I2C configuration in LPC845
5,840件の閲覧回数
DHARSAN
        I'm currently working in the LPC 845 microcontroller in I2c. i have tried the calculation for the CLKDIV register with the formula
Baudrate= I2C frequency/(SCLHIGH+SCLLOW)
For example;
100 KHz=30Mhz/(SCLHIGH+SCLLOW)
which gives the (SCLHIGH+SCLLOW)=300 & individual SCL will be 150
when substituting with the SCL= (CLKDIV+1)*(MSTSCLHIGH+2)
where MSTSCLHIGH =1,;
when finding the CLKDIV, which gives the CLKDIV = 49.
I have compared and substituted with the calculation which derived SDK example it does not match up and couldn't get the exact value for CLKDIV when configuring with I2C while debugging for 100KHz the value will be 0x18.
How the calculation will be. Kindly explain it briefly.
With Regards
Dharsan K K
5,800件の閲覧回数
DHARSAN
The DIVVAL of CLKDIV value for 30MHz is 14 has only given for the 400 KHz frequency, when calculating for 100 KHz there is no DIVVAL mentioned then how the calculation will be?
4 返答(返信)
5,806件の閲覧回数
xiangjun_rong
As the following screenshot,
SCL rate = I2C function clock rate / (SCL high time + SCL low time) = I2C function clock rate / ((CLKDIV + 1) * (MSTSCLHIGH + 2+MSTSCLLOW + 2))).
The CLKDIV is the value in I2C->CLKDIV reg
The MSTSCLHIGH is the value in MSTSCLHIGH bits in I2C->MSTTIME reg
The MSTSCLLOW is the value in MSTSCLLOW bits in  I2C->MSTTIME reg
In table 369, The I2C function clock rate is 30mhz
CLKDIV value is 14, MSTSCLHIGH bits is 0, MSTSCLLOW is 1.
SCL rate = I2C function clock rate /((CLKDIV + 1) * (MSTSCLHIGH + 2+MSTSCLLOW + 2)))
=30MHz/((14+1)*(0+2+1+2))=30MHz/(15*5)=400KHz
Hope it can help you
XiangJun Rong
5,796件の閲覧回数
DHARSAN
Also while debugging the SDK example with the configuration of 400KHz(Clock=30MHz), we got the value for the registers
CLKDIV=0x03
MSTTIME=0x77
Kindly resolve or give a solution for the issue.
5,775件の閲覧回数
xiangjun_rong
With the configuration:
case 1:
30mHz I2C clock:
CLKDIV=0x03
MSTTIME=0x77
The I2C baudrate is 30Mhz/((3+1)(7+2+7+2))=416Khz.
case 2:
If you want to get 100KHz I2C baud rate, you can select the parameter:
CLKDIV=15,
MSTTIME=0x77;
The I2C baudrate is 30Mhz/((15+1)(7+2+7+2))=104KHz.
Xiangjun Rong
タグ(1)
5,801件の閲覧回数
DHARSAN
%3CLINGO-SUB%20id%3D%22lingo-sub-1915299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC845%E3%81%AEI2C%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1915299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81I2c%E3%81%AELPC%20845%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CLKDIV%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%88%E7%AE%97%E3%82%92%E6%AC%A1%E3%81%AE%E5%BC%8F%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%3D%20I2C%E5%91%A8%E6%B3%A2%E6%95%B0%2F(SCLHIGH%2BSCLLOW)%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%3B%3C%2FP%3E%3CP%3E100%20KHz%20%3D%2030Mhz%20%2F(SCLHIGH%2BSCLLOW)%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20(SCLHIGH%2BSCLLOW)%3D300%20%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%81%E5%80%8B%E3%80%85%E3%81%AE%20SCL%20%E3%81%AF%20150%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ESCL%3D%20(CLKDIV%2B1)*(MSTSCLHIGH%2B2)%20%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81MSTSCLHIGH%20%3D1%2C%3B%3C%2FP%3E%3CP%3ECLKDIV%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CLKDIV%20%3D%2049%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81100KH%200x18%20z%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%ABI2C%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%ABCLKDIV%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84SDK%E3%81%AE%E4%BE%8B%E3%82%92%E5%B0%8E%E5%87%BA%E3%81%97%E3%81%9F%E8%A8%88%E7%AE%97%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%A8%88%E7%AE%97%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E7%B0%A1%E5%8D%98%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%83%80%E3%83%AB%E3%82%B5%E3%83%B3K.K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC845%E3%81%AEI2C%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B1%E3%83%BC%E3%82%B91%3A%3C%2FP%3E%0A%3CP%3E30mHz%20I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A%3C%2FP%3E%0A%3CP%3ECLKDIV%3D0x03%3C%2FP%3E%0A%3CP%3EMSTTIME%3D0x77%3C%2FP%3E%0A%3CP%3EI2C%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF30Mhz%20%2F((3%20%2B%201)(7%20%2B%202%20%2B%207%20%2B%202))%3D%20416Khz%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%B1%E3%83%BC%E3%82%B92%3A%3C%2FP%3E%0A%3CP%3E100KHz%20I2C%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ECLKDIV%3D15%E3%80%81%3C%2FP%3E%0A%3CP%3EMSTTIME%3D0x77%3B%3C%2FP%3E%0A%3CP%3EI2C%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF30Mhz%20%2F((15%20%2B%201)(7%20%2B%202%20%2B%207%20%2B%202))%3D%20104KHz%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A3%E3%83%B3%E3%82%B8%E3%83%A5%E3%83%B3%E3%83%BB%E3%83%AD%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC845%E3%81%AEI2C%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81400KHz(Clock%3D30MHz)%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%20SDK%20%E3%81%AE%E4%BE%8B%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ECLKDIV%3D0x03%3C%2FP%3E%3CP%3EMSTTIME%3D0x77%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC845%E3%81%AEI2C%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E30MHz%20%E3%81%AE%20CLKDIV%20%E5%80%A4%E3%81%AE%20DIVVAL%20%E3%81%AF%2014%20%E3%81%A7%E3%80%81400%20KHz%20%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%81%AE%E3%81%BF%E4%B8%8E%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81100%20KHz%20%E3%81%A7%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A8%20DIVVAL%20%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E8%A8%88%E7%AE%97%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC845%E3%81%AEI2C%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%3C%2FP%3E%0A%3CP%3ESCL%20%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20I2C%20%E6%A9%9F%E8%83%BD%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%BC%E3%83%88%20%2F%20(SCL%20%E3%83%8F%E3%82%A4%E6%99%82%E9%96%93%20%2B%20SCL%20%E3%83%AD%E3%83%BC%E6%99%82%E9%96%93)%20%3D%20I2C%20%E6%A9%9F%E8%83%BD%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%BC%E3%83%88%20%2F%20((CLKDIV%20%2B%201)%20*%20(MSTSCLHIGH%20%2B%202%2BMSTSCLLOW%20%2B%202)))%3C%2FP%3E%0A%3CP%3ECLKDIV%20%E3%81%AF%20I2C-%26gt%3BCLKDIV%20reg%20%E3%81%AE%E5%80%A4%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3EMSTSCLHIGH%20%E3%81%AF%E3%80%81I2C-%26gt%3BMSTTIME%20reg%20%E3%81%AE%20MSTSCLHIGH%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%80%A4%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3EMSTSCLLOW%20%E3%81%AF%E3%80%81I2C-%26gt%3BMSTTIME%20reg%20%E3%81%AE%20MSTSCLLOW%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%80%A4%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiangjun_rong_1-1721878873790.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiangjun_rong_1-1721878873790.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290233i8C24D7FC6FB5C11A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiangjun_rong_1-1721878873790.png%22%20alt%3D%22xiangjun_rong_1-1721878873790.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%A1%A8369%E3%81%A7%E3%81%AF%E3%80%81I2C%E9%96%A2%E6%95%B0%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF30MHz%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3ECLKDIV%20%E5%80%A4%E3%81%AF%2014%E3%80%81MSTSCLHIGH%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%200%E3%80%81MSTSCLLOW%20%E3%81%AF%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESCL%20%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20I2C%20%E6%A9%9F%E8%83%BD%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%BC%E3%83%88%20%2F((CLKDIV%20%2B%201)%20*%20(MSTSCLHIGH%20%2B%202%2BMSTSCLLOW%20%2B%202)))%3C%2FP%3E%0A%3CP%3E%3D30MHz%2F((14%2B1)*(0%2B2%2B1%2B2))%3D30MHz%2F(15*5)%3D400KHz%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A3%E3%83%B3%E3%82%B8%E3%83%A5%E3%83%B3%E3%83%BB%E3%83%AD%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
