LPC4370 and Keil MDK version 5 series program
1,920 次查看
sujayp
Dear NXP Technical Support Services ,
I am writing in regards the programming for the LPC4370FET256 using the KEIL MDK ARM Version 5 using the Keil ULINK 2 debugger.
Since I couldn’t find the proper link for programming for the LPC4370FET256 using the KEIL MDK ARM Version 5 using the Keil ULINK 2 debugger.
I was having the link for the Keil MDK version 4.74 not the Keil MDK arm Ver 5 series which is a latest one software  in order to program the LPC4370FET256 from the external flash memory.
Will you help in this regards
Thanking you.
1,646 次查看
soledad
Please check the below link, you will find LPCOpen for Keil v5
LPCOpen Software for LPC43XX|NXP
Sol
