LPC11U68 interrupts for buttons
2,243件の閲覧回数
Guy_mego
Hi All,
I defined my buttons as GPIOs, I want to get an interrupt when button is being pressed.
I can't find how to connect a GPIO to an interrupt.
I work on LPC11U68 board.
Does any one how  should i connect  my button that i will get an interrupt what its state is changed?
released -> pressed -> released.
Thanks in advance.
Guy.
4 返答(返信)
2,185件の閲覧回数
Guy_mego
Thanks a lot for the help.
2,236件の閲覧回数
DanielRuvalcaba
I would recommend you to use the LPCOpen libraries available in this link. You will find several examples to help you with your development.
I hope this helps, Daniel.
2,223件の閲覧回数
Guy_mego
I checked the examples and didn't find a solutions that assist me with my issue.
I also trying to search an answer in the forum but didn't find any.
I know how to work with interrupt but as I said, I don't know to connect a GPIO to an interrupt.
2,190件の閲覧回数
DanielRuvalcaba
I would recommend you to use as a reference any LPCOpen example that implements interrupts to see how an interrupt is enabled.
I also recommend you to take a look to chapter 3, 7, 8 and 9 of the User Manual.
