LPC1788 & NXP-emWin538-libraries, compile error
2,342 次查看
myz
Hello , All:
        I am used LPC1788 & emwin5.30c in my new product .But I find a bug in emwin5.30c, so I want update emwin to 5.38 version. My compiler is keil mdk 5.23,  I download NXP-emWin538-libraries.zip and replace emwin5.30c in my project .The compile Error like this:
.\Objects\DispPrj.axf: Error: L6366E: WM_ValidateWindow.o attributes are not compatible with the provided attributes .
Object WM_ValidateWindow.o contains Build Attributes that are incompatible with the provided attributes.
    Tag_CPU_arch = ARM v7E-M (=13)
.\Objects\DispPrj.axf: Error: L6366E: WM__ForEachDesc.o attributes are not compatible with the provided attributes .
Object WM__ForEachDesc.o contains Build Attributes that are incompatible with the provided attributes.
        Error nums up to 239. I don't know what occurred , and how can I sovle these errors?
        Thanks and wait for help.
标签 (2)
1,938 次查看
kerryzhou
Hi my z,
    Did you add the according lib path in the IDE?
    You can send me your test project, I will help you to check it on my side.
Kerry
1,938 次查看
kerryzhou
Hi my z,
   I have reproduced your problem on my side.
  I think it should be the new lib problem, please use the emwin5.30c now, I will check the new emwin problem with our according department.
Kerry
1,938 次查看
myz
Hi Kerry:
I found some bugs from emwin5.30c,older emwin version can not support truetype(I tested,seem), Can I use 5.32 or 5.36?Where I can download these version? And when will correct 5.38?
Thank you
