LCP1114 Start-up behavior
Content originally posted in LPCWare by brattchess on Tue Feb 03 00:16:34 MST 2015
We have a supply voltage that it is take too much time to achieve Vdd.
Is It  not possible modify the valid threshold voltage to put it higher?
Or How can we provoke internally a reset after the Vdd has achieve its value?
I am thinking about to use this MCP111/112 chip but it makes an expensive board which I didn't expect.
Thanks in advance.
Content originally posted in LPCWare by LyraElectronics on Wed Feb 04 10:22:15 MST 2015
You could either use an R-C netwrok to hold the reset line low for longer, or use a DS1818 (or similar).
Mike
