LPC4337 BOD RESET
LPC4337 BOD RESET
mazejun
Is BOD RESET enabled by default when the LPC4337 microcontroller is powered on? I cannot find the register to configure this function. If it is not enabled by default, can you provide a method to initialize this function, or which part of the manual should I read to implement this function? Thanks a lot!
Harry_Zhang
Hi @mazejun
Yes — BOD reset is enabled by default on LPC4337 at power‑on.
You cannot disable it, because the BOD is  Always‑On and  has no configurable register in LPC43xx.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2297988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC4337%20BOD%20RESET%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20BOD%20RESET%20enabled%20by%20default%20when%20the%20LPC4337%20microcontroller%20is%20powered%20on%3F%20I%20cannot%20find%20the%20register%20to%20configure%20this%20function.%20If%20it%20is%20not%20enabled%20by%20default%2C%20can%20you%20provide%20a%20method%20to%20initialize%20this%20function%2C%20or%20which%20part%20of%20the%20manual%20should%20I%20read%20to%20implement%20this%20function%3F%20Thanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC4337%20BOD%20RESET%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259053%22%20target%3D%22_blank%22%3E%40mazejun%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3EYes%20%E2%80%94%20BOD%20reset%20is%20enabled%20by%20default%20on%20LPC4337%20at%20power%E2%80%91on.%3CBR%20%2F%3EYou%20cannot%20disable%20it%2C%20because%20the%20BOD%20is%26nbsp%3B%20Always%E2%80%91On%20and%26nbsp%3B%20has%20no%20configurable%20register%20in%20LPC43xx.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3EHarry%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
