LPC18S50FET180 can replace LPC1830FET180?
Lurkersoo
Hello, I have a project is designed with LPC1830FET180. For shortage issue, I try to find pin-to-pin replacement. If I use LPC18S50FET180 to replace it, the LPC1830FET180 firmware need to be changed or it can be programmed directly and it can work well?
Thanks!
