I3C Read board sensor ICM-42688P
2,420 次查看
shashasha
Board settings
Connect the jumper resistor R554 2-3.
I couldn‘t find R554 jumper on LPC5536/LPC55S36 Evaluation Board
.Guess there is a fault in Readme.txt description.
2,395 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
Jumper resistor R554 exists on LPC55S36-EVK schematic revision D. Please download from LPC55S36-EVK Design Files.
Hope it helps you.
Have a nice day!
2,388 次查看
shashasha
Hi Leo
Thanks for your effort to reply to me.
I just followed your link and download the LPC55S36-EVK schematic revision D
I did found the R554 resistor located at left side of R421 on schematic drawing.
But I found the actual EVK doesn't exit R554 beside R421.
By the way , my EVK is NXP LPCXpresso55S36 B.V. version .
My Installed SDK version is 2.14.0(731 2023-07031), Manifest Vesion is 3.13.0.
So help to check if there is a fault. Thank you very much.
2,376 次查看
shashasha
Since there is no R554 for me to short 2-3,I think it is shorted internal
But when i run master_read_sensor_icm42688p demo, it just stopped after Comport Output as below
I3C master read sensor data example.
I3C master do dynamic address assignment to the sensor slave.
So I couldn't readout gyro and accelerator data.
