LPC1833JBD144 config SD card CLK, how do?
1,614件の閲覧回数
9218sky
pin conifg code:
scu_pinmux (CLK0,  0,   MD_DIS_PU | MD_EHS, FUNC4);            /*CLK0:  SD card clock*/
MDK build error:  CLK0   undefined!
how do use pinmux tool,  config this  pin_name "CLK0" work on SD_CLK  function ?
thanks.
1,424件の閲覧回数
soledad
Could you please add more information about this issue?
Which IDE are you using?
Are you using LPCOpen?
Could you add a screenshot of this error?
Sol
1,424件の閲覧回数
9218sky
Soledad.
the problem  already ravel out.
thanks.
