LPC1768 wake up from DeepSleep using a GPIO IRQ
1,705 次查看
laurianussss
I am trying to wake up an LPC1768 using a GPIO IRQ from Deep sleep. Now it works but only using WDT and it resets the MCU. Also need help with what should I do the program to be resumed when IRQ is detected and not reset.
When I try to use a GPIO intrerupt it does not even reset it.
PINSEL_CFG_Type PinCfg;
PinCfg.Funcnum = 1;
PinCfg.OpenDrain = 0;
PinCfg.Pinmode = PINSEL_PINMODE_PULLUP;
PinCfg.Portnum = 2;
PinCfg.Pinnum = 10;
PINSEL_ConfigPin(&PinCfg);
NVIC_SetPriority(EINT0_IRQn, 0);
NVIC_ClearPendingIRQ(EINT0_IRQn);
LPC_PINCON->PINSEL4 |= (0x01 << 20); // function: EINT0
LPC_SC->EXTMODE |= ~(1 << 0); // Edge sensitive
//LPC_SC->EXTPOLAR &= ~(1 << 0); // falling-edge sensitive
LPC_SC->EXTPOLAR &= 1 << 0; // falling-edge sensitive
LPC_SC->EXTINT = (1 << 0); // clear flag
NVIC_EnableIRQ(EINT0_IRQn);
//---------- Disable and disconnect the main PLL0 before enter into Deep-Sleep
// or Power-Down mode <according to errata.lpc1768-16.March.2010> ------------
LPC_SC->PLL1CON = 2; // Turn off the main PLL (PLL0)
LPC_SC->PLL1FEED = 0xAA; // Feed
LPC_SC->PLL1FEED = 0x55; // Feed
while ((LPC_SC->PLL1STAT & (1<<9)) == 0); // Check connect bit status
LPC_SC->PLL0CON &= ~(1<<1); // Disconnect the main PLL (PLL0)
LPC_SC->PLL0FEED = 0xAA; // Feed
LPC_SC->PLL0FEED = 0x55; // Feed
while ((LPC_SC->PLL0STAT & (1<<25)) != 0x00); // Wait for main PLL (PLL0) to disconnect
LPC_SC->PLL0CON &= ~(1<<0); // Turn off the main PLL (PLL0)
while ((LPC_SC->PLL0STAT & (1<<24)) != 0x00); // Wait for main PLL (PLL0) to shut down
//------------Then enter into PowerDown mode ----------------------------------
CLKPWR_DeepSleep();
void EINT0_IRQHandler(void)
NVIC_SystemReset();
标签 (2)
1,658 次查看
laurianussss
Thanks for reply. I found the problem after all. I was just need to disconnect debuger and make a power cycle. I was confused because watch dog wake up reset was working with debuger connected. Anyway GPIO wake up and continue the code was not working with debuger connected even after a power cycle. I think this was is not so clear explained in datasheet even now when I read it says something about this.
1,659 次查看
laurianussss
1,668 次查看
Hello @laurianussss
How about testing the low - power demo under LPCopen on your side first?
It uses timer as wake up source.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2051038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC1768%20%E4%BD%BF%E7%94%A8%20GPIO%20IRQ%20%E4%BB%8E%20DeepSleep%20%E5%94%A4%E9%86%92%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20GPIO%20IRQ%20%E5%B0%86%20LPC1768%20%E4%BB%8E%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E4%B8%AD%E5%94%A4%E9%86%92%E3%80%82%E7%8E%B0%E5%9C%A8%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E4%BB%85%E4%BD%BF%E7%94%A8%20WDT%20%E5%B9%B6%E4%B8%94%E5%AE%83%E4%BC%9A%E9%87%8D%E7%BD%AE%20MCU%E3%80%82%E8%BF%98%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%BD%93%E6%A3%80%E6%B5%8B%E5%88%B0%20IRQ%20%E8%80%8C%E4%B8%8D%E6%98%AF%E9%87%8D%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E6%89%8D%E8%83%BD%E6%81%A2%E5%A4%8D%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20GPIO%20%E4%B8%AD%E6%96%AD%E6%97%B6%EF%BC%8C%E5%AE%83%E7%94%9A%E8%87%B3%E4%B8%8D%E4%BC%9A%E9%87%8D%E7%BD%AE%E5%AE%83%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPINSEL_CFG_Type%20PinCfg%3B%3CBR%20%2F%3EPinCfg.Funcnum%20%3D%201%3B%3CBR%20%2F%3EPinCfg.OpenDrain%20%3D%200%3B%3CBR%20%2F%3EPinCfg.Pinmode%20%3D%20PINSEL_PINMODE_PULLUP%3B%3CBR%20%2F%3EPinCfg.Portnum%20%3D%202%3B%3CBR%20%2F%3E%3CBR%20%2F%3EPinCfg.Pinnum%20%3D%2010%3B%3CBR%20%2F%3EPINSEL_ConfigPin(%26amp%3BPinCfg)%3B%3CBR%20%2F%3E%3CBR%20%2F%3ENVIC_SetPriority(EINT0_IRQn%2C%200)%3B%3CBR%20%2F%3ENVIC_ClearPendingIRQ(EINT0_IRQn)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ELPC_PINCON-%26gt%3BPINSEL4%20%7C%3D%20(0x01%20%26lt%3B%26lt%3B%2020)%3B%20%2F%2F%E5%8A%9F%E8%83%BD%3A%20EINT0%3CBR%20%2F%3E%20LPC_SC-%26gt%3BEXTMODE%20%7C%3D%20~(1%20%26lt%3B%26lt%3B%200)%3B%20%2F%2F%20%E8%BE%B9%E7%BC%98%E6%95%8F%E6%84%9F%3CBR%20%2F%3E%2F%2FLPC_SC-%26gt%3BEXTPOLAR%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%200)%3B%20%2F%2F%E4%B8%8B%E9%99%8D%E6%B2%BF%E6%95%8F%E6%84%9F%3CBR%20%2F%3ELPC_SC-%26gt%3BEXTPOLAR%20%26amp%3B%3D%201%20%26lt%3B%26lt%3B%200%3B%20%2F%2F%E4%B8%8B%E9%99%8D%E6%B2%BF%E6%95%8F%E6%84%9F%3C%2FP%3E%3CP%3ELPC_SC-%26gt%3BEXTINT%20%3D%20(1%20%26lt%3B%26lt%3B%200)%3B%20%2F%2F%20clear%20flag%3CBR%20%2F%3E%3CBR%20%2F%3ENVIC_EnableIRQ(EINT0_IRQn)%3B%3C%2FP%3E%3CP%3E%2F%2F----------%20%E5%9C%A8%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E4%B9%8B%E5%89%8D%E7%A6%81%E7%94%A8%E5%B9%B6%E6%96%AD%E5%BC%80%E4%B8%BB%20PLL0%3CBR%20%2F%3E%20%2F%2F%E6%88%96%E6%8E%89%E7%94%B5%E6%A8%A1%E5%BC%8F%3CACCORDING%20to%3D%22%22%20errata.lpc1768-16.march.2010%3D%22%22%3E------------%3C%2FACCORDING%3E%3C%2FP%3E%3CP%3ELPC_SC-%26gt%3BPLL1CON%20%3D%202%3B%20%2F%2F%E5%85%B3%E9%97%AD%E4%B8%BBPLL%EF%BC%88PLL0%EF%BC%89%3CBR%20%2F%3E%20LPC_SC-%26gt%3BPLL1FEED%20%3D%200xAA%3B%20%2F%2F%20%E8%BF%9B%E7%BB%99%3CBR%20%2F%3ELPC_SC-%26gt%3BPLL1FEED%20%3D%200x55%3B%20%2F%2F%E4%BE%9B%E7%BB%99%3CBR%20%2F%3Ewhile%20((LPC_SC-%26gt%3BPLL1STAT%20%26amp%3B%20(1%26lt%3B%26lt%3B9))%20%3D%3D%200)%3B%20%2F%2F%E6%A3%80%E6%9F%A5%E8%BF%9E%E6%8E%A5%E4%BD%8D%E7%8A%B6%E6%80%81%3C%2FP%3E%3CP%3ELPC_SC-%26gt%3BPLL0CON%20%26amp%3B%3D%20~(1%26lt%3B%26lt%3B1)%3B%20%2F%2F%E6%96%AD%E5%BC%80%E4%B8%BBPLL%EF%BC%88PLL0%EF%BC%89%3CBR%20%2F%3E%20LPC_SC-%26gt%3BPLL0FEED%20%3D%200xAA%3B%20%2F%2F%20%E8%BF%9B%E7%BB%99%3CBR%20%2F%3ELPC_SC-%26gt%3BPLL0FEED%20%3D%200x55%3B%20%2F%2F%20%E4%BE%9B%E7%BB%99%3CBR%20%2F%3E%3CBR%20%2F%3Ewhile%20((LPC_SC-%26gt%3BPLL0STAT%20%26amp%3B%20(1%26lt%3B%26lt%3B25))%20!%3D%200x00)%3B%20%2F%2F%E7%AD%89%E5%BE%85%E4%B8%BB%20PLL%20(PLL0)%20%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3ELPC_SC-%26gt%3BPLL0CON%20%26amp%3B%3D%20~(1%26lt%3B%26lt%3B0)%3B%20%2F%2F%E5%85%B3%E9%97%AD%E4%B8%BBPLL%EF%BC%88PLL0%EF%BC%89%3CBR%20%2F%3E%20LPC_SC-%26gt%3BPLL0FEED%20%3D%200xAA%3B%20%2F%2F%20%E8%BF%9B%E7%BB%99%3CBR%20%2F%3ELPC_SC-%26gt%3BPLL0FEED%20%3D%200x55%3B%20%2F%2F%20%E4%BE%9B%E7%BB%99%3CBR%20%2F%3Ewhile%20((LPC_SC-%26gt%3BPLL0STAT%20%26amp%3B%20(1%26lt%3B%26lt%3B24))%20!%3D%200x00)%3B%20%2F%2F%E7%AD%89%E5%BE%85%E4%B8%BB%20PLL%20(PLL0)%20%E5%85%B3%E9%97%AD%3CBR%20%2F%3E%2F%2F------------%E7%84%B6%E5%90%8E%E8%BF%9B%E5%85%A5PowerDown%E6%A8%A1%E5%BC%8F----------------------------------%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ECLKPWR_%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3Evoid%20EINT0_IRQHandler(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ENVIC_SystemReset()%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2051038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC17xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC1768%20%E4%BD%BF%E7%94%A8%20GPIO%20IRQ%20%E4%BB%8E%20DeepSleep%20%E5%94%A4%E9%86%92%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E7%BB%88%E4%BA%8E%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E4%BA%86%E3%80%82%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E6%96%AD%E5%BC%80%E8%B0%83%E8%AF%95%E5%99%A8%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%94%B5%E6%BA%90%E5%BE%AA%E7%8E%AF%E3%80%82%E6%88%91%E5%BE%88%E5%9B%B0%E6%83%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%9C%8B%E9%97%A8%E7%8B%97%E5%94%A4%E9%86%92%E5%A4%8D%E4%BD%8D%E6%98%AF%E5%9C%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E7%9A%84%E3%80%82%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8CGPIO%20%E5%94%A4%E9%86%92%E5%B9%B6%E7%BB%A7%E7%BB%AD%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%E7%94%B5%E6%BA%90%E5%BE%AA%E7%8E%AF%E5%90%8E%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%B9%9F%E6%97%A0%E6%B3%95%E4%B8%8E%E8%BF%9E%E6%8E%A5%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%80%E8%B5%B7%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E5%AF%B9%E6%AD%A4%E7%9A%84%E8%A7%A3%E9%87%8A%E5%B9%B6%E4%B8%8D%E6%98%AF%E9%82%A3%E4%B9%88%E6%B8%85%E6%A5%9A%EF%BC%8C%E5%8D%B3%E4%BD%BF%E7%8E%B0%E5%9C%A8%E6%88%91%E8%AF%BB%E5%88%B0%E5%AE%83%E6%97%B6%E4%B9%9F%E6%8F%90%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC1768%20%E4%BD%BF%E7%94%A8%20GPIO%20IRQ%20%E4%BB%8E%20DeepSleep%20%E5%94%A4%E9%86%92%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247325%22%20target%3D%22_blank%22%3E%40laurianussss%3C%2FA%3E%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%3CSPAN%3E%E5%85%88%E5%9C%A8%E4%BD%A0%E9%82%A3%E8%BE%B9%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8BLPCopen%E4%B8%8B%E7%9A%84%E4%BD%8E%E5%8A%9F%E8%80%97%E6%BC%94%E7%A4%BA%E6%80%8E%E4%B9%88%E6%A0%B7%EF%BC%9F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorAlice_Yang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2288889999.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2288889999.jpg%22%20style%3D%22width%3A%20351px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F326395i479336CCB324EB26%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2288889999.jpg%22%20alt%3D%2288889999.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%E2%80%83%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%3CSPAN%3E%E5%AE%83%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E4%BD%9C%E4%B8%BA%E5%94%A4%E9%86%92%E6%BA%90%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%3CSPAN%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
