LPC4357 Uart example
2,601 次查看
Content originally posted in LPCWare by marcosbontempo on Mon May 02 07:27:58 MST 2016
Does anybody have an example using the UART of LPC4357? I'm using the LPC4357-EVB kit.
I already tried this example, with no success: http://docs.lpcware.com/lpcopen/v1.03/group___e_x_a_m_p_l_e_s___p_e_r_i_p_h__18_x_x43_x_x___u_a_r_t....
I searched examples in this link https://www.element14.com/community/docs/DOC-62632/l/element14-software-examples-and-demos-for-the-l..., but there is no one for UART.
Any tip will be very helpful,
Thanks.
2,094 次查看
bump
2,094 次查看
Content originally posted in LPCWare by marcosbontempo on Tue May 03 04:49:34 MST 2016
Thanks for you answer! These examples are exactly what I wanted.
2,094 次查看
Content originally posted in LPCWare by adityapadaria on Mon May 02 21:35:31 MST 2016
Download LPC43xx CMSIS - Compliant Standard Peripheral Firmware Driver Library.
It have UART Example.
Note: Check UART Pin Configuration. You may have to change pins according to your development board.
