LPC4357 bootloader dump
3,788 次查看
pieroquark87
Hi there,
I would like to know if is it possible to dump the bootloader flashed on the internal ROM of the LPC4357 tracing back to the corresponding bin file.
Many thanks in advance.
Giovanni
5 回复数
3,784 次查看
Pavel_Hernandez
No, you can't put your own bootloader in the ROM, the ROM already has the definite bootloader and can't be erased before out of the factory.
If you want to use the customized bootloader, you should put it in front of the flash.
Pavel
3,779 次查看
pieroquark87
Hi, yes, sorry, I said that badly. I meant I've loaded onto the flash A memory a custom bootloader using the Ulink Pro. After that if, for example, I give the board to you, is there a way you can trace back to the corresponding bin file of the custom bootloader I've loaded?
3,773 次查看
Pavel_Hernandez
Yes, sure, but are you interested in locking the MCU?
Pavel
3,766 次查看
pieroquark87
Hi, thanks for your reply. How do you make to trace back to the custom bootloader bin?
3,718 次查看
Pavel_Hernandez
What do you mean with |trace back|? Is that for TRACE or Reverse engineering?
I think we have different understanding could you please elaborate further?
If you want to use a secure bootloader I think this app note maybe could help you.
[Secure Bootloader implementation (nxp.com)] [Firmware Update Using Secondary Bootloader (nxp.com)]
Pavel
