LPC1788 with TFT interface
1,626 次查看
manikantakuntum
hi,
I am using  LPC1788 controller for interfacing TFT Display. I require to know that what  impedance should the RGB bit lines contains for interfacing with TFT Display and what impedance should i provide for interfacing  CLK signals
manikanta.k
标记 (1)
1,312 次查看
soledad
Hello Manikanta.k,
Please check the below link, you will find a schematic file that you can use as reference.
http://www.haoyuelectronics.com/Download/HY-LPC1788-SDK/HY-LPC1788-Core_SCH.pdf
In addition, I'd like to recommend looking at this thread:
http://www.lpcware.com/content/forum/dram-pcb-layout-works-only-60-mhz
Sol
