在ADC0中 No dc bias*/
|(0 << 16)/* 1 =以TWOS输出-0 =以Offset Binary输出*/
|(0x4)/* CRS ,设置ADC速度*/;
LPC_ADCHS-> FLUSH = 1; //FIFO刷新
///////////////////////////////////////////////////// //// DMA设置///////////////////////////////////////////// ///////////////////////
LPC_GPDMA-> CH [DMA_CH] .CONFIG |=0; //启用位,1启用,0禁用
LPC_GPDMA->INTTCCLEAR |= ((1UL <<DMA_CH ) & 0xFF);
LPC_GPDMA->INTERRCLR |= ((1UL <<DMA_CH ) & 0xFF);
LPC_GPDMA-> CONFIG = 0x01;
while(!(LPC_GPDMA-> CONFIG&0x01)); //使能
/* 描述符寄存器的值仅能通过DMA通道7传递 */
LPC_GPDMA-> CH[DMA_CH].SRCADDR =(uint32_t)&LPC_ADCHS-> FIFO_OUTPUT [0];//DMA源地址
LPC_GPDMA-> CH[DMA_CH].DESTADDR =((uint32_t)&sample);//DMA目标地址
LPC_GPDMA-> CH[DMA_CH].CONTROL =(DMA_TRANSFER_SIZE)//传输大小 最大4095
| (0x0 << 12)// src突发大小
| (0x0 << 15)// dst突发大小
| (0x2 << 18)// src传输宽度,0x2表示以字的形式传输
| (0x2 << 21)// dst传输宽度,0x2表示以字的形式传输
| (0x1 << 24)// src AHB主选择
| (0x0 << 25)// dst AHB主选择
| (0x0 << 26)// src增量:0,每次传输后src地址不递增
| (0x1 << 27)// dst增量:1,每次传输后的dst地址增量
| (0x1 << 31); //终端计数中断使能位:1,使能
LPC_GPDMA->CH[DMA_CH].CONFIG = (HSADC_DMA_READ << 1)// src外设:设置为8-HSADC
| (0x0 << 6)// dst外设:无设置-内存
| (0x6 << 11)//流控制:外设-存储器
| (0x1 << 14); // IE-中断错误掩码
//| (0x1 << 15);
// ITC-终端计数中断屏蔽
//| (0x1 << 0);// enable bit: 1 enable, 0 disable
//| (0x0 << 16)//锁定:置位时,此位启用锁定传输
//| (0x1 << 18); //进一步忽略src DMA req
LPC_CREG->DMAMUX=3<<16; //select HSADC read for DMAMUXPER8
LPC_GPDMA-> CH [DMA_CH] .LLI = 0;
// NVIC_EnableIRQ(DMA_IRQn);
config =LPC_GPDMA-> CH [DMA_CH] .CONFIG;
LPC_GPDMA-> CH [DMA_CH].CONFIG|=(0x1 << 0);
Chip_HSADC_SWTrigger(LPC_ADCHS);//启动ADCHS软件触发
//不配置就无法读取到数据,但会覆盖之前的配置
__asm("cpsie i");
void DMA_IRQHandler(void)
__asm("nop");
//stop hsadc
LPC_GPDMA-> CH [DMA_CH].CONFIG&=~(0x1 << 0);
Hope it can help you
XiangJun Rong
2,980 次查看
robberpen
%3CLINGO-SUB%20id%3D%22lingo-sub-1938925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC43XX%20HSADC%20DMA%20%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AE%BE%E7%BD%AEhsadc%E7%9A%84%E6%8F%8F%E8%BF%B0%E7%AC%A60%E5%90%8E%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%BD%AF%E4%BB%B6%E8%A7%A6%E5%8F%91%E5%B0%86%E6%95%B0%E6%8D%AE%E9%87%87%E6%A0%B7%E5%88%B0FIFOOUTPUT%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%E5%B9%B6%E5%B0%86FIFO_LEVEL%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA7%E3%80%82%E7%84%B6%E5%90%8E%E5%AE%83%3CSTRONG%3E%E6%88%90%E5%8A%9F%E4%B8%AD%E6%96%AD%E5%88%B0ADCHS_IRQHandler()%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%E7%BC%96%E7%A8%8B%E6%8C%87%E5%8D%97%EF%BC%8C%E5%AE%83%E8%BF%98%E5%BA%94%E8%AF%A5%E8%A7%A6%E5%8F%91%20DMA_HSADC_read%20%E4%BF%A1%E5%8F%B7%E6%9D%A5%E8%A7%A6%E5%8F%91%20DMA%20%E9%80%9A%E9%81%93%E6%BF%80%E6%B4%BB%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%20%3CSTRONG%3EDMA%20%E9%80%9A%E9%81%93%207%20%E4%BB%8E%E6%9C%AA%E5%B7%A5%E4%BD%9C%3C%2FSTRONG%3E%E3%80%82%EF%BC%88%E4%B8%8D%E5%B0%86%20src%3AFIFOOUTPUT%20%E5%A4%8D%E5%88%B6%E5%88%B0%20dst%3AMemory)%3CBR%20%2F%3E%E8%BF%99%E9%87%8C%E7%9A%84%20DMA%20%E8%AE%BE%E7%BD%AE%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%2F%E8%B0%83%E8%AF%95%E8%BF%99%E4%B8%AA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPS%EF%BC%9A%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CDMAMUXER8%20%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3ELPC_CREG-%26gt%3BDMAMUX%20%3D%20(LPC_CREG-%26gt%3BDMAMUX%20%7C%20(0x3%20%26lt%3B%26lt%3B%2016))%3B%20%2F%2F16b(DMAMUXER8)%20%3D%200x3%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8F%82%E8%80%83%20-%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FDMA-keep-getting-quot-Empty-FIFO-empty-quot-0x8000-from-HSADC%2Fm-p%2F734753%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FDMA-keep-getting-quot-Empty-FIFO-empty-quot-0x8000-from-HSADC%2Fmp%2F734753%3C%2FA%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FLPC-Link2-High-Speed-ADC-and-DMA-Interrupt%2Ftd-p%2F1532249%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FLPC-Link2-High-Speed-ADC-and-DMA-Interrupt%2Ftd-p%2F1532249%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E8%AE%BE%E7%BD%AE%20HSADC%20%E6%AD%A3%E5%9C%A8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%200%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%201%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%202%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%203%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%204%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%205%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%206%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_BRANCH_NEXT%20%7C%20HSADC_DESC_MATCH(1)%20%7C%0A%09%20HSADC_DESC_THRESH_NONE%20%7C%20HSADC_DESC_RESET_TIMER%20))%3B%0A%0A%09%20Chip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%207%2C%20(HSADC_DESC_CH(1)%20%7C%0A%09%20HSADC_DESC_MATCH(1)%20%7C%20HSADC_DESC_THRESH_NONE%20%7CHSADC_DESC_BRANCH_FIRST%20%7C%0A%09%20HSADC_DESC_RESET_TIMER%20%7C%20HSADC_DESC_HALT%20%7CHSADC_DESC_INT))%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3EDMA%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Estatic%20void%20App_DMA_Init(void)%0A%7B%0A%09%2F*%20Initialize%20GPDMA%20controller%20*%2F%0A%09Chip_GPDMA_Init(LPC_GPDMA)%3B%0A%09%2F*%20Setting%20GPDMA%20interrupt%20*%2F%0A%09NVIC_DisableIRQ(DMA_IRQn)%3B%0A%09NVIC_SetPriority(DMA_IRQn%2C%20((0x01%20%26lt%3B%26lt%3B%203)%20%7C%200x01))%3B%0A%09NVIC_EnableIRQ(DMA_IRQn)%3B%0A%7D%0A%0Avoid%20Setup_DMA_J(void)%20%2F%2Fcopy%20from%20https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers%2FDMA-keep-getting-quot-Empty-FIFO-empty-quot-0x8000-from-HSADC%2Fm-p%2F734753%0A%7B%0Auint8_t%20DMA_CH%20%3D%207%0A%09App_DMA_Init()%3B%0A%09LPC_CREG-%26gt%3BDMAMUX%20%3D%20(LPC_CREG-%26gt%3BDMAMUX%20%7C%20(0x3%20%26lt%3B%26lt%3B%2016))%3B%20%2F%2F16b(DMAMUXER8)%20%3D%200x3%0A%09%2F*%20Clear%20all%20DMA%20interrupt%20and%20error%20flag%20*%2F%0A%09LPC_GPDMA-%26gt%3BCONFIG%20%3D%200x00%3B%0A%23if%200%20%2F*%20PTM%20duplicated%20*%2F%0A%09LPC_GPDMA-%26gt%3BINTTCCLEAR%20%3D%200xFF%3B%20%2F%2Fclears%20channel%20terminal%20count%20interrupt%0A%09LPC_GPDMA-%26gt%3BINTERRCLR%20%3D%200xFF%3B%20%2F%2Fclears%20channel%20error%20interrupt.%0A%23endif%0A%09LPC_GPDMA-%26gt%3BCONFIG%20%3D%200x01%3B%0A%09while%20(!(LPC_GPDMA-%26gt%3BCONFIG%20%26amp%3B%200x01))%0A%09%09%3B%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.SRCADDR%20%3D%20(uint32_t)%20%26amp%3BLPC_ADCHS-%26gt%3BFIFO_OUTPUT%5B0%5D%3B%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.DESTADDR%20%3D%20((uint32_t)%20gluData)%3B%0A%09%2F%2FLPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.DESTADDR%20%3D%20((uint32_t)%20%26amp%3Bsample)%3B%0A%09%2F%2FLPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONTROL%20%3D%20(DMA_TRANSFER_SIZE%20%26lt%3B%26lt%3B%200)%20%2F%2F%20transfer%20size%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONTROL%20%3D%20(FIFO_OUTPUT_LEVEL%20%26lt%3B%26lt%3B%200)%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2012)%20%2F%2F%20src%20burst%20size%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2015)%20%2F%2F%20dst%20burst%20size%0A%09%09%09%7C%20(0x2%20%26lt%3B%26lt%3B%2018)%20%2F%2F%20src%20transfer%20width%0A%09%09%09%7C%20(0x2%20%26lt%3B%26lt%3B%2021)%20%2F%2F%20dst%20transfer%20width%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2024)%20%2F%2F%20src%20AHB%20master%20select%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2025)%20%2F%2F%20dst%20AHB%20master%20select%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2026)%20%2F%2F%20src%20increment%3A%200%2C%20src%20address%20not%20increment%20after%20each%20trans%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2027)%20%2F%2F%20dst%20increment%3A%201%2C%20dst%20address%20increment%20after%20each%20trans%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2031)%3B%20%2F%2F%20terminal%20count%20interrupt%20enable%20bit%3A%201%2C%20enabled%2C%20(0x0UL%20%26lt%3B%26lt%3B%2031)%3B%20%2F%2F%20Terminal%20count%20interrupt%20disabled%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%3D%20(0x1%20%26lt%3B%26lt%3B%200)%20%2F%2F%20enable%20bit%3A%201%20enable%2C%200%20disable%0A%09%7C%20(HSADC_DMA_READ%20%26lt%3B%26lt%3B%201)%20%2F%2F%20src%20peripheral%3A%20set%20to%208%20-%20HSADC%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%206)%20%2F%2F%20dst%20peripheral%3A%20no%20setting%20-%20memory%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2011)%20%2F%2F%20flow%20control%3A%20peripheral%20to%20memory%20-%20DMA%20control%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2014)%20%2F%2F%20IE%20-%20interrupt%20error%20mask%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2015)%20%2F%2F%20ITC%20-%20terminal%20count%20interrupt%20mask%0A%09%09%09%7C%20(0x0%20%26lt%3B%26lt%3B%2016)%20%2F%2F%20lock%3A%20when%20set%2C%20this%20bit%20enables%20locked%20transfer%0A%09%09%09%7C%20(0x1%20%26lt%3B%26lt%3B%2018)%3B%20%2F%2F%20Halt%3A%201%2C%20enable%20DMA%20requests%3B%200%2C%20ignore%20further%20src%20DMA%20req%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.LLI%20%3D%200%3B%0A%09NVIC_SetPriority(DMA_IRQn%2C0x00)%3B%0A%09NVIC_ClearPendingIRQ(DMA_IRQn)%3B%0A%09LPC_GPDMA-%26gt%3BCONFIG%20%3D%200x01%3B%0A%09NVIC_EnableIRQ(DMA_IRQn)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1938925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC43xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E4%B8%AD%E5%9B%BD%E7%94%A8%E6%88%B7%E8%AE%BA%E5%9D%9B%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC43XX%20HSADC%20DMA%20%E5%A6%82%E4%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BC%BC%E4%B9%8E%3CEM%3E%3CSTRONG%3E0x06%20%26lt%3B%26lt%3B%2011%3C%2FSTRONG%3E%3C%2FEM%3E%E7%94%A8%E4%BA%8E%E7%AA%81%E5%8F%91%20DMA%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E7%BB%A7%E7%BB%AD%E8%BF%9B%E8%A1%8C%E6%9B%B4%E5%A4%9A%E6%B5%8B%E8%AF%95%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%3D%20(0x1%20%26lt%3B%26lt%3B%200)%20%2F%2F%20enable%20bit%3A%201%20enable%2C%200%20...%0A%09%7C%20(0x6%20%26lt%3B%26lt%3B%2011)%20%2F%2F%20flow%20control%3A%20peripheral%20to%20memory%20-%20DMA%20control%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1939931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC43XX%20HSADC%20DMA%20%E5%A6%82%E4%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CDIV%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%200px%200px%200px%202px%3B%22%3E%0A%3CDIV%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'Consolas'%3B%20font-size%3A%2010pt%3B%20white-space%3A%20pre%3B%22%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ETICKRATE_HZ1%20(1000)%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%AF%8F%E7%A7%92%2010%20%E4%B8%AA%E5%88%BB%E5%BA%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20DGEC%200xE%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3EHSADC_DMA_READ%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3EDMA_CH%207%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EDMA_TRANSFER_SIZE%201024%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%9C%80%E5%A4%A7%204095%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3ENUM_SAMPLE%20DMA_TRANSFER_SIZE%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20descrip0%2Cdescrip1%2Cconfig%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%E9%A2%91%E7%8E%87HSADC%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%E6%A0%B7%E6%9C%AC%5BNUM_SAMPLE%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EADCHS_DMA_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2Fuint8_t%20DGEC%20%3D%200xE%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20ADCHS%E9%87%87%E6%A0%B7%E9%A2%91%E7%8E%87%E8%AE%BE%E7%BD%AE%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%20%2F*80M*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2FCLK_M4_ADCHS%E4%BD%BF%E7%94%A8BASE_M4_CLK%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20Chip_USB0_Init()%3B%3C%2FSPAN%3E%3CSPAN%3E%2F*%E5%B0%86USB0%20PLL%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%BA480%20MHz%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20Chip_Clock_SetDivider(%3C%2FSPAN%3E%3CSPAN%3ECLK_IDIV_A%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3ECLKIN_USBPLL%3C%2FSPAN%3E%3CSPAN%3E%2C2)%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%E6%9D%A5%E8%87%AAUSB0PLL%E7%9A%84DIV_A%E6%BA%90%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%88%86%E9%A2%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA2(%E6%94%AF%E6%8C%81%E7%9A%84%E6%9C%80%E5%A4%A7%3C%2FSPAN%3E%3CSPAN%3Ediv%3C%2FSPAN%3E%3CSPAN%3E%E5%80%BC%E4%B8%BA4)%5BIN%20480%20MHz%3B%E8%BE%93%E5%87%BA240%20MHz%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20Chip_Clock_SetDivider(%3C%2FSPAN%3E%3CSPAN%3ECLK_IDIV_B%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3ECLKIN_IDIVA%3C%2FSPAN%3E%3CSPAN%3E%2C3)%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%E6%9D%A5%E8%87%AADIV_A%E7%9A%84%E6%BA%90DIV_B%EF%BC%8C%5BIN%20240%20MHz%3B%E8%BE%93%E5%87%BA80%20MHz%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EChip_Clock_SetBaseClock(%3C%2FSPAN%3E%20%3CSPAN%3ECLK_BASE_ADCHS%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3ECLKIN_IDIVB%3C%2FSPAN%3E%20%3CSPAN%3E%2C%20true%2C%20false)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E4%BB%8EDIV_B%E8%8E%B7%E5%8F%96ADHCS%E5%9F%BA%E7%A1%80%E6%97%B6%E9%92%9F*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20freqHSADC%20%3D%20Chip_HSADC_GetBaseClockRate(LPC_ADCHS)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EChip_Clock_EnableOpts(%3C%2FSPAN%3E%20%3CSPAN%3ECLK_MX_ADCHS%3C%2FSPAN%3E%20%3CSPAN%3E%2C%20true%2C%20true%2C%201)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%E6%97%B6%E9%92%9F*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EChip_Clock_Enable(%3C%2FSPAN%3E%20%3CSPAN%3ECLK_ADCHS%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%E6%97%B6%E9%92%9F*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20HSADC%E8%AE%BE%E7%BD%AE%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E4%B8%AD%E6%96%AD%E8%AE%BE%E7%BD%AE%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20LPC_ADCHS-%26gt%3B%20INTS%20%5B0%5D%20.CLR_EN%20%3D%200x7F%3B%20%2F%2F%E7%A6%81%E7%94%A8%E4%B8%AD%E6%96%AD0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20LPC_ADCHS-%26gt%3B%20INTS%20%5B0%5D%20.CLR_STAT%20%3D%200x7F%3B%20%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20while(LPC_ADCHS-%26gt%3BINTS%5B0%5D.STATUS%26amp%3B0x7D)%3B%20%2F%2F%E7%AD%89%E5%BE%85%E7%8A%B6%E6%80%81%E6%B8%85%E9%99%A4%EF%BC%8C%E5%BF%85%E9%A1%BB%E6%8E%92%E9%99%A4FIFO_EMPTY%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2FLPC_ADCHS-%26gt%3BINTS%5B1%5D.CLR_EN%20%3D%200x7F%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2FLPC_ADCHS-%26gt%3BINTS%5B1%5D.CLR_STAT%20%3D%200x7F%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20while(LPC_ADCHS-%26gt%3B%20INTS%20%5B1%5D.STATUS%26amp%3B0x1E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%E5%88%9D%E5%A7%8B%E5%8C%96HSADC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20Chip_RGU_TriggerReset(%3C%2FSPAN%3E%3CSPAN%3ERGU_ADCHS_RST%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%A4%8D%E4%BD%8DHADC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E5%BD%93%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88Chip_RGU_InReset%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3ERGU_ADCHS_RST%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%EF%BC%89%7B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3EPOWER_DOWN%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E7%A6%81%E7%94%A8%E7%94%B5%E6%BA%90%E5%85%B3%E9%97%AD%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20FIFO%20%E4%B8%AD%E6%96%AD%201%EF%BC%8C%20%E6%97%A0%20%E6%89%93%E5%8C%85%E6%A8%A1%E5%BC%8F%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2FChip_HSADC_SetupFIFO(LPC_ADCHS%2C%201%2C%20false)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3EFIFO_CFG%3C%2FSPAN%3E%3CSPAN%3E%20%3D(8%20%26lt%3B%26lt%3B%201)%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20FIFO_LEVEL%E5%A4%A7%E5%B0%8FPACKED_READ%20%E6%95%B0%E6%8D%AE%E4%BF%9D%E5%AD%98%E5%9C%A8FIFO%E7%9A%84%E6%96%B9%E5%BC%8F%EF%BC%8C1%E8%A1%A8%E7%A4%BA%E4%B8%A4%E4%B8%AA%E9%87%87%E6%A0%B7%E6%95%B0%E6%8D%AE%E6%89%93%E5%8C%85%E5%AD%98%E6%94%BE%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3EDSCR_STS%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20(1%20%26lt%3B%26lt%3B%201)%7C%200%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E8%AE%BE%E7%BD%AE%E6%B4%BB%E5%8A%A8%E7%9A%84%E6%8F%8F%E8%BF%B0%E7%AC%A6%E8%A1%A8%E4%B8%8E%E6%8F%8F%E8%BF%B0%E7%AC%A6%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E8%AE%BE%E7%BD%AE%E6%8F%8F%E8%BF%B0%E7%AC%A6%E8%A1%A80%E4%B8%AD%E7%9A%84%E6%8F%8F%E8%BF%B0%E7%AC%A60*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EDESCRIPTOR%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%5B0%5D%20%3D%20(1%20%26lt%3B%26lt%3B%2024)%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20RESET_TIMER%20%E5%A4%8D%E4%BD%8D%E5%AE%9A%E6%97%B6%E5%99%A8*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0%20%26lt%3B%26lt%3B%2022)%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20THRESH%20%E6%9C%AA%E6%B7%BB%E5%8A%A0%E6%AF%94%E8%BE%83%E5%99%A8*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(0%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20MATCH%20%E6%8F%8F%E8%BF%B0%E7%AC%A6%E8%AE%A1%E6%97%B6%E5%99%A8%E5%80%BC%E7%AD%89%E4%BA%8EMATC%E6%97%B6%EF%BC%8C%E8%BD%AC%E6%8D%A2%E6%8F%8F%E8%BF%B0%E7%AC%A6*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(1%20%26lt%3B%26lt%3B%206)%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20BRANCH%20to%20First%20%E8%BD%AC%E6%8D%A2%E5%AE%8C%E6%88%90%E5%90%8E%E8%B7%B3%E8%BD%AC%E5%88%B0%E8%AF%A5%E8%A1%A8%E7%AC%AC%E4%B8%80%E4%B8%AACPU*%2F%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20descrip0%20%3DLPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EDESCRIPTOR%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%5B0%5D%20%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E8%AE%BE%E7%BD%AE%E6%8F%8F%E8%BF%B0%E7%AC%A6%201%20%E5%9C%A8%200x9A%20%E6%97%B6%E9%92%9F%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%B5%8B%E9%87%8F%E5%B9%B6%E5%88%86%E6%94%AF%E5%88%B0%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%8F%8F%E8%BF%B0%E7%AC%A6*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EDESCRIPTOR%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%5B1%5D%20%3D(1%20%26lt%3B%26lt%3B%2031)%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20UPDATE%20TABLE*%2F%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E6%9C%80%E9%AB%98%E4%BD%8D%E9%85%8D%E7%BD%AE%E4%B8%8D%E4%B8%8A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(1%20%26lt%3B%26lt%3B%2024)%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E9%87%8D%E7%BD%AE%E5%AE%9A%E6%97%B6%E5%99%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(0%20%26lt%3B%26lt%3B%2022)%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E9%98%88%E5%80%BC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(0%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%3CSPAN%3E%2F*%20%E5%8C%B9%E9%85%8D*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(0x01%20%26lt%3B%26lt%3B%206)%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%88%86%E6%94%AF%E5%88%B0%E7%AC%AC%E4%B8%80%E4%B8%AA%20*%2F%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20descrip1%20%3DLPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EDESCRIPTOR%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%5B1%5D%20%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%20%3D(0x90%20%26lt%3B%26lt%3B%206)%3C%2FSPAN%3E%3CSPAN%3E%2F*%E6%81%A2%E5%A4%8D%E6%97%B6%E9%97%B4%2C%E5%BB%BA%E8%AE%AE%E5%80%BC*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0%20%26lt%3B%26lt%3B%205)%3C%2FSPAN%3E%3CSPAN%3E%2F*%20CHANNEL_ID_EN%20%EF%BC%8C0%E8%A1%A8%E7%A4%BA%E4%B8%8D%E5%B0%86%E9%80%9A%E9%81%93ID%E8%BE%93%E5%85%A5%E5%88%B0FIFO%E4%B8%AD*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x01)%3C%2FSPAN%3E%3CSPAN%3E%2F*%20TRIGGER_MASK%2001%20%E8%A1%A8%E7%A4%BA%E4%BB%85%E4%BD%BF%E7%94%A8%E8%BD%AF%E4%BB%B6%E8%A7%A6%E5%8F%91*%2F%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20CRS%E8%AE%BE%E7%BD%AE%E4%B8%BA0x4%EF%BC%8C%E6%89%80%E4%BB%A5SPEED%E6%89%80%E6%9C%89DGEC%E5%BA%94%E8%AF%A5%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA0xE%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ELPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EADC_SPEED%3C%2FSPAN%3E%20%3CSPAN%3E%3D(DGEC%20%26lt%3B%26lt%3B%2020)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(DGEC%20%26lt%3B%26lt%3B%2016)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%EF%BC%88DGEC%20%26lt%3B%26lt%3B%2012%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7C%20(DGEC%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(DGEC%20%26lt%3B%26lt%3B%204)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(DGEC)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%E6%9C%AA%E8%AE%BE%E7%BD%AE%E9%98%88%E5%80%BC%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%9C%AA%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ELPC_ADCHS-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EPOWER_CONTROL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%EF%BC%881%20%26lt%3B%26lt%3B%2018%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20BGAP%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C(1%20%26lt%3B%26lt%3B%2017)%3C%2FSPAN%3E%3CSPAN%3E%2F*%E7%94%B5%E6%BA%90%20ADC%E4%BF%9D%E6%8C%81%E4%BE%9B%E7%94%B5*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C(0%20%26lt%3B%26lt%3B%204)%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20DCINNEG%E5%9C%A8ADC0%20No%20%3C%2FSPAN%3E%3CSPAN%3Edc%3C%2FSPAN%3E%3CSPAN%3E%20bias%20%E5%BD%93%20DCINNEG%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%20%E6%97%B6%EF%BC%8C%E6%8F%90%E4%BE%9B%20ADCHS_NEG%20%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%EF%BC%88ADCHS%20%E7%94%A8%E4%BA%8E%E7%9C%9F%E5%B7%AE%E5%88%86%E6%A8%A1%E5%BC%8F%EF%BC%89%EF%BC%9A*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C(0%20%26lt%3B%26lt%3B%2010)%3C%2FSPAN%3E%3CSPAN%3E%2F*%20DC%E5%9C%A8ADC0%E4%B8%AD%20No%20%3C%2FSPAN%3E%3CSPAN%3Edc%3C%2FSPAN%3E%3CSPAN%3E%20bias*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C(0%20%26lt%3B%26lt%3B%2016)%3C%2FSPAN%3E%3CSPAN%3E%2F*%201%20%3D%E4%BB%A5TWOS%E8%BE%93%E5%87%BA-0%20%3D%E4%BB%A5Offset%20Binary%E8%BE%93%E5%87%BA*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C(0x4)%3C%2FSPAN%3E%3CSPAN%3E%2F*%20CRS%20%EF%BC%8C%E8%AE%BE%E7%BD%AEADC%E9%80%9F%E5%BA%A6*%2F%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3EFLUSH%3C%2FSPAN%3E%3CSPAN%3E%20%3D%201%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FFIFO%E5%88%B7%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%20DMA%E8%AE%BE%E7%BD%AE%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20NVIC_DisableIRQ(%3C%2FSPAN%3E%3CSPAN%3EDMA_IRQn%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%20%5BDMA_CH%5D%20.%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%20%7C%3D0%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%90%AF%E7%94%A8%E4%BD%8D%EF%BC%8C1%E5%90%AF%E7%94%A8%EF%BC%8C0%E7%A6%81%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ELPC_GPDMA-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EINTTCCLEAR%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%20((1UL%20%26lt%3B%26lt%3B%20DMA_CH%20)%20%26amp%3B%200xFF)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ELPC_GPDMA-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EINTERRCLR%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%20((1UL%20%26lt%3B%26lt%3B%20DMA_CH%20)%20%26amp%3B%200xFF)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200x01%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%3E(!(LPC_GPDMA-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECONFIG%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B0x01))%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E4%BD%BF%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E6%8F%8F%E8%BF%B0%E7%AC%A6%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E4%BB%85%E8%83%BD%E9%80%9A%E8%BF%87DMA%E9%80%9A%E9%81%937%E4%BC%A0%E9%80%92%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3ESRCADDR%3C%2FSPAN%3E%3CSPAN%3E%20%3D(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E)%26amp%3BLPC_ADCHS-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3EFIFO_OUTPUT%3C%2FSPAN%3E%3CSPAN%3E%20%5B0%5D%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2FDMA%E6%BA%90%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3EDESTADDR%3C%2FSPAN%3E%3CSPAN%3E%20%3D((%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E)%26amp%3Bsample)%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2FDMA%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3ECONTROL%3C%2FSPAN%3E%3CSPAN%3E%20%3D(DMA_TRANSFER_SIZE)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E4%BC%A0%E8%BE%93%E5%A4%A7%E5%B0%8F%20%E6%9C%80%E5%A4%A74095%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x0%20%26lt%3B%26lt%3B%2012)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E7%AA%81%E5%8F%91%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x0%20%26lt%3B%26lt%3B%2015)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%E7%AA%81%E5%8F%91%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x2%20%26lt%3B%26lt%3B%2018)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%A0%E8%BE%93%E5%AE%BD%E5%BA%A6%EF%BC%8C0x2%E8%A1%A8%E7%A4%BA%E4%BB%A5%E5%AD%97%E7%9A%84%E5%BD%A2%E5%BC%8F%E4%BC%A0%E8%BE%93%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x2%20%26lt%3B%26lt%3B%2021)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%A0%E8%BE%93%E5%AE%BD%E5%BA%A6%EF%BC%8C0x2%E8%A1%A8%E7%A4%BA%E4%BB%A5%E5%AD%97%E7%9A%84%E5%BD%A2%E5%BC%8F%E4%BC%A0%E8%BE%93%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x1%20%26lt%3B%26lt%3B%2024)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%20AHB%E4%B8%BB%E9%80%89%E6%8B%A9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x0%20%26lt%3B%26lt%3B%2025)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%20AHB%E4%B8%BB%E9%80%89%E6%8B%A9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x0%20%26lt%3B%26lt%3B%2026)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E5%A2%9E%E9%87%8F%EF%BC%9A0%EF%BC%8C%E6%AF%8F%E6%AC%A1%E4%BC%A0%E8%BE%93%E5%90%8E%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%E4%B8%8D%E9%80%92%E5%A2%9E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x1%20%26lt%3B%26lt%3B%2027)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%E5%A2%9E%E9%87%8F%EF%BC%9A1%EF%BC%8C%E6%AF%8F%E6%AC%A1%E4%BC%A0%E8%BE%93%E5%90%8E%E7%9A%84%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%E5%A2%9E%E9%87%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x1%20%26lt%3B%26lt%3B%2031)%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E7%BB%88%E7%AB%AF%E8%AE%A1%E6%95%B0%E4%B8%AD%E6%96%AD%E4%BD%BF%E8%83%BD%E4%BD%8D%EF%BC%9A1%EF%BC%8C%E4%BD%BF%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20(%3C%2FSPAN%3E%3CSPAN%3EHSADC_DMA_READ%3C%2FSPAN%3E%3CSPAN%3E%20%26lt%3B%26lt%3B%201)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%96%E8%AE%BE%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA8-HSADC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x0%20%26lt%3B%26lt%3B%206)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Edst%3C%2FSPAN%3E%3CSPAN%3E%E5%A4%96%E8%AE%BE%EF%BC%9A%E6%97%A0%E8%AE%BE%E7%BD%AE-%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x6%20%26lt%3B%26lt%3B%2011)%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%B5%81%E6%8E%A7%E5%88%B6%EF%BC%9A%E5%A4%96%E8%AE%BE-%E5%AD%98%E5%82%A8%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7C%20(0x1%20%26lt%3B%26lt%3B%2014)%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20IE-%E4%B8%AD%E6%96%AD%E9%94%99%E8%AF%AF%E6%8E%A9%E7%A0%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%7C%20%EF%BC%880x1%20%26lt%3B%26lt%3B%2015%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20ITC-%E7%BB%88%E7%AB%AF%E8%AE%A1%E6%95%B0%E4%B8%AD%E6%96%AD%E5%B1%8F%E8%94%BD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%7C%20(0x1%20%26lt%3B%26lt%3B%200)%3B%2F%2F%20%E5%90%AF%E7%94%A8%E4%BD%8D%EF%BC%9A1%20%E5%90%AF%E7%94%A8%EF%BC%8C0%20%E7%A6%81%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%7C%20(0x0%20%26lt%3B%26lt%3B%2016)%2F%2F%E9%94%81%E5%AE%9A%EF%BC%9A%E7%BD%AE%E4%BD%8D%E6%97%B6%EF%BC%8C%E6%AD%A4%E4%BD%8D%E8%A7%A3%E9%94%81%E4%BC%A0%E8%BE%93%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%7C%20(0x1%20%26lt%3B%26lt%3B%2018)%3B%20%2F%2F%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%BF%BD%E7%95%A5%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%20%3CSPAN%3EDMA%3C%2FSPAN%3E%20%3CSPAN%3Ereq%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ELPC_CREG-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX%3C%2FSPAN%3E%20%3CSPAN%3E%3D3%26lt%3B%26lt%3B16%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E9%80%89%E6%8B%A9%20DMAMUXPER8%20%E7%9A%84%20HSADC%20%E8%AF%BB%E5%8F%96%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%20%5BDMA_CH%5D%20.%3C%2FSPAN%3E%3CSPAN%3ELLI%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20NVIC_EnableIRQ(DMA_IRQn)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20config%20%3DLPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%20%5BDMA_CH%5D%20.%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%20%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%7C%3D(0x1%20%26lt%3B%26lt%3B%200)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20Chip_HSADC_SWTrigger(LPC_ADCHS)%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%90%AF%E5%8A%A8ADCHS%E8%BD%AF%E4%BB%B6%E8%A7%A6%E5%8F%91%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%E4%B8%8D%E9%85%8D%E7%BD%AE%E5%B0%B1%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%88%B0%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E4%BC%9A%E8%A6%86%E7%9B%96%E4%B9%8B%E5%89%8D%E7%9A%84%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20NVIC_SetPriority(%3C%2FSPAN%3E%3CSPAN%3EDMA_IRQn%3C%2FSPAN%3E%3CSPAN%3E%2C0x00)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20NVIC_ClearPendingIRQ(%3C%2FSPAN%3E%3CSPAN%3EDMA_IRQn%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20NVIC_EnableIRQ(%3C%2FSPAN%3E%3CSPAN%3EDMA_IRQn%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E__asm%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3Ecpsie%3C%2FSPAN%3E%3CSPAN%3E%20i%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EDMA_IRQHandler%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E__asm%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%3C%2FSPAN%3E%20%3CSPAN%3Enop%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3CSPAN%3Ehsadc%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20LPC_GPDMA-%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%3ECH%3C%2FSPAN%3E%3CSPAN%3E%20%5BDMA_CH%5D.%3C%2FSPAN%3E%3CSPAN%3ECONFIG%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3D~(0x1%20%26lt%3B%26lt%3B%200)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%E5%B8%8C%E6%9C%9B%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%88%B0%E4%BD%A0%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3EBR%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%E8%8D%A3%E5%90%91%E4%BF%8A%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1939412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC43XX%20HSADC%20DMA%20%E5%A6%82%E4%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20DMA%20%E4%BC%A0%E8%BE%93%E6%9D%A5%E6%93%8D%E4%BD%9C%20hsadc%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%20DMA_read%20REQ%20%E4%BF%A1%E5%8F%B7%E8%8E%B7%E5%BE%97%E6%9B%B4%E5%A4%9A%E6%9C%AA%E6%9D%A5%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E9%87%8C%E6%9C%89%E4%BA%9B%E9%94%AE%E9%9C%80%E8%A6%81%E7%A1%AE%E8%AE%A4%3C%2FP%3E%3CP%3E%E5%9F%BA%E4%BA%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E48.7.4.1%20DMA%20%E8%AF%BB%E5%8F%96%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3Ehsadc%20%E4%BB%85%E6%94%AF%E6%8C%81%20DMA%20%E9%80%9A%E9%81%93%208%20%E8%BF%9B%E8%A1%8C%E8%AF%BB%E5%8F%96%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%88%91%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%E5%9C%A8%20IRQ%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E4%B8%8A%E8%AE%BE%E7%BD%AE%E4%BD%8D%201%E3%80%82%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%26gt%3BLPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%3D%20LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%7C%26nbsp%3B%200x1%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%E4%BD%86%E6%88%91%E6%83%B3%E9%80%9A%E8%BF%87%3CSTRONG%3EDMA_read%20REQ%20%E4%BF%A1%E5%8F%B7%3C%2FSTRONG%3E%E6%BF%80%E6%B4%BB%20DMA%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%BF%98%E8%AE%BE%E7%BD%AE%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EDMAMUXER8%3C%2FSTRONG%3E%20%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BB%8D%E7%84%B6%E4%B8%8D%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E9%A2%84%E8%AE%A1%20DMA_read%20%E4%BF%A1%E5%8F%B7%E5%BA%94%E8%AF%A5%E5%9C%A8%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EFIFO%E7%BA%A7%E5%88%AB%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%88%96%E8%80%85%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EFIFO_FULL%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%8F%91%E7%94%9F%E3%80%82%3CBR%20%2F%3E%26gt%3BLPC_CREG-%26gt%3B%20%3CSPAN%3EDMAMUX%3C%2FSPAN%3E%20%3CSPAN%3E%3D%20(LPC_CREG-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX%3C%2FSPAN%3E%20%3CSPAN%3E%7C%20(0x3%20%26lt%3B%26lt%3B%2016))%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20ADCHS_IRQHandler(void)%20%7B%0A%09LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%3D%20LPC_GPDMA-%26gt%3BCH%5BDMA_CH%5D.CONFIG%20%7C%20%200x1%3B%0A%09Chip_HSADC_ClearIntStatus(LPC_ADCHS%2C%201%2C%20Chip_HSADC_GetIntStatus(LPC_ADCHS%2C%201)%20%26amp%3B%20Chip_HSADC_GetEnabledInts(LPC_ADCHS%2C%201))%3B%0A%09Chip_HSADC_ClearIntStatus(LPC_ADCHS%2C%200%2C%20Chip_HSADC_GetIntStatus(LPC_ADCHS%2C%200)%20%26amp%3B%20Chip_HSADC_GetEnabledInts(LPC_ADCHS%2C%200))%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E2%80%83%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222024-08-24%2002_02_06-UM10503.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222024-08-24%2002_02_06-UM10503.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F295035i5E46C079FEB3C4DC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222024-08-24%2002_02_06-UM10503.png%22%20alt%3D%222024-08-24%2002_02_06-UM10503.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
