I2C Led Driver to RGB Led
Content originally posted in LPCWare by jhd on Fri Dec 04 17:23:41 MST 2015
Hello!,
This Led Driver PCA9553 is good for this RGB Led?
There is another model that you recommend?
I need some flashing LEDs to notify the user, I need at least white, red, green, blue and yellow. If possible with a high gloss. You think it's okay to use RGB LTRB GFSF or RGBW better?.
Content originally posted in LPCWare by jhd on Sun Dec 06 13:55:10 MST 2015
I changed the RGBA for RGB, this:
http://www.osram-os.com/Graphics/XPic9/00134830_0.pdf
I will use the PCA9633.
Bes regards
