LPC1114 PWM Library
LPC1114 PWM Library
lpcware
Content originally posted in LPCWare by jschimpf255 on Thu Nov 26 17:30:09 MST 2015
I have just put out a LPC1114 Pulse Width Modulation library that uses the LPC board and chip library. The library can use any of the 4 counter/timers on the chip and any of the pins available.
It is available at: PWMLib.
The link contains the code and manual for the library.
--jim schimpf
