LPC3250 NAND flash & SDRAM size compatibility
lpcware
Content originally posted in LPCWare by pdpro on Fri Nov 01 11:57:09 MST 2013
I am working on my own custom hardware using LPC3250. I want to use maximum size for NAND flash & SDRAM. I studied almost all the concerned section of datasheet & user manual but can't find any mentioning of size compatibility of respective interfacing.
Does anyone have idea about what is maximum supporting size of NAND flash & SDRAM?
