LPC1768 Clock Issue
LPC1768 Clock Issue
2,960 次查看
domneck
Hello engineers,
We trying to debug/program a LPC1768 but there is something wrong and we are out of ideas. We created a project to blink led and when programming the chip with JLINK everything seams to be ok even after verifying. When we start the debug session in LPCXpresso we are getting HARDWARE FALUT.
Board is not getting Clock.
Same we tried with segger software its fine LED is blinking.
--MANZ
标记 (1)
2,746 次查看
kerryzhou
Hi Domneck S,
   I already reply you in your another post, please help to close this post by mark it as answered, because it is the repeat question.
Kerry
2,746 次查看
kerryzhou
Hi Domneck S,
    This question should be the same problem in your another post:
LPC1768 HardFault
    Please check the MCU setting in yoru LPCXpresso, besides, you can try to use the official lpcopen code for LPC1768:
LPCOpen Software for LPC17XX|NXP
   But before you run the lpcopen code, you should check whether your on board external crystal is the same as the lpcopen defined.
Wish it helps you!
If you still have question, please let me know!
Kerry
2,746 次查看
domneck
Hi Kerry,
Thanks for quick reply.
I created project using C project option and CMSISv2p00_LPC17xx  core library i have used.
When i flash with LPCxpresso IDE i facing this issue not with J-Link Debugger V2.14i.
2,747 次查看
kerryzhou
Hi Domneck S,
Kerry
