LPC4357 Uart example
Content originally posted in LPCWare by marcosbontempo on Mon May 02 07:27:58 MST 2016
Does anybody have an example using the UART of LPC4357? I'm using the LPC4357-EVB kit.
I already tried this example, with no success: http://docs.lpcware.com/lpcopen/v1.03/group___e_x_a_m_p_l_e_s___p_e_r_i_p_h__18_x_x43_x_x___u_a_r_t....
I searched examples in this link https://www.element14.com/community/docs/DOC-62632/l/element14-software-examples-and-demos-for-the-l..., but there is no one for UART.
Any tip will be very helpful,
Thanks.
bump
Content originally posted in LPCWare by marcosbontempo on Tue May 03 04:49:34 MST 2016
Thanks for you answer! These examples are exactly what I wanted.
Content originally posted in LPCWare by adityapadaria on Mon May 02 21:35:31 MST 2016
Download LPC43xx CMSIS - Compliant Standard Peripheral Firmware Driver Library.
It have UART Example.
Note: Check UART Pin Configuration. You may have to change pins according to your development board.
