How to store data on internal flash memory
2,237 次查看
Content originally posted in LPCWare by mackrants on Tue Jun 16 04:33:35 MST 2015
I'm using lpc2387 and because of security reasons I want to store some data on the flash memory.
I'm aware that some of it is used for running the code, but I want to use the part of the flash that isn't used.
I searched a lot but didn't find enough info about how to do this.
I need ALL of the libraries that I'm required to use and a full example of how to read and write data to the flash.
thanks a lot!!
Asaf
6 回复数
2,197 次查看
Content originally posted in LPCWare by TheFallGuy on Wed Jun 17 05:17:15 MST 2015
There is no header file  - you do not need it.
There is no library - you do not need it.
The User Manual tells you what you need to do.
2,197 次查看
Content originally posted in LPCWare by mackrants on Wed Jun 17 05:06:25 MST 2015
I don't have the necessary libraries and I don't know which libraries I should have,
Where can I find the header files for this?
lpc23xx.h isn't enough
2,197 次查看
Content originally posted in LPCWare by mackrants on Wed Jun 17 05:06:20 MST 2015
2,197 次查看
Content originally posted in LPCWare by TheFallGuy on Wed Jun 17 02:42:22 MST 2015
Did you READ THE USER MANUAL? It shows you how.
UM10211, Chapter 29, section 8.
2,197 次查看
Content originally posted in LPCWare by mackrants on Wed Jun 17 02:22:36 MST 2015
I got the Flash Mem address range, but I don't know how to write there on run-time.
I didn't figure out how to do that with C code...
Can you please show me an example?
2,197 次查看
Content originally posted in LPCWare by TheFallGuy on Tue Jun 16 05:32:18 MST 2015
Read the User Manual. The section on IAP should provide everything you need.
