LPC 4337 SGPIO. How to set SGPIO resister for 12 bits and external CLK?
1,942件の閲覧回数
robertolucatell
LPC SGPIO
ラベル(2)
1,554件の閲覧回数
Carlos_Mendoza
Hi Roberto,
I would recommend you to take a look to the following application notes on how to use SGPIO:
SGPIO on the LPC4300:
http://www.nxp.com/documents/application_note/AN11275.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
Using SGPIO to emulate an SPI master interface:
http://www.nxp.com/documents/application_note/AN11210.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
LPC4300 camera interface design using SGPIO:
http://www.nxp.com/documents/application_note/AN11196.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
SGPIO camera module design using LPC4300:
http://www.nxp.com/documents/application_note/AN11343.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
Implementing a UART using SGPIO on LPC4300:
http://www.nxp.com/documents/application_note/AN11351.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
Hope it helps!
Carlos Mendoza
Technical Support Engineer
