I²C communication on the LPC810 (without using the ROM API)
1,799 次查看
LPC81x1114
I wish to establish I²C communication with NXP's LM75A temperature sensor using an LPC810 microcontroller for educational purposes, without utilising the ROM API.
I have managed to send I²C commands unilaterally and display text on an LCD, for instance, but I am unsure how to write code for communicating with a slave device like the LM75A, which requires read operations. I have attached my current source code below; at present, I cannot read the temperature from the LM75A.
■ Overview
・I/O ports assigned for I2C functionality
・Communication via polling, without interrupts
■ Main Queries
When wishing to return an ACK signal in master receive mode, it appears the LPC810 lacks such a register (only registers for the three conditions: START, CONTINUE, STOP). Can this be read using the attached code? If possible, I would appreciate a concrete example of source code.
#ifdef __USE_CMSIS
#include "LPC8xx.h"
#endif
#include <cr_section_macros.h>
#include "romI2C.h" //本コードはROMAPIを使用してないので、I2Cの定数定義部分のみ
#include "I2C_DEFINE.h"
#define LM75AAddr (0x48) //温度センサ アドレス
#define I2C_RW_W (0x00) //RW(LSB)はLCDは常に0
#define LM75TempRegi_pointer (0x00) //Tempレジスタポイタ
//Command:RS=0,Data:RS=1
#define LM75ConfRegi_pointer (0x01) //Configuration registerポインタ
int waiting=0;
void SwitchMatrix_Init();
void IOCON_Init();
void I2C_Init();
//void I2C_one_Byte_Write(uint8_t data);
void I2C_Multiple_Write(uint8_t Addr,uint8_t WriteByte,uint8_t *i2c_data);
void Systick_Init();
void I2C_Addr_WSend(uint8_t Addr);
void I2C_Addr_RSend(uint8_t Addr);
void Temp_SenceInit();
uint8_t I2C_Multiple_Read(uint8_t Addr,uint8_t ReadByte);
uint16_t ReadTemperture_LM75A(uint8_t Addr);
void mon_CFG(); //I2Cデータモニタ用関数
//void I2C_Stop();
//Systick
void SysTick_Handler(){
waiting=0;
static void wait_ms(uint32_t ms){
waiting=1;
SysTick_Config(SystemCoreClock/1000*ms);
while(waiting);
int main(void) {
int LED_C;
uint16_t temp=0;
LPC_GPIO_PORT->DIR0 |=(1<<1);
SystemCoreClockUpdate();
// Enter an infinite loop, just incrementing a counter
IOCON_Init();
while(1){
temp=ReadTemperture_LM75A(LM75AAddr);
return 0 ;
}//main
void I2C_Init(){
LPC_SYSCON->PRESETCTRL &= ~(0x1<<6); //Assert Reset
LPC_SYSCON->PRESETCTRL |= (0x1<<6); //Clear Resett
//Set i2c clock DIV
LPC_I2C->DIV = 0x0001; //PCLK I2C Clock
LPC_I2C->MSTTIME=0; //Mater SCL Low Timee
LPC_I2C->CFG = I2C_CFG_MSTEN | 0x04; //マスターモード モニタイネーブル クロックストレッチ
void Temp_SenceInit(){ //温度センサ初期設定
uint8_t Config[3]={LM75AAddr,LM75ConfRegi_pointer,0x00}; //
I2C_Multiple_Write(LM75AAddr, 3, Config);
void I2C_Addr_WSend(uint8_t Addr){
while(!(LPC_I2C->STAT & I2C_STAT_MSTPENDING));
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_IDLE);
LPC_I2C->MSTDAT = (Addr<<1|0); // address and 0 for RWn bit
LPC_I2C->MSTCTL = I2C_MSTCTL_MSTSTART; // send start
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_TX);
void I2C_Addr_RSend(uint8_t Addr){
LPC_I2C->MSTDAT = (Addr<<1)|1; // address and 0 for RWn bit
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_RX);
void I2C_Multiple_Write(uint8_t Addr,uint8_t WriteByte,uint8_t *i2c_data){
//LPC_I2C->CFG = I2C_CFG_MSTEN; //マスターモード
I2C_Addr_WSend(Addr);
for (int i = 1; i < WriteByte; ++i){
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_IDLE);//
LPC_I2C->MSTDAT = *(i2c_data+i); // send data
wait_ms(100); //wait
LPC_I2C->MSTCTL = I2C_MSTCTL_MSTCONTINUE; // continue transaction
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_TX); //break(); //abort();
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_IDLE); //break();*/
LPC_I2C->MSTCTL = I2C_MSTCTL_MSTSTOP; //
//if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_IDLE);
//温度センサからの温度データ読みだし
uint16_t ReadTemperture_LM75A(uint8_t Addr){ //
uint8_t Readdata_MSB;
uint8_t Readdata_LSB;
uint16_t Readdata;
//I2C_Addr_RSend(Addr); //read
I2C_Addr_WSend(Addr); //write
LPC_I2C->MSTDAT = LM75TempRegi_pointer;
//LPC_I2C->MSTCTL = I2C_MSTCTL_MSTSTART; //RE-START
LPC_I2C->MSTDAT = (Addr<<1)|1; //読みだし
LPC_I2C->MSTCTL = I2C_MSTCTL_MSTSTART; //RE=START
Readdata_MSB=LPC_I2C->MSTDAT;
Readdata_LSB=LPC_I2C->MSTDAT;
LPC_I2C->MSTCTL = I2C_MSTCTL_MSTSTOP; // send stop NACKのスレーブへの送信
if((LPC_I2C->STAT & I2C_STAT_MSTSTATE) != I2C_STAT_MSTST_IDLE) ;
Readdata=Readdata_MSB<<8|Readdata_LSB;
return Readdata;
/* Enable SWM clock */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<7|1<<5); //Enable SWM Clock,I2C Clock
LPC_SWM->PINASSIGN7 = 0x00ffffffUL; //SDA
/* I2C0_SCL */
LPC_SWM->PINASSIGN8 = 0xffffff04UL; //SCL
LPC_SWM->PINENABLE0 = 0xffffffb3UL;
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<18); //Enables clock for IOCON block.
void IOCON_Init() {
/* Enable UART clock */
void Systick_Init(){
SysTick->CTRL=0; //Systick_Countter stop
SysTick->LOAD=12000; //1ms
SysTick->VAL=0; //
SysTick->CTRL=0x07; //Systick
void mon_CFG(){
uint32_t mondata;
mondata=LPC_I2C->MONRXDAT;
1,716 次查看
LPC81x1114
Habib_MS,
Thank you for your message.
I wrote a program using Chapter 29.2 “Code Example I2C” as a reference, but it isn't working properly.
Currently, I cannot visualize how the LPC810 operates when controlling as a master using hardware I2C.
I believe the code example lists three constants to set in LPC_I2C->MSTCTL: I2C_MSTCTL_MSTSTART, I2C_MSTCTL_MSTCONTINUE, and I2C_MSTCTL_MSTSTOP.
I2C_MSTCTL_MSTSTART handles the start condition and restart condition, and also...
I2C_MSTCTL_MSTSTOP is for the stop condition,
but could you please explain how I2C_MSTCTL_MSTCONTINUE behaves in both master transmit mode and master receive mode?
Translated with DeepL.com (free version)
1,697 次查看
Habib_MS
Hello @LPC81x1114,
Of course.
The macro I2C_MSTCTL_MSTCONTINUE is defined with a value of 1, as shown in Chapter 29.2.1 "Definitions". It is used in the MSTCTL register, which writes a 1 to the MSTCONTINUE bit. This bit performs the following function:
In simplified terms, this bit tells the LPC controller that it can proceed with the next operation in the I2C protocol. For example, if a transmission has already started and an ACK has been received, the next step might be to send a data byte to the slave. This is when the MSTCONTINUE bit is activated.
That is why, in the example "Master writes one byte to slave", the bit is set after receiving an ACK and before sending the data byte.
Habib
1,737 次查看
Habib_MS
Hello @LPC81x1114,
I highly recommend reviewing Section 7.10: "Protocols for Writing and Reading the Registers" in the LM75A datasheet. This section explains how the I2C communication frames should be structured to perform various actions with the sensor. For example, it includes the frame format required to write to the configuration register:
Additionally, there are other useful frame formats mentioned that can help you better understand the communication process. This section also highlights key aspects of I2C communication.
I also suggest checking out Section 7.3: "Slave Address", which explains how to configure the sensor's slave address.
On another note, the RM provides several example codes that directly access I2C registers without using the ROM API. These examples can serve as a helpful reference and are located in the chapter 29.2 called "Code Examples I2C".
Hope this helps.
Habib
%3CLINGO-SUB%20id%3D%22lingo-sub-2178553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20LPC810%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%20I%C2%B2C%20%E9%80%9A%E4%BF%A1%EF%BC%88%E6%97%A0%E9%9C%80%E4%BD%BF%E7%94%A8%20ROM%20API%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%87%BA%E4%BA%8E%E6%95%99%E5%AD%A6%E7%9B%AE%E7%9A%84%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8%20LPC810%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%20LM75A%20%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%BB%BA%E7%AB%8B%20I%C2%B2C%20%E9%80%9A%E4%BF%A1%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BD%BF%E7%94%A8%20ROM%20API%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%88%91%E8%AE%BE%E6%B3%95%E5%8D%95%E6%96%B9%E9%9D%A2%E5%8F%91%E9%80%81%20I%C2%B2C%20%E5%91%BD%E4%BB%A4%E5%B9%B6%E5%9C%A8%E6%B6%B2%E6%99%B6%E5%B1%8F%E4%B8%8A%E6%98%BE%E7%A4%BA%E6%96%87%E6%9C%AC%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%A6%82%E4%BD%95%E7%BC%96%E5%86%99%E7%94%A8%E4%BA%8E%E4%B8%8E%20LM75A%20%E7%AD%89%E9%9C%80%E8%A6%81%E8%AF%BB%E5%8F%96%E6%93%8D%E4%BD%9C%E7%9A%84%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%E9%80%9A%E4%BF%A1%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E4%B8%8B%E9%9D%A2%E9%99%84%E4%B8%8A%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9B%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%BB%8E%20LM75A%20%E8%AF%BB%E5%8F%96%E6%B8%A9%E5%BA%A6%E3%80%82%3CBR%20%2F%3E%E2%96%A0%20%E6%A6%82%E8%BF%B0%3CBR%20%2F%3E%E3%83%BB%E4%B8%BA%20I2C%20%E5%8A%9F%E8%83%BD%E5%88%86%E9%85%8D%E7%9A%84%20I%2FO%20%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%E3%83%BB%E9%80%9A%E8%BF%87%E8%BD%AE%E8%AF%A2%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%EF%BC%8C%E6%97%A0%E4%B8%AD%E6%96%AD%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9F%A5%E8%AF%A2%3CBR%20%2F%3E%E5%BD%93%E5%B8%8C%E6%9C%9B%E5%9C%A8%E4%B8%BB%E7%AB%99%E6%8E%A5%E6%94%B6%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%94%E5%9B%9E%20ACK%20%E4%BF%A1%E5%8F%B7%E6%97%B6%EF%BC%8CLPC810%20%E4%BC%BC%E4%B9%8E%E7%BC%BA%E5%B0%91%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E5%8F%AA%E6%9C%89%E4%B8%89%E4%B8%AA%E6%9D%A1%E4%BB%B6%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9ASTART%EF%BC%88%E5%BC%80%E5%A7%8B%EF%BC%89%E3%80%81CONTINUE%EF%BC%88%E7%BB%A7%E7%BB%AD%EF%BC%89%E3%80%81STOP%EF%BC%88%E5%81%9C%E6%AD%A2%EF%BC%89%EF%BC%89%E3%80%82%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%E6%89%80%E9%99%84%E4%BB%A3%E7%A0%81%E8%AF%BB%E5%8F%96%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E6%8F%90%E4%BE%9B%E6%BA%90%E4%BB%A3%E7%A0%81%E7%9A%84%E5%85%B7%E4%BD%93%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23ifdef%3C%2FSPAN%3E%3CSPAN%3E__USE_CMSIS%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22LPC8xx.h%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%3CCR_SECTION_MACROS.H%3E%3C%2FCR_SECTION_MACROS.H%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22romI2C.h%22%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%9C%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFromapi%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81i2c%E3%81%AE%E5%AE%9A%E6%95%B0%E5%AE%9A%E7%BE%A9%E9%83%A8%E5%88%86%E3%81%AE%E3%81%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23include%3C%2FSPAN%3E%20%3CSPAN%3E%22I2C_DEFINE.h%22%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ELM75AAddr%3C%2FSPAN%3E%3CSPAN%3E(0x48)%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EI2C_RW_W%3C%2FSPAN%3E%3CSPAN%3E(0x00)%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2Frw%EF%BC%88lsb%EF%BC%89%E3%81%AFlcd%E3%81%AF%E5%B8%B8%E3%81%AB0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ELM75TempRegi_pointer%3C%2FSPAN%3E%3CSPAN%3E(0x00)%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3CSPAN%3E%E6%B8%A9%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%E6%B8%A9%E5%BA%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2FCommand%3ARS%3D0%2CData%3ARS%3D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ELM75ConfRegi_pointer%3C%2FSPAN%3E%3CSPAN%3E(0x01)%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3CSPAN%3E%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eint%3C%2FSPAN%3E%3CSPAN%3E%E7%AD%89%E5%BE%85%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESwitchMatrix_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EIOCON_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2Fvoid%20I2C_one_Byte_Write(uint8_t%20data)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Multiple_Write%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Ei2c_data%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESystick_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Addr_WSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Addr_RSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ETemp_SenceInit%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3EI2C_Multiple_Read%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint16_t%20%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E5%85%89%E5%9C%88_LM75A%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A9%BA%E7%99%BD%3C%2FSPAN%3E%20%3CSPAN%3Emon_CFG%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FI2C%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%8B%E3%82%BF%E7%94%A8%E9%96%A2%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Fvoid%20I2C_Stop()%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3CSPAN%3ESystick%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESysTick_Handler%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%AD%89%E5%BE%85%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Ewait_ms%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%20%3C%2FSPAN%3E%3CSPAN%3Ems%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%AD%89%E5%BE%85%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESysTick_Config%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E7%B3%BB%E7%BB%9F%E6%A0%B8%E5%BF%83%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E1000%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E7%AD%89%E5%BE%85%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Emain%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3ELED_C%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint16_t%20%3C%2FSPAN%3E%3CSPAN%3E%E6%B8%A9%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_GPIO_PORT%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EDIR0%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%B3%BB%E7%BB%9F%E6%A0%B8%E5%BF%83%E6%97%B6%E9%92%9F%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2F%20%E8%BF%9B%E5%85%A5%E4%B8%80%E4%B8%AA%E6%97%A0%E9%99%90%E5%BE%AA%E7%8E%AF%EF%BC%8C%E5%8F%AA%E6%98%AF%E9%80%92%E5%A2%9E%E4%B8%80%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIOCON_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESwitchMatrix_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B8%A9%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E5%85%89%E5%9C%88_LM75A%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELM75AAddr%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3E%2F%2Fmain%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Init%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_SYSCON%3C%2FSPAN%3E%3CSPAN%3E%20-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%20PRES%20ETCTRL%3C%2FSPAN%3E%3CSPAN%3E%20%26amp%3B%20%3D%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E~(%3C%2FSPAN%3E%3CSPAN%3E%200x1%3C%2FSPAN%3E%3CSPAN%3E%20%26lt%3B%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%206)%3B%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%96%AD%E8%A8%80%E9%87%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_SYSCON%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EPRESETCTRL%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E6%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E6%B8%85%E9%99%A4%20%3C%2FSPAN%3E%3CSPAN%3E%E9%87%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2F%E8%AE%BE%E7%BD%AE%20i2c%20%E6%97%B6%E9%92%9F%20DIV%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%88%86%E9%A2%91%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x0001%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FPCLK%20I2C%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTTIME%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E4%B8%BB%20SCL%20%E4%BD%8E%E7%94%B5%E5%B9%B3%20%3C%2FSPAN%3E%3CSPAN%3E%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ECFG%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3EI2C_CFG_MSTEN%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3E0x04%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%20%E3%83%A2%E3%83%8B%E3%82%BF%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%88%E3%83%AC%E3%83%83%E3%83%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ETemp_SenceInit%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E5%88%9D%E6%9C%9F%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3CSPAN%3ELM75AAddr%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3ELM75ConfRegi_pointer%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3E0x00%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EI2C_Multiple_Write%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELM75AAddr%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Addr_WSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_idle%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%9C%B0%E5%9D%80%EF%BC%8CRWn%20%E4%BD%8D%E4%B8%BA%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mststart%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%8F%91%E9%80%81%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_tx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Addr_RSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_idle%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%9C%B0%E5%9D%80%EF%BC%8CRWn%20%E4%BD%8D%E4%B8%BA%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mststart%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%8F%91%E9%80%81%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_rx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EI2C_Multiple_Write%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3Ei2c_data%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Flpc_i2c-%26gt%3Bcfg%20%3D%20i2c_cfg_msten%3B%20%2F%2F%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI2C_Addr_WSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%E5%86%99%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_idle%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ei2c_data%3C%2FSPAN%3E%3CSPAN%3E%2B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewait_ms%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E7%AD%89%E5%BE%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mstcontinue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E7%BB%A7%E7%BB%AD%E4%BA%A4%E6%98%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_tx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2Fbreak()%3B%20%2F%2Fabort()%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_idle%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2Fbreak()%3B*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3D%20i2c_mstctl_mststop%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Fif((LPC_I2C-%26gt%3BSTAT%26amp%3B%20I2C_STAT_MSTSTATE)%20!%3D%20I2C_STAT_MSTST_IDLE)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2F%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8B%E3%82%89%E3%81%AE%E6%B8%A9%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%E8%AA%AD%E3%81%BF%E3%81%A0%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint16_t%20%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E5%85%89%E5%9C%88_LM75A%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%7B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_MSB%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint8_t%20%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_LSB%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint16_t%20%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2FI2C_Addr_RSend(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3B%20%2F%2Fread%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI2C_Addr_WSend%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E5%86%99%E5%85%A5%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3ELM75TempRegi_pointer%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Flpc_i2c-%26gt%3Bmstctl%20%3D%20i2c_mstctl_mststart%3B%20%2F%2Fre-start%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mstcontinue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_tx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%E8%AA%AD%E3%81%BF%E3%81%A0%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mststart%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FRE%3DSTART%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_MSB%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_mstctl_mstcontinue%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_LSB%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTDAT%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_rx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3EMSTCTL%20%3D%20i2c_mstctl_mststop%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%8F%91%E9%80%81%E5%81%9C%E6%AD%A2%20NACK%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%B8%E3%81%AE%E9%80%81%E4%BF%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstpending%3C%2FSPAN%3E%3CSPAN%3E))%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESTAT%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mststate%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%3CSPAN%3Ei2c_stat_mstst_idle%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_MSB%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE_LSB%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3E%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESwitchMatrix_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%20SWM%20%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_SYSCON%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESYSAHBCLKCTRL%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%90%AF%E7%94%A8%20SWM%20%E6%97%B6%E9%92%9F%E3%80%81I2C%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ELPC_SWM%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EPINASSIGN7%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x00ffffff%3C%2FSPAN%3E%3CSPAN%3EUL%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FSDA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20I2C0_SCL%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_SWM%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EPINASSIGN8%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0xffffff04%3C%2FSPAN%3E%3CSPAN%3EUL%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FSCL%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ELPC_SWM%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EPINENABLE0%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0xffffffb3%3C%2FSPAN%3E%3CSPAN%3EUL%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ELPC_SYSCON%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESYSAHBCLKCTRL%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E18%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%90%AF%E7%94%A8%20IOCON%20%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EIOCON_Init%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%20UART%20%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELPC_SYSCON%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ESYSAHBCLKCTRL%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E18%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESystick_Init%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESysTick%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ECTRL%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2FSystick_Countter%20%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESysTick%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E12000%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F1ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESysTick%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EVAL%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESysTick%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ECTRL%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E0x07%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%3C%2FSPAN%3E%3CSPAN%3E%E7%B2%98%E8%B4%B4%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E7%A9%BA%E7%99%BD%3C%2FSPAN%3E%20%3CSPAN%3Emon_CFG%3C%2FSPAN%3E%3CSPAN%3E()%7B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Euint32_t%20%3C%2FSPAN%3E%3CSPAN%3Emondata%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emondata%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3ELPC_I2C%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMONRXDAT%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I%C2%B2C%20communication%20on%20the%20LPC810%20(without%20using%20the%20ROM%20API)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255410%22%20target%3D%22_blank%22%3E%40LPC81x1114%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%E5%BD%93%E7%84%B6%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E7%AC%AC%2029.2.1%22%E5%AE%9A%E4%B9%89%22%20%E7%AB%A0%E6%89%80%E7%A4%BA%EF%BC%8C%E5%AE%8F%20I2C_MSTCTL_MSTCONTINUE%20%E7%9A%84%E5%AE%9A%E4%B9%89%E5%80%BC%E4%B8%BA%201%E3%80%82%E5%AE%83%E7%94%A8%E4%BA%8E%20MSTCTL%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%B0%86%201%20%E5%86%99%E5%85%A5%20MSTCONTINUE%20%E4%BD%8D%E3%80%82%E8%AF%A5%E4%BD%8D%E5%85%B7%E6%9C%89%E4%BB%A5%E4%B8%8B%E5%8A%9F%E8%83%BD%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Habib_MS_0-1759962768950.png%22%20style%3D%22width%3A%20608px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Habib_MS_0-1759962768950.png%22%20style%3D%22width%3A%20608px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359955i7D178BFFEBE6E15D%2Fimage-dimensions%2F608x256%3Fv%3Dv2%22%20width%3D%22608%22%20height%3D%22256%22%20role%3D%22button%22%20title%3D%22Habib_MS_0-1759962768950.png%22%20alt%3D%22Habib_MS_0-1759962768950.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHabib_MS_0-1759962768950.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%AE%80%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%8C%E8%AF%A5%E4%BD%8D%E5%91%8A%E8%AF%89%20LPC%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%20I2C%20%E5%8D%8F%E8%AE%AE%E4%B8%AD%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E6%93%8D%E4%BD%9C%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BC%A0%E8%BE%93%E5%B7%B2%E7%BB%8F%E5%BC%80%E5%A7%8B%E5%B9%B6%E4%B8%94%E5%B7%B2%E7%BB%8F%E6%94%B6%E5%88%B0%20ACK%EF%BC%8C%E5%88%99%E4%B8%8B%E4%B8%80%E6%AD%A5%E5%8F%AF%E8%83%BD%E6%98%AF%E5%90%91%E4%BB%8E%E6%9C%BA%E5%8F%91%E9%80%81%E4%B8%80%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%E3%80%82%E6%AD%A4%E6%97%B6%20MSTCONTINUE%20%E4%BD%8D%E8%A2%AB%E6%BF%80%E6%B4%BB%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%8C%E5%9C%A8%E7%A4%BA%E4%BE%8B%20%22%20Master%20%E5%90%91%E4%BB%8E%E7%AB%99%20%22%20%E5%86%99%E5%85%A5%E4%B8%80%E4%B8%AA%E5%AD%97%E8%8A%82%EF%BC%8C%E8%AF%A5%E4%BD%8D%E6%98%AF%E5%9C%A8%E6%8E%A5%E6%94%B6%20ACK%20%E4%B9%8B%E5%90%8E%E5%92%8C%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%E4%B9%8B%E5%89%8D%E8%AE%BE%E7%BD%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Habib_MS_1-1759962808651.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Habib_MS_1-1759962808651.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359956iF27ECAD62A382E6B%2Fimage-dimensions%2F569x343%3Fv%3Dv2%22%20width%3D%22569%22%20height%3D%22343%22%20role%3D%22button%22%20title%3D%22Habib_MS_1-1759962808651.png%22%20alt%3D%22Habib_MS_1-1759962808651.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHabib_MS_1-1759962808651.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I%C2%B2C%20communication%20on%20the%20LPC810%20(without%20using%20the%20ROM%20API)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%93%88%E6%AF%94%E5%8D%9C_MS%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%95%99%E8%A8%80%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%AC%AC%2029.2%20%E7%AB%A0%20%E2%80%9C%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%20I2C%E2%80%9D%20%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%E7%BC%96%E5%86%99%E4%BA%86%E4%B8%80%E4%B8%AA%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%AE%83%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%83%B3%E8%B1%A1%20LPC810%20%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%20I2C%20%E4%BD%9C%E4%B8%BA%E4%B8%BB%E7%AB%99%E8%BF%9B%E8%A1%8C%E6%8E%A7%E5%88%B6%E6%97%B6%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E5%88%97%E5%87%BA%E4%BA%86%E8%A6%81%E5%9C%A8%20LPC_I2C-%26gt%3BMSTCTL%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%E4%B8%89%E4%B8%AA%E5%B8%B8%E9%87%8F%EF%BC%9AI2C_MSTCTL_MSTSTART%E3%80%81I2C_MSTCTL_MSTCONTINUE%20%E5%92%8C%20I2C_MSTCTL_MSTSTOP%E3%80%82%3CBR%20%2F%3EI2C_MSTCTL_MSTSTART%20%E7%94%A8%E4%BA%8E%E5%A4%84%E7%90%86%E5%90%AF%E5%8A%A8%E6%9D%A1%E4%BB%B6%E5%92%8C%E9%87%8D%E5%90%AF%E6%9D%A1%E4%BB%B6%EF%BC%8C%E5%8F%A6%E5%A4%96......%3CBR%20%2F%3EI2C_MSTCTL_MSTSTOP%20%E7%94%A8%E4%BA%8E%E5%A4%84%E7%90%86%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%EF%BC%8C%3CBR%20%2F%3E%E4%BD%86%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%20I2C_MSTCTL_MSTCONTINUE%20%E5%9C%A8%E4%B8%BB%E7%AB%99%E5%8F%91%E9%80%81%E6%A8%A1%E5%BC%8F%E5%92%8C%E4%B8%BB%E7%AB%99%E6%8E%A5%E6%94%B6%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%B7%B2%E4%BD%BF%E7%94%A8%20DeepL.com%20%E7%BF%BB%E8%AF%91%EF%BC%88%E5%85%8D%E8%B4%B9%E7%89%88%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I%C2%B2C%20communication%20on%20the%20LPC810%20(without%20using%20the%20ROM%20API)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255410%22%20target%3D%22_blank%22%3E%40LPC81x1114%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fi3c-ic-digital-temp-sensors%2Fdigital-temperature-sensor-and-thermal-watchdog%3ALM75A%23documentation%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELM75A%20%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%3C%2FA%3E%E4%B8%AD%E7%9A%84%E7%AC%AC%207.10%20%E8%8A%82%EF%BC%9A%22%E5%86%99%E5%85%A5%E5%92%8C%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%8D%8F%E8%AE%AE%22%20%E3%80%82%E6%9C%AC%E8%8A%82%E5%B0%86%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E6%9E%84%E5%BB%BA%20I2C%20%E9%80%9A%E4%BF%A1%E5%B8%A7%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AF%B9%E4%BC%A0%E6%84%9F%E5%99%A8%E6%89%A7%E8%A1%8C%E5%90%84%E7%A7%8D%E6%93%8D%E4%BD%9C%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%AE%83%E5%8C%85%E6%8B%AC%E5%86%99%E5%85%A5%E9%85%8D%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%E6%89%80%E9%9C%80%E7%9A%84%E5%B8%A7%E6%A0%BC%E5%BC%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Habib_MS_1-1759787216901.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Habib_MS_1-1759787216901.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359662i544E44D66E98979C%2Fimage-dimensions%2F590x233%3Fv%3Dv2%22%20width%3D%22590%22%20height%3D%22233%22%20role%3D%22button%22%20title%3D%22Habib_MS_1-1759787216901.png%22%20alt%3D%22Habib_MS_1-1759787216901.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHabib_MS_1-1759787216901.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%BF%98%E6%8F%90%E5%88%B0%E4%BA%86%E5%85%B6%E4%BB%96%E4%B8%80%E4%BA%9B%E6%9C%89%E7%94%A8%E7%9A%84%E6%A1%86%E6%9E%B6%E6%A0%BC%E5%BC%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E4%BD%A0%E6%9B%B4%E5%A5%BD%E5%9C%B0%E7%90%86%E8%A7%A3%E4%BA%A4%E6%B5%81%E8%BF%87%E7%A8%8B%E3%80%82%E6%9C%AC%E8%8A%82%E8%BF%98%E9%87%8D%E7%82%B9%E4%BB%8B%E7%BB%8D%E4%BA%86%20I2C%20%E9%80%9A%E4%BF%A1%E7%9A%84%E4%B8%BB%E8%A6%81%E6%96%B9%E9%9D%A2%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E5%BB%BA%E8%AE%AE%E6%9F%A5%E7%9C%8B%E7%AC%AC%207.3%20%E8%8A%82%EF%BC%9A%22%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%22%20%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%E3%80%82%3CBR%20%2F%3E%E5%8F%A6%E5%A4%96%EF%BC%8CRM%20%E6%8F%90%E4%BE%9B%E4%BA%86%E5%87%A0%E4%B8%AA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E8%AE%BF%E9%97%AE%20I2C%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E4%BD%BF%E7%94%A8%20ROM%20API%E3%80%82%E8%BF%99%E4%BA%9B%E7%A4%BA%E4%BE%8B%E5%8F%AF%E4%BB%A5%E4%BD%9C%E4%B8%BA%E6%9C%89%E7%94%A8%E7%9A%84%E5%8F%82%E8%80%83%EF%BC%8C%E4%BD%8D%E4%BA%8E%E5%90%8D%E4%B8%BA%20%22%20%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%20I2C%20%22%20%E7%9A%84%E7%AC%AC%2029.2%20%E7%AB%A0%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3CBR%20%2F%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E
