LPC1549, PWM on SCT0_7
1,245件の閲覧回数
jørgenbusch
I'm having trouble getting a PWM signal on PIO1_14 (for SCT0_7)
Maybe it the some clock issue, however I'm not sure. I hope you might have a hint of somekind.
Below is code (as you can see it is using the library from lpc chip. )
Using embOS as operating system.
#define SCT_PWM            LPC_SCT0 /* Use SCT0 for PWM */
#define SCT_PWM_PIN_OUT    7        /* COUT0_7 Generate square wave */
#define SCT_PWM_OUT 0
void Init_and_start_PWM(void)
Chip_SYSCTL_PowerDown(SYSCTL_POWERDOWN_SCTPLL_PD);
Chip_Clock_SetSCTPLLSource(SYSCTL_PLLCLKSRC_MAINOSC);
Chip_Clock_SetupSCTPLL(5,2);
Chip_SYSCTL_PowerUp(SYSCTL_POWERDOWN_SCTPLL_PD);
/* Wait for PLL to lock */
while (!Chip_Clock_IsSCTPLLLocked()) {}
#define SCT_PWM_RATE   200000        /* PWM frequency 200 KHz */
  Chip_SCTPWM_Init(LPC_SCT0);
Chip_SCTPWM_SetRate(LPC_SCT0, SCT_PWM_RATE);
/* Enable SWM clock before altering SWM */
Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_SWM);
  Chip_SWM_EnableFixedPin(SWM_FIXED_SCT0_OUT7);
  Chip_Clock_DisablePeriphClock(SYSCTL_CLOCK_SWM);
Chip_SCTPWM_SetOutPin(LPC_SCT0, SCT_PWM_OUT, SCT_PWM_PIN_OUT);
/* Start with 50% duty cycle */
Chip_SCTPWM_SetDutyCycle(LPC_SCT0, SCT_PWM_OUT, Chip_SCTPWM_PercentageToTicks(LPC_SCT0, 50));
Chip_SCTPWM_Start(LPC_SCT0);
Starting the PWM (just above), I only measure the pin goes high, and there it stays. Breaking the code shows that the counters are running in SCT.
BR Jørgen Busch
ラベル(4)
タグ(4)
919件の閲覧回数
jørgenbusch
The define SCT_PWN_OUT cannot be 0, it must be fx, 1.
Then it runs :-)
