LPC1115 Flash
LPC1115 Flash
1,617件の閲覧回数
lpcware
Content originally posted in LPCWare by ElecoLPC on Tue Mar 01 07:49:30 MST 2016
I use the LPC1115 for my custom boards, I read the UserManual and I'm very frustrated on Flash Memory Management... I need to save continuously data on Flash and this is impossibile if every time I need to erase the entire sector and re-program the entire sector... I see that on other family uC there's a function called "EEPROM emulated", there's also on this device?
Thanks.
Lorenzo.
2 返答(返信)
1,579件の閲覧回数
lpcware
bump
1,579件の閲覧回数
lpcware
Content originally posted in LPCWare by tha on Fri Apr 08 02:43:35 MST 2016
Unfortunately, that's how the flash is designed.  If you need something like an EEPROM, you may want to look at the 11Exx parts.  Those have actual EEPROM on chip.
