LPC1768 PCB Design Course
2,113 次查看
farbodjam
I have question about Dutch course to studding how to use Arm LPC1768 inside of our PCB as a stand alone Micro-controller and to easy on board or separate programming them?
If it in English or Nederlands is where ?
And I want to working with this micros inside of my PCB's as central Micro-controllers in the filed of serial communicator or USB with play and plug interface. Also PC interface in each categories that I need, because its all long time that i working with prototyping and development boards as a "Basic Design tester" and "programs tester".
How can I making contact with you or course organizers?
Tanks for reading and answering.
1,895 次查看
xiangjun_rong
Hi, Miri,
I suppose that you have a PCB board based on LPC1768 which is designed by yourself, you want to program it, am I right?
You can go to the link and download the LPCOpen code and LPCXpresso from the link:
LPCOpen Software for LPC17XX|NXP
Hope it can help you
Xiangjun Rong'
