LPC1549 LPCXpresso Board Rev B Schematic
2,499 次查看
Content originally posted in LPCWare by DAMEK on Wed Apr 30 07:36:07 MST 2014
Hey,
i have an rev B board and the assembly pressure layer on the bottom side don't match the schematic on sheet 4 of 4 (drawn / issued on 03/03/2014).
Have someone the right schematic for me?
The reason for my question is that I need 8 following pins (port bits) on a port (parallel lcd).
Thank you for working
greetings
Andreas
4 回复数
2,197 次查看
Content originally posted in LPCWare by DAMEK on Thu May 15 02:11:35 MST 2014
Hey team,
Excuse my long response time...
but the fact is, your Silkscreen correction is correct.
thanks a lot!
and if you could, try to link this file with your lpc15xx download area for other developers.
Closed!
2,197 次查看
Content originally posted in LPCWare by DAMEK on Fri May 02 13:00:50 MST 2014
thank you for that very fast help and reply!
it's true, that on the bottom side stands "LPC1549 Xpresso V2 Rev B".I I was fortunate to got my board on the embbeded world 2014 in Nürnberg - germany.
so thank you very much for this fast and useful answers!!!
i try it on monday and let u now about the problem is solved.
greetings
Andreas
2,197 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed Apr 30 23:27:41 MST 2014
The posted schematic is correct.  The problem is with the silkscreen on the pcb itself which incorrectly identifies the LPC1549 port connected to three Xpresso and one Arduino header pins.
We have now posted a new document showing these mis-identifications on the top and bottom silkscreen, and redlined the correct LPC1549 port. This document can be found, along with the schematic, at:
http://www.lpcware.com/content/nxpfile/lpc1549-lpcxpresso-board-schematic
LPCXpresso Support
2,197 次查看
Content originally posted in LPCWare by mc on Wed Apr 30 11:04:41 MST 2014
Hi Andreas,
Could you please let us know printing on bottom side?
The latest board has following marking
Other old boards were never in mass production.
Where did you get this board?
Let me know details and I can help you.
