How to use S25FL016K SPI Flash with DMA in lpc4357?
1,136 次查看
jigar2
I'm using Embedded artist LPC4357 board.I want to configure Spansion s25fl016k SPI Flash with spifi controller using DMA to transer large data.Tried lpcspifilib but can't find relevent.
Has somebody tried SPIFI with DMA if yes please suggest any solution.
Is there any other method for using the same?
标记 (3)
985 次查看
Carlos_Mendoza
Hi Jigar,
Please take a look to the below community thread, I think it might be helpful for you:
DMA to/from SPIFI
Hope it helps!
Carlos Mendoza
Technical Support Engineer
