LPC1758 I2C Problem
LPC1758 I2C Problem
1,592件の閲覧回数
Content originally posted in LPCWare by hoiyin00 on Tue Apr 15 13:37:35 MST 2014
I am trying to write a I2C codes for the LPC1758 as a master to write to and read from ultrasonic sensor srf08 with keil uvision4.
But I m a beginner of programming and first time to use LPC1758, so I want some helps.
If anyone can help me I would really appreciate.
1,532件の閲覧回数
Content originally posted in LPCWare by hoiyin00 on Thu Apr 17 02:34:38 MST 2014
Thanks for answering me
I have use the example of the mcb1700 sample code bundle.
But I still dont understand how the code work.
Would you mind to explain it a bit??
1,532件の閲覧回数
Content originally posted in LPCWare by embd02161991 on Wed Apr 16 16:55:08 MST 2014
You can start from the I2C example in LPCOpen.
visit : http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc17xx-packages
or
http://www.lpcware.com/content/nxpfile/mcb1700-sample-code-bundle-lpc17xx-peripherals-using-keils-md...
NXP Technical Support
