LPC1227 Float pins
LPC1227 Float pins
1,502 次查看
Content originally posted in LPCWare by Atieh on Tue Sep 09 18:54:24 MST 2014
Is there any possibility to float all pins at the same time in LPC1227 without reset the microcontroller?
Ati
1,477 次查看
Content originally posted in LPCWare by nxp_apps on Fri Sep 12 14:41:37 MST 2014
Hi Ati,
Your software can configure the GPIO input pins with internal pull-up and internal pull-downs disabled. This will put the pins in tri-state mode.
Hope this helps.
Thanks.
nxp support
