I/O configure
I/O configure
2,727件の閲覧回数
lihai
LPC1788 when using ulink2 debug, all I/O output H level, can I configure to output Low level, and how to configure it.?
タグ(1)
4 返答(返信)
2,608件の閲覧回数
jeremyzhou
Hi Li Hai,
for the opportunity to serve you.
The default configuration of GPIO is persevere, would make them output high level.
TIC
2,608件の閲覧回数
lihai
Thank you, Mr jeremyzhou
Sorry I reply so late, thank you very much for your help. I know how to initial the Pin mode. But when I use keil4 download .hex file to Flash, all I/O output high level. Infact i need low level. so when download .hex file, can output low level?
Have a great day!
2,608件の閲覧回数
jeremyzhou
Hi Li Hai,
Thanks your reply.
I'm afraid that default setting of I/O is impossible to change.
TIC
2,608件の閲覧回数
lihai
Hi jeremyzhou
    Thank you!In that case, I need redesigned my circuit.
Have a great day.
