How to start debugging apps in LP4357?
4,542 次查看
Content originally posted in LPCWare by jgorsk on Thu Aug 30 01:58:23 MST 2012
I'm trying to use Keil 4.54 (eval) to debug programs in the LPC4357
using only the internal flash and ram memories.
The program loads and the PC is pointing to 0x10403e00 address
instead of a location in the internal flash memory.
The program will not jump or run to main function
but when the PC is altered manually to point to any
funtion in my program, debugging will work (except
for the ISRs).
Is dubbuging in flash based LPC43 parts supported by the current version of Keil?
13 回复数
4,439 次查看
Content originally posted in LPCWare by rgledhill on Sat May 11 02:23:53 MST 2013
We are developing and debugging just fine on a Hitex LPC4357 dev kit, using Keil 4.71a (also works fine with earlier versions).  Make sure you're downloading the code to flash before debugging (I notice the box to do this isn't ticked in the screenshots above).
There is a bug in the USART0 CMSIS driver from NXP whereby it doesn't clear and initialise the FIFOs correctly on start-up.  Corrected version attached.
I've also attached a demo project for the LPC4357 which uses the RTX library; you could remove references to RTX though and it will then just build as an app (note the LED will only work on the Keil LPC4357 kit).  Tested on Hitex LPC4357 board but should still build and run on other 4357 kits.
Don't use the Keil simulator for LPC43xx - NXP haven't provided the necessary framework for the simulator so it would be difficult to get useful results out.
If you've bought the Keil software drop their support a line - even if you're evaluating it, they will be happy to help.
Cheers
Richard
Hitex UK Ltd
4,439 次查看
Content originally posted in LPCWare by jgorsk on Fri Apr 26 00:48:42 MST 2013
As far as I know Keil simulator isn't supporting the LPC43xx. You need the actual hardware, then you can run your program in debug mode. If that's what you're asking about. The LPC43xx chips are supporting debugging mode.
4,439 次查看
Content originally posted in LPCWare by sivareddydevireddy on Wed Apr 24 23:05:56 MST 2013
i am also trying to simulte the same blinky example program but when i enter into simulation pc is pointed to 0x0 location it is not going to main routine.
did you ever try that example in simulation mode? right now i dont have hardware board so i am trying to check the code in simulation mode  will it support simulation mode?
i heard from someone else that this microcontroller doesnt support simulation mode.how far is it true?
please try to help me uot from this issue it really very urgent to me.
thanks inadvance
4,439 次查看
Content originally posted in LPCWare by jgorsk on Wed Sep 19 02:06:49 MST 2012
wellsk, thank you very much for your reply. It really helped. The problem was in the initialization file.
I am able to debug now. There are still other problems but that may be just my bad understanding
of how some of the peripherials work. I need to spend some time on troubleshooting.
bavarian, thanks for your help too. My program started to work in debug mode but it didn't work
in normal mode untill I followed your recommendation and added this line $K\ARM\BIN\ELFDWT.EXE !L BASEADDRESS(0x1A000000)
in the User tab.
There might be some issues with your example. Have you tried using running it? It doesn't work for me.
1. Target CPU is 4350 not 4357 and that's why 'Stop after bootloader' seems not to be relevant
2. Program does not jump to main function. It jumps into the middle of 'SetClock' function.
3. When you run the example on your board, what's the state of pin P2.7? It's high on my board.
4,439 次查看
Content originally posted in LPCWare by bavarian on Tue Sep 18 02:33:45 MST 2012
I don't see any problems or strange effects when working with the LPC4357.
Let's make a quick crosscheck:
- You link your application to 0x1A000000 (internal flash, bank A)
- You add the required flash header to the file with the user program command "$K\ARM\BIN\ELFDWT.EXE !L BASEADDRESS(0x1A000000)" (in the User tab).
  This header need to be there for internal flash
- Set up the flash programming settings: Click “Settings” in the “Utilities” tab. Add the LPC18xx/43xx IAP 512kB Flash driver to the “Programming Algorithm” box.
  Then set the “RAM for Algorithm” box to a larger size, 0x8000 will be fine. Click OK to save.
- You program the file to the internal flash. Either do it manually from the Flash menu or you check the box "Download to flash" in Debug --> Settings.
  Then it's done when you start the debugger
- You start the debugger (the INI script contains a LOAD instruction, so in the debug tab you could uncheck "Load application at startup".
  Alternatively you keep it checked and un-comment the LOAD line in the script file)
If you did not check "Run to main" the debugger will come up with the PC set to the Reset_Handler. This is after the bootloader. As far as I know the setting "Stop after bootloader" is not relevant for the LPC4357 environment).
I attached my test example, an extended example from the folder .\Keil_4.54\ARM\Boards\Keil\MCB4300. It's the original Blinky example, I just added the internal flash as target.
Hope it helps
4,439 次查看
Content originally posted in LPCWare by jgorsk on Mon Sep 17 14:56:09 MST 2012
Thank you so much wellsk for your reply.
I can't verify my setting now but I'll do that asap.
I think the basic settings are the same, the initialization
file may be different though.
Will debugging still work on your board if 'Stop after bootloader'
option is selected?
4,439 次查看
Content originally posted in LPCWare by wellsk on Mon Sep 17 13:31:00 MST 2012
I'm using the v4.54 version of Keil UV4 with the Keil MCB 4357 board with internal FLASH. So far, I've seen no issues similar to that.
The only thing I can think of is that the debugger configuration is incorrect. See my settings below (especially VECTRESET).
<img src="data:image/png;base64,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" border="0" alt="" />
The initialization file contains:
FUNC void Setup (unsigned int region) {
  region &amp;= 0xFF000000;
  _WDWORD(0x40043100, region);                // Set the shadow pointer
  _WDWORD(0xE000ED08, 0);                    // Set the vector table offset to 0
  SP = _RDWORD(0);                     // Setup Stack Pointer
  PC = _RDWORD(4);                 // Setup Program Counter
LOAD %L INCREMENTAL
Setup(0x1A000000); // Get ready to execute image in Flash bank A
<img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAn0AAAGVCAIAAAAE7tDoAAAgAElEQVR4nOy9Z5gj933nWS9vb++e57zr863vzmvLtizZsmU/D8+UZhWoM002ZzjDoFkNLWt199zRGq0le70WNaEn9fRMh5lO6ISMRs5o5JxzzjmjgEJGI6ObFDXSc/eiAHT3RNKy1r6A5/P0U10ooIpAT33+39//V0VgHc++u4b54M6D7/3d9b/+m//8G7/7B//2d7/wm5/9w9/6vT/6rc/90Wc+98Xf/vwf//bvn+RP/svyx5+M/xcfwD/tMXzCXf/yPoH/R+z9n/wAfkl7/8f6cH7BY5685PNTvviZz3/xM5//4vGafy5fxP/P/+f5/B9/5vNf/Mzn/ui3fu+PfvP3/vDffvYLv/G7f/DOe//b/3757/7z7P2bi1tkOhu4u4b5uxsLf/W3V3/jd37/dz//h7tY4uDo4+HRx8MPfzr88Kejj346+ujRlMMnGP0CHH706PAnjw5/8rMnOYL5+OdHH8M//+k5/MlJfnb61xN8/PPDxzd+HqNPxM9GP/nZ6KOfDV/EAObDnw0+fDT48FEf5mjKT3tTDk/RfTEfdw4/7o4+7ow+7oxOLXRHH3dGz3xh5xdkNOXjp/HTp/Dp9/L8//anHcypHZ3e/tEvgecc9i9jd7/ogT3xyRxv/wRPec+nf/4n/gbaE6Z/BsfvdnRM7xQ/O+bDU/Q/LUc/O/439eGjZ202gPnoU/DCf+DDj35+zE9+PvykJ5Cfjz7xGenpJ7Sn8U9+Tn4qj3728+/MvPqzfx6P78y8+tNHP9vFEn/nc3/4P//273/rP/zVDz64tYXEAB/cfvBXf3vtV/+H/wmFJ4H1nj1e0fhLhlDZHKlaYg1bouVIt52ZjivbcWc77lzXneu6cx13dowr03Zl2s5025luu9JtV6YzJvs0Mh1XtjvFneu6s113rufJ97z5vrcw8IIDLzj0FUf+4shfHAWKh4Hiob94GCgeBkqjQHEUmD5VOgyWDoPQ0SchBH34GMEXEYApHQVKR/7Ska946CseesHRhKEXHHnBQ1/x0Fs88k3wnsZTPPI88SuMGzzGdQJn4RhH4ciRP3LkD+25Q1t2ZM0MLemBOT0wp/um1JSBKTUwpYem9NCYGhqSA0Oir08OdIm+Nt7TxLrqaEcZacvDbXnwQBZoSQMtib8h8jdEvobIVxd46nx3je+u8t3V/SmuKm+Ks8JxVjiOMtteZtkhlq3EtBYZliLTWmTaiixbiW2HWHaIba+wHVW28xjWdNlRO0F1zHiD2nOps511lqPGtFcZtgrdWqZZIZoVolkgmqVEs0B0a5lhqzDsVeYJWPYqy1FjOWHqJ6ixHE8weZbtasBw3M1TwOtPHAbDVmbYKgxbhWGvMMf7On4529VgT17L9bQ+MQdc79PheFpsd5PtarBcdZazxnTUGI4q01FlOmssV53tbnDcTY6nyYHf5xlv8kugNTkw+KiqDHuFbivTrRDNCtFtZYa9wnBUmc4aE/4WXCdw1lnwl+tqcJ74wNmu5qkP09VguxosZ53pqDHsFbq1TLOUqOYixQhSjHmKsUA1F+lWiGGvsBxVlrPGcTd53oMp+74Dvq8t8HeE/o4w0BUGu8JgVxTsikI9GHG4Jwn3JZG+JDKQPhtZZCCL9KXhvjTUkwS74mBHHOhIAm1xoC0JtKXBjjTck0X68uhAER0oogNlbDhFFR+q4kNVYqhKDNWn0SSGmuRQkxxqkyPdlNRIfwIDTHpkPIEpM8acORyTPbRkDy3ZQ+uU3KHtBPb8oT1/6MgfOvKHzvyhM380pnDkOo27cOrs5AFPnbgeO8V5S0e+p/DhFD8M9EwCn5zyKYLPoHv06NuvfaMZDIBiASQRlKWCslRQlQrqUkFdym9J+QdSfkfK70n5fSm/L+UNpbyRlHf4DEYnnh1JeUMpbyjl9aW8vpTflfI7Uv6BlN+S8utSfl0qqErh3fFLYn5BxG/4fd/+8280ex96M81ya4jEkf7Vr/36t/7DX929vwz81d9c/Y3f+X00nhTK1eWurNpb0AVKxnDZGqvZEg1H6sCVbXtyHW+2682dINv1ZDuebMedbbuybVfmwJU5cGXarmzbnW1PrezJdY/JniDXg/Hmet5cz5fv+wt9f6HvBweB4iBYHIZKo1BpFCyNgqVRqDQKlYah0jBYHAaLg0BxECgOQsVhCBqFy4dPEpoQLh+GK0fhylG48mG48mGk8hFM+MV8GC6PCZWPgtBhoDTyF4f+4tAHDn3gYIp/Mg7wF0d+cOQHRz5w5CuOfMVDH3gI29pXOjxpZd/T3OwpHnnAx2R86CwcOuF/KrmRPTuwZQfWdN+a7ptTvRP0LZm+OQ0zgGVsTPUNyb4+0dPFu9pYRxNtq8IHylBLHmrJgk2JvynxN4S+htBTF3qqAm+N76nB3uW5HofjrLDtZbYNYlkhprVIM4M0U55mKtDNBYalwLCADEuRaS2xbGWWvcx2VNiOChPGXmHBOKosR5XlqLAdFfZ4ucpyVFlOmNOuPS1ppqM6kS5EhU+4JnAK1VykWUp0a5luK9NtZbq1TLeWGTD2MsNeYdirMEx7lWGvwNaEN2ba4eOED6Y2te9TpAurxV6l28o0S4lmKdIsJZqlRLeOxc90VB93/Fjhx+/2D/PusXRPuI02cdt4v676sew9rU8L1/sPsHWL42lx3E2Wq850VBm2Mt1aolqKFFOBYsyTjXmKqUAxF6mWEnycYw3bKwx7hW6v0K0Vhq18atTirLNdx2OXsZuPB0+1iXQhmqVEMYFkQ4GkzxF1GaIuQzbkqSaQbi0xbGWmvcJ21jmuBtfThOG5mzxPi+dp7XsPBL4Dga8t8LeF/rYw2BYGO7CDxaGeONyHebp9wxPjhnriYEfkPxD6WzACX1Pkb4n9B5JgRxbqycJ9eaQvjw6UsVPqVcaGyvixgJ9jX+1z7Js+Zd+pek/a1/KYfR9Tb27s3RP2PXymegvPVO8ns+8T6n22fT+FeqEXq7d79OjSn32j7vWCfA7I55T4HIjPKQtYVQGrLmA1BayWkHUgZHWFrP6E4bMZCFmD08u9yat6QtaBkNUSspoCVl3AqgpYZQEL4nNKfHZhn13YZ9fc7kt/9o1m70NDuKILlKLgARK79z9+5nPf/8HfAhf+/Xc+94U/LtS6cmdK6c5pfaAhBFmiFXu87kg13ZkDb77jL3T9+W6g0IPxF7r+QseX7/hybW/uwJs98GZaY7IH3mzbm2t78x1fvuPLd32Fp+A/RS9Q6AXAfrDYDxYHodIwDA3D0ChSHkXKowg0jEDDcAlmECr2Q2A/VOyHS4MINIyUR5HK4XjL8igCjcIniJQPI5XDaOUoWvkwWv0wWv0wNiFaeSaRMUdjykeh8ihYGgWLQz84CICTIUKhHygOAsVhsDQMlkaB0jBQHPqLQz84hA3tL44CpWk0P/KPOfSVjk08pnTkK538Oz70gode8NBTOHQXRq7CyJUfOnMDR7Zvz/Rt6Z411bWmupZUx5LqWlM9W6ZvS/dtmb413bdm+pZ035Lum1N9U7JnSnYNia4u3tHGDtSRljLcVASbskBD4quLvVWRpyrwVvmeKt9d5TkrPGeZ56xwJ0xiLpxxS3RLkWYqUIw5ij5D1qcphizNmKMZpw4uMq0lhg1i2CCGFWJYSwxriWGFGFaIYYMYtjLTVmbYy0x7mekoM6dudpyUX5Vlr7LtcD6usuD8CsvGWqaaSxQTSDbmyYY8WZ8j6bNkfY5szE/tSzUXj61sLtLMRZoFmlCCObnNWJywAByVqX0nqXcStpzjPAdLl2ICycYCxQhSTCDVBFLNRbplfMaHhwhM+zQKjwP31CgnNfwET/Ofp8XxtGDpMuADsEJUy/j4qZYS3QYx4P0eZ8pp5n4CV4MFK226mbvBdjcnwn6ms5+I0fD6JtvVYDqqdBtEtRQpxjxZnyVq0wR1kqBO7GlSRF2GpM+SDTmyIQ8HU4qpQDEVyMYx1PFXUJ5WDpiTYdbkYzyuK0wHXrB0ifocQZvGq5N4dZKoy5ANucm7QczxOO/UMI7jrHFcdY6rznM3eO4mzL63yfcd8P0HwkBbGOyIgl1RqCsK9cTTEDymJwn1JKGeJNgVBTpC/4HA1+R7G3xPfd9T33fX+J66wNcU+9vSYFcW7snDfXlkoIgMFI9597R6n4y/sH21L8y+6adn3yeD71Pta3+2fT+tej2nvestPi/4vlC9/+Dg+1TvfusbX607nVkWrcCigSxaiUWDOLQyh1bj0Opcap1LbXGpB1xqh0vt8ah9HrXPowyfQZ9HGUyWBzxKj0fp8ahdHrXLpba51AMuFX7DGodW5tAgDq3EooEsaoFJzTCpNYf9W9/46tS7Km+h1Oh95rN/cO78W8BnP/8FFJ5sDhUUrrTal9cHiuZI2RavuZINT+bAl+sEwG6o2AuD/XCxHyn1I8V+qNgNFTrBQieQbwfyB/5sy59t+rJNf7blzx34cweBfDtQ6AQLnWChC/8MTZiumRIq9kJgL1TshUv9SGkQgQYRaBCFhtHyaMIwCg1gIlA/UupHSv0INIhBg3hlFK+MYuVhFBpGofFrp0TLw1jlMF45ilePElNqT6N6lKgexSfExhxGq4fRymEEGkWgYRgahEqDULEfLPaDYC8I9kPFQbg0CEPDMDQMlQbB4iBY7AfAfgAch/JAaRiCRiFoFIZGIegwCB0GS4fB0ihQGgVKhwHoMAAdThaO4Jp2oHTkLx36S4f+SVnbUxh6CgNPfuDO9Z3ZriPTgbGn2/ZMx57pOjJdR7YPY8/07Jm+LdOzZXrWVM8Mqzfe0UcPtNGWOtRUBOsyX03qq4o9FaG7InCX+a7yvhPiOstcO8RxlDgOiG2H2DaIbYNYNohlLTEsRboZpJkKFEOWpEsTNQmiJkHSJkm6NEWfpRpyVGOeZirQTCAM1VSgmgpUY4FqKlBNIM0MUs0gzQLSrEW6tUS3wUCMKXaIYS8zbRWmDY7IxydfWGOTlJMj6bJEXYaoTe9pUnuaFEmXIeuzZEOebMyTDTmyPkfSZUm67PiMPz7F58e2NuRI+ixRl9nTZoi6DMmQIxsL08QMC2yi3vok5tZZjhrTUZ0eA0mfJ+qzJH2OpM+TDfmJP4p0K8SwQnAgg+0+LreekMrJAMeaVNFPK3kcQI+1N8mUY+ubQYoxT9JnSfosxZg/3ss4TVbHJWhHlemonabKcFSnoXNcBIafmjj78equ+1SGng4LYOly3A2Ws8awlalmkGLIEbVpgjqBVUTR0hBKGkLLwhh5BKuI4ZRxvCqOVyUI6gRBnSSok7As8ZrUni5D1OfIhjzFBFJNRfiLGDMeHhXHn+RkzAQPekj63J4ug1cnccoYThkjqJNEbZqsz1GMBaoJpJpBuqVEt0B0S2mMuciwlJiWEtMKMa0Qy15mOcpsR4XjrHCcNZ6rvu9p7PuafF9L4G8LAm1hoCMMdmATi+FAHOyIgx1RoC3wHfC9zX1Pjeeu8lzw8LTMc1X4nrrQ3xIHOtJQTwpH3shAER0qokPFae/CPKfyrE3A6n1x9v2EZecn7fsc9T7dvidrzk+o13NSvaUXlJ3/y9Scu0ePLn7tTNlqTVPwWQo+S8XnqXiQii/R8GUavkzD12j4Og3fpOEPaPgDGq5Lw/Un7F69cfHSZZjdqzceW7Nz9UaPhuvQcAc03AEN36ThGzR8bfK2JRoepOLzVHyWisuScSkyDrKYL37tzNS7ai9oi0JbKPwX//hPgF//zc/WDoYKZ1rtyegCBVOoZI1Vncm6N9305dvBQjdS6kWhQQz2XHkQgwbRUi9S6obBTrjQDuVbwVwrkGsGco1ArhnItYK5VqhwECq0w2BnQjdSHBMGO5Hj9Z0I2IkUu5FiL1qC6cegXgzqx6FBojKcMIiXB/HyIA71Y6UeTBzqJyontin341AvBo2fjU62iZeHicooUR0lqofJ2mGydvQsErWjRPUwUT1MVEaJyig+IVaBxT+MQoNoqR8t9cKlXrjYC5d6kVI/WupHoUG0NAiX+uFiLwz2QmA3BHbhkQScy+GwHoFG4ePg/hijEGzo0ihYGk6BM3QAHPrAgTff8+Z6nlx3Mq3eccET6tmOK9eD58hduZ4r13Nlu85M15Hp2tNdW7pjTbbN8ZYh1tRFGppQXRmoyL1lqQcSuUoCZ4nvAHl2kGsrcmwg2wYyrUWmFWSaQYa5SLcU6Wa4sFygGnMUQ4akS+9pEgRVDK+IElTxPXWCpE2RdWmyLkPWZyn6LEWXJeuzJF2GpE2TtBmSNkPUZYm6LFGfJRmyZEOOYsxTTFMKVHOBaipQzSANDo4WiGmdpJxJ1qHbylRzkWzMk3TZPU2aoEkR1Am8Oo5Xxwnq5J4mRdKlSboMUZMiqJN4dQKvjhPUCYImtadNwxA0KYImiVcncao4VhnDKKI4ZRyvTu5p00R9Fj710yylqcDG4dVRZcKKspVpVgiW7p4uQ9Cm93TpPV0GFjDZkKcYQaoZpJpBirFANuSJ+ixxLP5xHJ/YHYJL03RbmWErT1PySdnD6p3CdjdZzhrDXqFZIYq5CEt3T5va06Zg9VLMINVSpE6NBc9/P87EW+ZJid4MUid14GkpmG47YWV7dazkaRHbc8K77nHYpVlLFGOepE0RVHGsPIwSB3YE3i2+e5vv2RF4d4S+XaF/VwQTOAlSEkLLIhhlHKdKETTpPW0azsckfZaog8dGaaIuQ9RniYY8yVAgG0GSoUAy5En6/J4ui9ekcKo4Rh7ByCM4ZYygThC1aZIuMx5y6XPwGIukz5K0GZJuDFmfIeszFEOWYshRDTmauUC3gExriWWD2I4yx1Xhuus8T4Pnaex7m/ve5r63xfe1BL6W0NcS+loCb3Pf3eC5ahxnhe2AOA6IbS+xbSWOA+K5qwJfQxRoS0JdabgnC/dlU+9O7Ks44d1TAj5tX01iqPnHs6/lMfvmHrfvSQEfT/o+WXY+OQX2z0e9zwi+3aNH7575U8hoSOB2kridJG4ng9vJ4nfy+B0Qv1PC75TxO2X8Tg2/XcdvN/HbB/jtA/xWG7/Vxm9dvHT5/5o8Ll66vP3BtcfWtPFbB/jtJn67jt+u4bfhtyrhd0D8Th6/k8XvZHA7Sdx2Ersdx26XDLp3z/wvE+9Cai+o9GQrrcGv/+ZngV//zc/2Rx8pXWmtL2sIgpZI2ZGoedKNQLYVLHQixV683E9UBsnKMFUdpqrDZGWQKPfiUDdW7ETBg0ihFc43QtlGMFsPZRuhXCOcb4bzrUjhIAIeRIvtaLHzQmLFTqzUiZW68VIvDvXiUC9R7icrgydJlHsJqJco95KVQaoySFeH6dowWRkkK/0k1EtA3TjUjZc68WInVuqcfB/44FPVUap2guoxyeooWRk+scdhsjJMlAeJ8iBe7sehfhzqw3aPlnrTIUIc6kdLvWixOx5PFDphsBMudsJgN1zsRUr9SGkQhQaR0iAC67nYCxf74WI/XILFPIjAZXNoGIaG8JpQcRygg2A/APb8hZ6v0PXlOt5cx5vteLJtGG+u48t3ffmer9DzFnqeXMeTHbe2OdNtR/rAnmyZ4w1jtK4LV9UBSOkrSd2g2FEQOHJ8e45ny3EsObY5yzRnmaYs3ZShGbJUY4ZqzFIMWYohSzZkyYYMWZ8maVN7mgReGcHKwlhZCCePEJSxPXV8T53Y0ySJ6iRRnSSqknuqBEEZxylip1DG8SpYh0mCJgWbA5YiET4t6nNkAxyOS3QrxJhO01rLdNh541CVxKvjOFUMq4hiFRGcMjZ+2/HKCFoenoStKFYZxyrjWEUUI49gZGG0NISSBFHiwK7Yj5QE0bIwVhHDq5ME2L6wIycCgx1Js0KTsAWSDJMzvjqB1yTxmhQs4Kl9yfocUZfBa5I4ZRynjOFUcfxU/7oMUQdvliMb4KA87gma+p4J2/f0HC3b3WA6a3RbmWopUUwFkj67p03j1Qm8OrGnTZH0GYoxRzHmH+NkxJ8YKEPUpfe0KYImSdAk97RpovbUIVGMhUkpeDpxDifpKtMBN3BND6zJdjfYrjrTUaGaQbI+u6dOwNLd5rsRHPs6y3qSNZZ1jWldY1rWmJY1pnWNaV1j2dbZ9k2ea0vg3REHkZIwShrByKNYRQyriGHkMYw8ipZF0LIIVhHDq5J4TZqgyxB0mT1ddk+XJWjTOHUSq4ihZWG0NISRR3CKKF4VJ6gSBFWCoE7uqZMEVQKniOHkUYwsjJGFMdIwWhqCl3HyCE4ewStiBGV8T5Mg6lIUfYZqytHMBYZ13CfItpc5jgrHWeE6q1xnleeq8Vw1nqvOdVbZjjLcWsi0FhnWItMCsmxFrrPM99ZF/gNJsCsNjb0rjw7lJ9X7fPueFvCT9p1Wnp/acvXUed9p8H08++YOrSe8+4R6P4F9i7+QfX/Z073do0dvvfTFgloZXF8ObyxHNpZjG8txxFISsZRBLOU2lwqbS+DmErS5CG0uVjcXa5uL9c2FxuZCY3Nh6z/9/WOiPbm89Z/+vr65UNtcrG4uwi8HN5cKiKUcYimDWEwiluKIpdj6Unh9KbS+FFhbzCnlF176YrP3oSFchb2rcGf7hx+NvTsYfaR2Z/T+gjlcsscq7mTdn22G8geRYjcO9VPVQbo2zNRG2fooUx9lasN0tZ8q95KlTrx4EANb0XwjkquHc7VIrh7J1SP5RiTfiBSa0UIrBrZi4EGseBCHKR3Eiwdx8CAOHpxaP362nSh1EqVOAuokoW6y3EtVeulKP10dTOinK/10pZeu9DLVQaY2zNaH2dowUx1kqv10uZcqd5JQJ1lqJ8Z0klA39ZT3eZxUZZCq9JPlfrLcO0E/+aT+y/1kuZ8o9xInNjs9EJkAHkTAdgTsRIvdWKkXK3WjxW70dNwfU+xFir1IqRcp9SOwlSe5OQjCZflO4CT5jj/f9ufa/lzbX+gECt0A2AsWeoFCx5/veHNtb/bAkzlwp1vOVNOerFtjVWOkrAuU1D5Q4c5JHFmBNb1vTnJNCbYxwdQnGPoETRunaONkTZykjpHUsT11jKCOE9Rxgiaxp0kQ1Am8Ko5TRLCyEFoSQEsCGFkIK4/gVVG8MjZGEcPLo1hZGCMJokUBlNCPHGcd367IjxT7UeIAShJES4NoSQgtCWGkIYwsjJVH8co4XpUkaNJEHVz7LdEtk2hohWdVC0R9bk+TwqsSOGUMq4hg5JGJXyM4RQSriGBkYZQkuCv274r8SHEAKQmipCGUNISUBJFi/67ItyP0bgs8W3z35r5ri+/eEfmQkiBaHsEq43h1kjCeksyRDDmSIUee2stYIBsLJEN+Tw/HrAROGcep4jh1Aq9OEjRJgja1p03DVsMpYxhZCCn27wp9Jw8DLQtPvBLHKeM4ZQKnSuLVqT1thmTITSZry0x7le1snJxtZbsbTEcNTvwUY56kyxA00/rqWL0kfZaky5wsvxOm0V8VxyljOEUUezzyCCEloZOHhFPCo6IEXjUuBRM0qT1thqQ/PjCGozpVL9znxXbVGfYK1Vwg6dJ4VQwjDe0KvZtcxxrTskIzPqTqH1B0yxTtEkmzSFIvEFX395RjiKoFonqRrH1ANa4wLesc+wbPhdh3b/E920LvttC7JfBs8T2bfPeWwLMj9CMlIbQ8ilUmcKokTpMiaNPTsIuSBlGSAHr8VxQZIwtjpCG0OLgr9O3wPVs85ybXucl1IDh2BNeB4No3ec4tnnN737XDdyOFPpQ4gJGG8MoIQR0napJkfYpiyFCNGaopSzPl6OY8w1JgWItMW4llg5jjZn6Qbgbp5gLdVKCb8gwryHZA+56awH8gCXYkoZ70hHenHNs3PlQ8od4n7av5xNn3OQ3Px2XnJ7Lvs1LvC8rOn1K9z+m3+uVN93aPHp3/ky9k5VLv8rx/eT64PB9eno88nIs+nEs+nEuvzGVX5rKrc+DqHLg6B63OlVfnyqtz1dW56upcbXVu82/+7qRup9JF/M3fVVfnKqtz5dU5aPLy7OpcdmUuvTKXejgXfTgXeTgXXp4PLs/7l+56lu5mZOLzf/KFZu9D49O9e/iR1ps1BkFrFHImqt50I5hrRcB2DOoly/1MbZitj3KNUa4xytVH2fowU+2ny90U1EkUD+KFZqxQj+Zq4Vw1nKvBRHK1SK4Wzdej+Xq00IgVmmPA5vHyScAxcbCVKLYSxYNEsZ0otZNQJ13upivddKWfqU6o9DKVfrY2yNUHufowXx/laoNsrZ+pdNPlTqrcSZbayeJBoniQKLWTpXYSmvyEOkmok4I6Yz1PKXWSpfbY1sV2ongQLx7A2k5A3WQZpp+u9FNjxsZNwT8rvWS5myh1YsV2tNCK5JvhY1rhfCtSaMEmDhda4XwzlGuGco1QrhnKNUP5ZijfCuVb4UI7DLbDhXYIJn8QzB8E8weBMe1Avh3Mt4OF9mRavX1iZScEdkKFTiDf9ufavmzLm2l50k1Xqu5M1GyxiiVcMgRBrTencqWl9qTIEt83RDj6MFMbomtCVFWQogqSFAGCPICX+XESP0bix0gCGGkALQ2iZUGMLIyVh7HyMEYWQksCKLEfJfajpUGMLIRTRHCKCE4exsrCWGkIIwmghL5dvmeb59rkOhAcxwbbvs6yrbOs62zbBse+wXEgOHYEx47g2hFcxxbPuS3w7Ij8SEkII4/iVUmiLksxglRziQbP0h17N4PXpPDKOFYZxcgjaGkIJQ2ipSG0LISRhdDSEFIc2BH5YLNuw0VOkX9X5N8WeLb57k2eE8F1bHDtGxwbfCSb+65toXdXHEBJQ2hZBKOIYpUxnCqOUyXw6gRencRrkgQ41GqzBF0Gli5WEcPCWx7bFyaOU0bRksCOwI3g2tfZlnW2dZ1tW+fYNjh2BNexyXPBLtkWendEvh3x2Cg4VZKgzZAMeaq5SLeVWY4a29Vgu8YTq2w33Ls0rrQTdRmCOoFTRrGKKF4F10KdFYUAACAASURBVFdTRG1qT5OEFQuHe/Qk3CPFgV2hf0fg3eZ7NvddCK5zg+PY4DgQXOcmz7XF92zzvdsC747AN6kJB5DiIFISQsvCOGWcoE2TDHmKuUizlRmOGtvdnIZdlrPGsJcppgJJm8Iro2hJcIfvRrBtK3TjMkW7RFItEBT3cNK7GPEcWnQbKbi1y7+5u39rl38LKbiNEt7BSObxigWieomif0AzPqSbVhjmVaZllWVZYZpXGKYVunGFYV7j2BH77m2RHykNo+VRrDKOU6dw6iRWGYOHWfBgDi0JoCVBtCSAEgemut1g21YZZngE8ICsXSZplsmaJZJmmaJdpmgf0nQrdMMa07TBtiA49u19567QgxR5MRI/VhbCycM4RRSvjBFUcaImQdJl4CkSqjFPO0WOZsrRzQW2HeK5agJfSxToiINdabgPX1Mkjz7NvrEJz1Lvi+z7zOz7/OD75KTvs2vOL+h2fq59/8nV2zl6dO6Ln89IRO57N733bvrv3QzeuxlamA0vzMYXZpOLs+nF2czSbGFptrA0W1qahZZmoaXZygkQP/jbi5cu9yePi5cuI37wt/BT8MalycszS7Ppxdnk4mx8YTa8MBtamA3eu+mbv+mZv+Gav5ESCc598fNT72q8oPIx7+p9OXOoaIuVXcmaL9MM5Q9ixU6i3EtplgH48Rbf1RjlG6N8Y5iDJQd1kqVWojj2bjRbjWYrkUwlkqmEM5VwphLJVCLZaiRbjeaq0Vwtlq/F8vVYvhY9TWzCeFk2DwDADDEaB5vJYitZaqegTjrAPQsAwF1rptLLVHvZai8X2j8HPPZ4Bx/opKFOqnSQLLYmNBNgMwE2E8WTtJJFWPDNRLEZB5vxQjNeaMQKjVi+Hs3XY/l6rNCMgy1YwEmokyp305WejfbOyf2dpaZSlW6q0k1B3WSpHS+2YoVm1MV4HQBe34uEc40x+UY43wjnGqFsPZipBdJVf7riT1f96ao/XQuka4FMPZhtBHONYK4RzDYC2UYgU2fdmO6Gqck1g7lWMH8wsTLMQWi8phMqdEKFdjB/EMi1fJmmN93wpGrORMURhazhoilQ0HkzKmdSZouJzGG+IcjW+JgqL1XhocjcJKmLIHZhRU60wInk23f37VtjHFv7zm2+Z1foQ4oDKEkAJQ4gRX6kyLcr8qEkAbQkiJWFsfIwRhrCSAJosR8p8G7zXJts+wbTsko3rlAND8i6ZZJmiaheIqqWSKolknqZpF4ma5bJmmWydpmqX2GY19h2xL5rR+RHyyJ4VZKkz1NMxbF64UtHjHnipJUGq4igZWGUNIiUBFAT4ES7LfBs7rvgOLst8GwLvPAaBNe+wbausyxrLMsay7LKtKyxrRtcB6zeHZF/VwwTQEpggihpECULoeWwj+NYZQKjjGMUMXhOcaLeGE4F58UoThHBSIM7AvcGx7pC0y+Ttctk7RJZu0TSLpG1S2TdMlX/gGZYoRtXGKYVpmWVbd3gOreE3l1JCKOI4zVpkiFPNZcY9irLWWe7muxT3oUoZpBsyBF1abw6gVVEsfIIThnFq+LjUoQyhoXHIuLgrsi/I/Bu8T2bPBeC41hn29aYllWG6SHN+ICqX6LolijaZYr+AdXwkG5aoZtX6OZVBoxljWldZ9vXOY7NffeuKIiRRwkaWL0lur3CcsH9z6e8S9Sm8IooWhLY5rs32NYVmmGJrF4gKOaxkjmU8NbO/o1t7uwm+9oG8+o649oG6xqCfX2TM7u9fwspvIORzhMU9/dUC3vqRaJ6iaQ5mY8XSeplmnGVZdvgubaE/t3JMGVaZEZK4L9GP1LkR4n8yIlxERz7OtP8kKJfIqrv42TzGMldjHgOLZ5Di+6ghHNo0RxafBcjmcdK7+Pli0TVA6p2haZfZRjWmSYEx7rJtW/xHNv7zh2+c1foQUkCGFl4XGDQpIi6NGk8SZylGrJUQ5ZuKrBspRPePY68ssjgH2DfJ+d9n2ffT3y50ZNlZ2v20PZE8H1W2fkx9br+kYLvL6Pm3Dl69JV//S/diFX+G18TnP2a6OzXJGe/pjj7Vc2bX9W/+RXTm2cs58/YL5xxXzjjvXDGf+FM6MKZ8GmWL37z4qXLjcnj4qXLyxe/OX02dOGM/8IZ74Uz7gtn7BfOWM6fMb15Rv/mV9RvflVx9quSN74mfOOr/De+uv/6V53rD//dv/6Xx971nfbu8PAnen/OEi7aYxV3subPNsOFg1ixY6G+AwDATf0o1xi5GO8CwDeJ0VGhMczX+lk4XEKtZLEZL9RjeVi65UimHE6rrwDAFTEUTkOhNBRKlyOZciRbiWYr0Ww1MnFzJFOJZB8nmq1EpXMAAADAXX6hHi80EsVWCjqwUd8BAACYs2SrPZh8vV9oDAvNkfweANyz5+v9XLWXrXQz5U4aOkgVW0mwmQAbcbARL9TjhXoMZuz+k9Ri+Wo0V41ODyNTiWQDqHPADDESA5vx4sGxd6nvAOd5tkovXemNhwJzVjj6J0sHcbAVKzTHVfdsPZSphTLVKcF0JZAqB1JlXxLyJSBfAhovJCF/quxPTU1c8aUqatx5AJhjpaq+dFWNv/AjSSOQbQbzcMNaJzSNxfIFAFjgFtphsB0qHATzLX+26Us3PKmaO1lxxiBbGDQHcnpvWu2My60RsSnI1/u4ag9D7qRI7SSxjSCy4AQWNN+M4pp3uKZNthHB1K8xdGt0/SrdsEI3rrEsCK5ji+/eEXi3Bd5toXdH6N0VeJEiP1oSxEhDcMxFin27Qu/2vnuTbV9nmFeo+mWSepGgvI+TzWNEd9GiObRwDiW8gxLcQQlvo4R3UKI7aNFdrHRhT7VMMawwrRs8144ogFHE93RZsgmkmoo0c4lugWiWEvkJ78LV4ym7It+O0LPFdyN4TgTPsclzwvbd2nchuI51tnWNaV5lmFYZphWGaYVhXmVZ1jk2BM8x3ozv2tx3be47N/edsLk3+a4tgWdb5NsVB5DSMEoWRskiaFkYJTueP4aNi1VEsPIwVhZCiX2bXPsq3bBEVN3Dy+Zx0rtYyRxGfAcjnsOI57CSeaz0Hk52n6BYIKqWyNoHNOMq277J9+yKQxhFgqDNkI0g3VZhOessZ2MaLpmOKt068a4W9m4EIw9PIm8cr4rD0kWK/NsCzybPtcGxr7GsqwzTQ5phmaJbImsWiKr7e4p5vPwuVnoXK53Hye7h5fcJyuPy755yYU+5SFIvkrVLFP1DunmD69oRBTGK+J42SzaCNGuZ6axPi8xP5t2T3r1PkM9jxHeQ/JsT6V5Zo/14lXZljX5lnXl1g3V9k3NjB1av5C5Odhcnm8fJ7+Hk8zjZPFZ6FyOZw4jv4mQLJM0DummV40Dse7ZFAZQsglUmcKoEVhFFy8JIcWBX5EOKfEihDyn07vLdW1wHgmVbZ5hXqLolouo+VnoHKbi1zbuxxb2xyZ3dZF9HsK4j2LOb7BtbnBvb3NtI/hxadBcjuY+XLhDkS0TlMkn1gKxeoWpX6YY1hnGdZd7k2Lf5bqTIj5GG4InkPW2KpMuQ9BmKPkM1ZOmmPMtW4rmqAl9TFGg/5t0pT7Fv7MX2Vccfb7k6Yd9TZefnV56ftO/JVudPYN+nzfiCE/v+ktX7aYNv5+jRmV/5F87VZe6ffYn36pf4r35J+OqXpK++rHztZc1rf6p/7SXj6y9ZZ15yzrzknnnJO/NSYOal4AmW3nnn4qXL5dOPi5cuL7/zTmjmpeDMS4GZl3wzL3lmXnLOvGSdecn4+kv6117SvPanytdelr76svDVL/Ff/RLvz17m/K8vO1YWz/zKf9XsfWiMVHXBp3nX6M9bwyVHvOJN1QLZZrhwEPdy3gCAWe0gVxvmG6N8c1RoHoLNUaExytcGuWovU+6koINksZko1OOwd7PlSBoKp1Q/BoAfi4qh1IR0KZyGwmkonCmHM+VwBjr569jWmTK8MiK5A8e8q7JqLF9LgM1kyTQLr5p4N1fr5+uDQmMINkeKewBwz1FoDPK1iXqhdqo09m6iUIvlq7FcJZarRGFgwefgcQAs2vGuJwMFKJT2oc4Cr++F4dSbLLVT5U660rPTYO+O55jTAe5Z4B18oAcXtxPgwcS7tXC2GspUQ+lKMF0JpmDjQr5kyZcoeuOgJ1Zwx0DPmKInXvQmit4ENIVxDQCuqb3JsjdZ8aWqvnQtkG0Ec63QWLHtMIx8AQAWeOMa9UEw1/JnG950zZOsuOOQIwJagjmjL611JVT2qNQcFOq9PI2bpXTQpDaS2LInMOH2TZh9I4pj2GEbNhm6DZpmlaJ8SFYtkVQLROUiSf2Qalhlmte5DsS+a3PfvbU/7lZFivxocQAjDWGkIZQkgBT5dgWeLZ4TwbKu0g0PyJpFguIeVnIXJbi9w7u5xbmxyZlFsK9tMK+tM69tsK4j2Nc3OTd2+HMYyf091TLVuMq2bwl9aFl0T5shG0EK7F3rKe9ilTG4yIyUBB7z7rbAs8V3IXhOBNeB4Dlh9W7ynBsc+xrLMvXuKsO8wjSvsizrbOsGx47gORA8xwbXvs6xrbGtayzrGtu6xratsW3rHDti37kl8GyL/Lvi4K40hJSGUNLQSfViFVGsPIyRBdHSwK7QjWBbHlJ19wnyuxjRHZTg1u7+jW3u7BZndpt7c5t3c5t3a5d/ByWaw0jmcfIFovoh3bTGdW4J/ShZFKdOkwx5urU8aW9uctzP9+64rQw/nlQO7Ag8myfqq0sU7SJJfX9PeQ8vv4uTzmHEt1HCW0jBcbEXLbqDFt1BiaYjoTmM5C5ONk9QLpJ1q0zbFt+HlsGRt0C1QmPvji8Fhud3QZIuTVDFMNLQjsCD4NhX6cYHFO0iUXkPJ51DC2/v7o/Vu864us64usG8hmBd2+TMbnFv7PBvoYR3MJI5rHQOK53DjHV7By2+jRLd2hXeQYvvEZRLFP1Dlm2d594S+pDSMFYZx6kSmBPe3RX5doVepNC7w3dtcuzrTMsKzfCApFnAy+fQolvbvFkE69oG69o648oa/coq7Qqs/zX6tXXGdQT7xhb31s7+7V3+HaRgHiOcx4juYcULeOkiQba0p3hA1qzSjRtsyxbPuSv0oCVBrCJKUMeJ2hRJl4a7oyferfCf692nxN/YUB57sX3VL7DvCyrPz2t4fpp6n93qPK45O0971/VJ+pyfZ99//Jpz5+jRmX/1X7vWl3mv/rv9184IXzsjfv2M9PUvK2e+rJl5WT/zsvGNl61nX3aefdlz7mXvuZcD514OnvtTmKV337146XJh8nhsefndd0Pn/jRw7mXvuZc95152nn3ZevZl4xsv62de1rz+svL1L0tf/7LotTOCP//y/qtf5v7Zl52ri2d+5V98Cu9GwIO4agEAliTVYa4+nEj3EGwdgo3c3oVpqfVtnLeVABvmvQvAubmrZ0/Xfd8g61JFPe7Nye/nUXZYq+eRdiic8aHOAsANdSRTjmSgSAaKpKHI2LtzKMJ54CzVlK/FC42k6j5wno2fg73bzVZ7udo474KtQ+V9ALjnABujQn2Qr6VPHNtbWE8jUQihzwGv35h7HQCAG5pIVn1lcjCvj/cOhdM+5NmTx+w9/hW4JwBbSagN51077R3gAtde7WVgKin8eeAsNZn2c98A3r52+20AAK7K9FcA4Iq0xrsBALOaYLocSJc12PPAG2R1vKjCTD+NcwhjwR11IV4HXr16+1UAAK6pPPHSGBP5VQB4FePzJiveqXdl96eHdUXRCcsXpr++TorzbgHATaM/U/emqoxrAHBVZQ8XiB8AwN9f/4+Tzf4PrIencrGUDprUShJZ9vgm3L4RzTXssvXbTC2Crl6nKh+Q5Yt70vsE6X2s9B5etkhUP6DpV9nWDR7sM9c23w17FyUOoI+9690VuLd4zg2WZZWmXyYp7+Nld9GiO8j9m1ucWQTr6hrjyirtxyvUH69Qx9FnjXF9k3sbJZrHK5cohhWWfUvgRcuiBG2GZCxQT3iX8gm8u3PKu45NWL085wbHvs6yrrHMa0zzKnM8ibg2mW9G8BwIrn2DY1tjW1ZZ5lWmeZVlgVlj2za4jk2+e0vo2xEHdiRBpGSs3hPejYy9Kzn27gJBfhcjuo3k39zmXt9kXd9gXkewxklri3tzh38bJZ7DSu/vqcaRV+BDSiM4VYpkyNOsZebk9h0cd+NF3o3iVXGcMoqRhpAi3/a+G8GxrzHND2mGacadSvcOWnQLKbi5sw9za5d/a1dwa5d/a5d/c2f/5jbv5s7+baTwDloyh5PdJ2pWGNZNvhcli+LH3p3k3UnkfayfGSnyb/Fc6yzLCs3wgKJdJKruE+TzWAk8v3tzZ//mDu/mzv7NsfVFdzDiOax0Hi+fJyjm8XDSld3FSObG3hXcQYnvERRLFP0Ky7rOc2+J/E/1LlLkQ469697k2NeZ5hWqfomkvo+THXt3nXVtnXFllfbjVdr055V1xrUN5iyCdWObe3Obd2uHd2uHd3uXfxfFv4sW3MOK7+Mki3vyBxTNKsOE4Ni2+K5dsQ8jC+FV8T1tkqhLkfRpsj5LM+WZtiLXVeH7msJAW/Rc757KvrFjHrOv4qnB9xNn30/XcnXi1pLPCb7OJ2d8wSfU+zT7fmr1/sI1587hozO/+t96tld5F14RXHhFeOEV6VuvyN9+Rfn2K9q3XzG8/Yr57Vesb7/ifPcV97uveL/59cA3vx785tdgLl66nJk8Ll66vPStf//YmtA3vxb85te93/y6+91XnO++Ynv7FfPbrxjefkX79ivKt1+Rv/2K9K1XhBe+zj//de75r7u3Hp751f/mtHdzp70bKFgjJWe84k3X4aYqM/kd4DzPXhvm6pOw2zostg4V9wDgrX1XrZetdO3UtwHgvqjYtBAvAAAwQwhEM+VIBq4zl8LpUlh8BwDu8NKlSBoy4M8DZ6mGTJl3AwBuqA3488BZihE27gn1hsV3AGBu30GdAc6jXbUEGMG+CZylxCUT7+aqvVy1V6gPwMaw2Jx4tzkCG8NCfZCv9bKVTqYcx78JALcNiUIYcw4AgPNoRyWa9cOmj2bLUQf1dQAAbqjDaYg3CwCzqlCqGEp5d98AXsN7wxk/6iwwsxeOg81k6SAFtdPH3uWNvVvpZaop/AXgLDWVDnDfAADgTZYZbMUKhqsAcEVaD0vuAsAcJ10JpPzbbwA/EpV8wtsAcJsRK3iieQXqHPD6niLqRrwOAMCbm6Zx8PXEiu5Y0RMreszkPwcAAJhjpav+dD3gYLwGvIV0t8NgJ6xYAIAFHtieLkTA9tS7vql3IyDxAwAAgP9Ijavt0Z2/AQDgR2saN1vpYsjtFImNJLLiBRbsvhnFNW6zdAi6Zo2qXCHKFwmyezjxPFY0j5XcJyiWKboVpnmdY9+Y9uMIvLsiP0oSwMBtTZIASuxDijzb+04E27JK1z8gqxYI8nmMeA7Jh717bYN5dY1+ZZX64xXqlVX6lTXG1XXW7BbvDlp8j6BaphrXOPZtoR8tjxF0GbLp+I4Wx31V6iRWGR83VUkCj83v7gi90/6pcd7lucbtVBz7Onvc2zWGY9vgwu1O47y7wbGts4/D7hrbBkf8LYFnR+TflQR3JUGkJIiUhtCyMHo6yzvOuyGMNIgUeTe59lWGYYmkvoeTzWFEt5D7s1uc65us65vs65vs65ucG9u8W0jBHbR4HidfIGqemndPeLd5sp+ZbMhP53cnF8/ECOpJ3hX5j71LnXpXeY+gmMfL7+Jkc1jJHbT4Nkp4Gym8jRTeRo2BEzBs4tso0RxGehevWIDzrsCPlsfgAjjNWma5Gmx36zjyOqp0+PpdOPLKQkiRf2vfheDY11mWVbrpIVX/gKJdIqsXiar7BMU9vPweQTEubhNVCyTNIlm7RNEtU3RLFO0iSbNIVC/A6RwrncOI72KlC0Q1PDTZ4Hu2xSfrzDG0LAx/73DDwaTc4thgWVbphgcU7eKeYh4jvY0U3Nzm3djizCLY1xCsaxus6xusaxusawjWdQRrdpN9c5sL6/bOLv8Okn8HKZhDCe6ihfdwkvt46eKe4gFFu8Y0ITjWrX0XUuzDyI+9S9anKYbMxLvVqXfFoZ7kud49lX0/gX2n/VYn7av5Bez7WPA9dVfnTxR8T9zf6kn1vvDOVr/k6d7O4aOv/NqveNE7wvfeFL/3pvS9N+Xvval875zmvXP6b581/uWM5Tsz9u/MOL8z4/3ujPe7M4HvzgQnLH37L6Z3yVj69l88tmb5238R+u5M8Lszvu/O+L474/zOjP07M5bvzBj/ckb/7bOa984p3zsnf+9N6XvnxJfOCS6d86C2vvJr/12z/wt5dwS2RsWW8zYA3NIP8/V+ttrNlM2zADCralpIbwHnGGa4optVXwWAq5JyFFbsqcfcfrYSzWquwvHXUYlmK0bC+emzvEw5Kp0DgDl+rsK/CQC39EkP8w3gvrjckRzn3W6+1ivUB4XGqAjn3fvOYnNUbI7AxtDNONH6dMeYLEYw54CZvWA8X425aDPAebQTrjCX92/AeXeagCePG+poNoA+B8wQI4niwbjIXO5mqj077V3gwr593Fndy1StNwDghrafDnDfAN7BetvxYisOGq8CwFVZI5wN7Z4FfiypBG3U14A5VgpiXX9sT7foMQ9iBngV7fXEi554yZuY5N140ZMoeZNlr2gOAC5s2xsawlunX/s20jP1bicCdibebYy9e03tiIKkHwPAjyR6d1LjjMtFyK8Ar93e9/N0PrbKTVc4qTInSeogiO1YoRXJM22xdAi6do2qekBU3MNL7mJFdzHi+3uKZbIObi7d4DoRPNcW37Mj9CHFfrQ0gJWHsPIQRhaA1bsr8Gxx7etM0wpNt0xS3sfL72Ikd5CC27v7N7d5N7a4s5vs65vs2S3OjW3ejZ392yjRPbxiiaxfYdoQ++5dcQirTBD1OYoZnFxNdOxdgiaJU8bhrIOSBk/3Mwdh9W7xXdM52q1999a+ezxfy3PCU79wGkbwHJv7zq3x5K57i+/ePJ7idW3yx/O7OyLfriSIlIZRsghKFkbJwijpsXQnHVVRnCKClYfR0sCOwI3gWFfphmWyZoGgnMdJ76CEt5D8W0gBzG206C5Odp+gXCRpYKMg+J4dcQijiJ+e351419U89u6kn/nktct76sTxPSv4nk2uY51lXaGblim6JbJ2iaxZhJk0K92D/TdhHnc8D30XK5nHy+/vqRZI2gc00wbXtSsO4VRJov64r2pys6om+/H7VU1unSEJ7gp9OwLv9r57Cx70sO3rLOsa0wK3bq0yLavwhbws2zrbvsFxbHDs6yy4+cv8kGZ8QNEtkdQLe8oFovoBzbDCsm7su7eE/l1JGO6rmpY94IZteOCFlgRQIt8O373Jta+zLCtwuXsPLneL76BEt5HC27v827uCW0jBbaTg9q7gNlJwByWaQ4vmx1Pv0ns46X2cdAEvWyDIF/cUS0TVQ6pmjWFEcCxbPOeOwIuSBLCKCEGdIOqmdeYMzZxnnfJuF/bu6f+nwnMFHHuxfVXPsO+ny77PaLmyZA4tz7DvJ+q3elrw/Qer9xevOXcOH3393/yan7on//535O+/p3j/Pc333tNefs9w+T3j9y9Zv3/J/v1Lzr++5P3Bt7w/+FbwhxeDP7wY+eHF6IuI/fBi7IcXoz+8GPrhxdAPL/p+8C3vD77l/OtL9u9fsn3/kvH7lwyX39Nefk/zvfcU71+S/5+XZJf/0kfBf/3f/PenvOvJPb3O7ElP6sxe7hsAcEM3zNWHheYIHOfdY+/mar1sxXwDAGbVBxbyW8CbDEuhnijU4nndNQC4JqvF8lX+TQC4qYXblePH6K4BAABcQLuOm5lj+WosX43lqjHZXQC4y8/X4/J5ALh3/Q4A3DFnTnkXrjMPCo0ROPVu67DYOgQNDwDg3b1QP1/ryeYAYM6chuLYN4EZUiQBNhJuxgxwATPeaXX/JgDc0ESzmisAcEUKd3VNW6/DmDeBGXJ83FFV7mYqvUx1YKe/C1zgOaZXNGmXAOAdQmiQCfLOAu/g/N0E1IkXTVcB4Kq8FS00DXtvATf1esIF4IY2kKmwZwHgutqXhHyJkjdR8sZL3rh3awb4c4zPmyz7kmVfsuxNVrzJsjdZ9qYqvnTNn66xbwDATaN2723gHFsPtk9d+Dv1brHLuw0AN02BXNOXqTNnAeC6xhkrka8AwI9lRn9G60mrZNivATNzwojIFOYbQmxdgKn201V+qtJLknnwIieKb93hmBBM/QpVvUxU3sfLxnVmqmGFZV3nOjd4rs19OOz6UBI/RhbEKsKTxqIwVhpCS/w7As8W17HONK/QDA+o2iWSCg4x9/DSeZzkLkZ8Fz7F46T38PKFPdUy1bDKsiH23TuiAEYew2vSJGOBOrn7Et1aplsg+JYRBE0SzjoYeQQlDaGloUm5NYJVRNCyEFISgK/T3RF6d4S+HaFvRzS9X5J/V+TfEfq2hd5tgWcbdqrIf7JYPW1mRkpP9jPHsKo4VpXAjvuZo5jjZuY4DF4Vh+u9aGlwV+jZ4jk22JZVuvEBRbdIVN0nKO8TlPf3VPf3VAtEzRJF/4Bmgj/PLYF3VxxCy+N4dZqoz53oZ25MvDvJuxb4ZlXT63ejeFWcoEmMLyJSRk9M8bo2OPY1pmUF7lJmjlW3yjCv0E0rNNNDmvEhzfiQanhANTyg6JfhC23JmiWKFm5yXmVaN7hwj1tsT5elmIpU6/Q6ouMbWD52f2aSPrOnSeFV8fHlwvBVZ/AVw+Lgriiwe+q7COyK4WuWgki4B1vo2+bDB29bZVlWGCa4xILge7ZFAaQkjJbHsMoEQZMiaFI4VXxyT8ogWhrCyEJw1QEl9u8KPVv7TgTHtsa0rNCND6i6ZbJmiaReJKoXiaqFPeUiUbVw3EGtXiJpHlC0D6k6mBWqboWmX6HpV+mGNYZpnWXZ5Dp2TvRV3DXiwQAAIABJREFUEVRxojZF1mXIhgzFmKUas3RznmUvcd1Vga8lCrTFwS5cZ37a/9Ho2UQft6/8afO+z7Lv87PvJ5n0NcPqPW1fuOxsf17Z+ehTBV/vi+37j6DezuGjtz/3214ez3DzA+2Pvq/90feNH1w2fnDZ+sFl+5Xvua99z3vte/5r3wvOvh+cfT964/3ozffjN99PfGJiN9+P3Xg/NPt+cPZ9/7Xvea99z33te/Yr37N+cBnekfZHlzV/f1l/40ceLuet3/sMXGfWhyCNH1R68s/w7qSvKlbqiuYAAHiXEBrmG6NCc6S4901S7FBxDwCAZVl9kKv1HbR3AGBBXG5bKW8Db7Is4+t2DNcA4JqimQCbCcU9YLo8uYxHeBsAbhsspLeAN5kW+CIfsJEAG4lCI15oJOT3AOCeEGwmijHsmwAAvI33d9KVrmQOAOask37mfr426au6DwD3nWDrsNg68rC+CbzFdzeG+Zr9JgBfd5TAnwfeoMRTpYNUyXgdAIDbhgTYMBPfAgAAuKmL5Wv8mwBs+lihES80E2ArUYxjzwNvUBKpMnzDjX6mOshWBw46nHcH6eogo10GAOAsPZOtDTOh/bPAu7hAP1nuJSDzNQC4pmzHwIOom/U6AADAW0hXM5RrhKR3AQD4QFz1pyoTAttvAH+OC8IXFPkztf+bvTd/jiO5D3z7z3i/PMfu+q0kh9erjeeI/oE/vhfeFw5b1ujW01pyy7IYMbLXsma865WvedLYao3m4jkkhxd4gmSTAEGAuO+jAXQDfd/3faK7qy8QnHEE3g9ZR1ZVVnX13Q18P/ENslGdVZVV1VWfyqysTJM3te9Njf5c9daLtMmfNQeW/1al+oObTsvuoz9Qqf7rbZc1XLSGi9ZwwRJivBsp2SKl5ZE3VKp/eRzMmybfValUqp8v7bqTd/+nSqX6o/cWI6vm8LW3VKr/+8aDHd+U3vti0z2+7nq25tStOB4t2+8v2EZmTNenDFfHty8+3fjo4cr7dxd/dXv+V7fntPeWfvNw/cMnerpzgzHjxed7lyf2r0yZr720fjrD9pthvzHj+PSl7cqk6dJz4/lnu+ee6D96tPnh6Pr7D1Z/82Dlvfsr791b/vXdpV/fXfr1veX37q0wl/jt82PGyxOWqy8d1+c8t5YCd9YiTP+FMTS03N3V8O3lwM0FD93XI/M+D91R0ZzrxpwLe8XI8smk5cqk9coUChtKfPWl7cpLLAHTPOrqtP3atOPajOPaDCNR3su7vpuLvpuLvhvzHlTRjR4x0m/u0t1v0f1mXJ91Xpu2XZk0X36+d+HZ7jkd3ZT6g4f0K0z0M+OnuxfGjJcmzFem7NdmXDfmvbeWAndWI6iSmTcc4U5mlOsdGuuvatZ5Y959a8F7e8l3e8l3c959fZZ+lejyhOni+N75Z4bzzPG6MLZ3YWzvwpjxwjPjhWeG808NdE2AbuecbufjJ9sfP9Z/9Hjr48d65iHC/uUJy7Vpuob57kb8/lZydDuNuork9R29TY9HdG8jenctfGcFdYLto/vxWPQyXXm46R45mC6amQ463HQXH+jl45e2q1OWT16YLj7fOz9mOD9muDjBGtf96Zznxrz35qLv5gLdsh11Q4ZeqUIvdF2bppdAP+9/iraOfmn7w9GNDx5tfvho48PRzY8ebX70aPOjx5sfP9Gfe6I/T3emwcbOxbHdi2OGy+PGK5Omay9t12ccN+fcyLh3ln13V/x3VwL3VgL31oIP1kOP9DHdTmrMSL+/+8JamrQJvdvAvnY6ZOzL9vCsyL7SrxvJVzu3WPCVetwr/8Q30lbBV8a7v/xv37v1q3+xPbyrf+8XG7/8u4133t5+523DL942/vJt87tvm999y/buW/ZfveX81c/c2p+5tT/1NxMe7U892p+5fvUzx6/esr37lvndt8zvvm385duGX7y9/c7bG++8vfGL/7n16//P+uDOrV/9yy++913au+b4/H5E4N1Xy/tB+j0iT2rfn7WF8o5o0R2nNu99java/OV2OFsLZQO3uCrPN26YS75EcfPuV1V//HgzVvDEDjyxg407X1WpVKo/Ht2I5Z//M1Y5+s9rG3e+qlK9+zyW98RWf65Sqf551R3Nu9k3bqM59+y7TIKDDbTYeNGbKCHv+hIlX6LkT1KBdDmYqYaytel3Vap3dyK5Oorpd7HV/UIfSHlvfEX1h3fdvkTRGy969x8zTabe/bt/Qg7OOsMrf4fN9L/mCp540Tv/ryqVSqXSvkhVfKmKL13xpSpb97G9oVL9/SL6quqzPPtD1deumyueBOWOb/4vlerv5lCHl+4rf6RS/dHjlfCBLZy3hXJP/gGff8nkt138Q9Uf3LCbA1lzMIfFyt+yyf5pDfVdtXgbq0L/oyeL4aIl7L78RyqVSvVfR7y26CYzy7+8/Q8q1d+vGH3Z+z9Xqf6fr/xf9PR3rltii6bo3H5k2hie2g1NbAfHtwJPN/yPV70Pllx35qw3X5qvThgvP9v++MnG+w/X3n+w9sGjzY912+fHDBfGmW6nXpiuTDLSnXXemHffnHffnHffmHejd0mvTts+mTRffsHrJQq91XOeeb8WvWJ78fke6jHj0xnX9XnfraXAyGr43kaU6TGYHt3v7ipTyzqP1OtCPVdcn3Mx/TN7b6J+m2edn8462DLo9Tm6R/6b856bc1gvTkznGKxcbzH9LTOdVfH6TWS740cZuMHOiPXSPLIcvL3kv7no5QpkUxb0xvMl5hXhyxPmTyYt9JgBqIuuJXp4hvsbqL+qtGAgwlF96gE9KEJkhClW3px331r0jqAumleCI8v+24s+eg+g3jN4ja4d12YcqBdG5pm0nb4XmbJemaRLpVwnVjPO63PuW4v+O6vhexvxB1vJh0wHlsIhiXbZUYHRGIWxexvRu+soInfX6YENuH6hxYG+WmFGrVjw3ph3X591Xp2207+KObSf/beW/LeWAreXA7eW/DcXvOhtomvTdtQfJ+p59Ma8+/qc61O6CxHbVeYe6zLqQgT1IDZh+gR1IsYE6j8SdXf16TR6cGC/PmO/Meu8gfpApXd14O5q8N5q8P5aCMWDtdCDtdDDjcjj7cTT3fTYXp7xLlm6cva184JoX8H4Cg3tS+joqplq543m2lsxTZ2bbWzVnnqJ9vVljzyR9Fd+73eu/OPPjZMT4YWZ8MxEeGYiNjMRn5mIz02k5sfTC+PphfHswnhuYTzfUuQWxjML4+mF8dT8eHxuIj4zEZuZCM9MhGeeh+enDS+eX/nHn3/l977kDMQsoQLr3VlDkKodCfvN2EL9Zviz1mDeHi244pQ3WfGlq8FMDUUoWwtmq8FMNZiuBNKVQKrsT5b9ScqXKHkTRWHEi0xvU+TwxJlA3UhxUfTQM5a4SHLhS1L+VDmQQQ2t66FcPZw7jOQOI7nDcO4wnKuHsvVQthbMsFktB1Jlf6rsT5V9yZI3UfLE3Z/+sUr1z2tsr1UetkfJZNmXKvtSFX+q4ud6x6TDm6p4k0ykKr5U1Zeu+dI1b7rqTVWZLqwr7kTZlaB7dWZGayjaI0V7pGCLFGxh+kUgrteLcMFCF2SL9MgKkSLdk3OUskYpuj9nOkrsIE6WSMmKBnGie3UuWcIlc6iI+owc/QeV6u/Xdn15vSe35c6uOzKr9vSSNTVvSc2ZktP7iSljfGI3NrYdebwRfLDivbPgvjVr/3TK/MnE3sUxw4VnOxfGDZcm9i+zBUTmIsV2Vch09ot6pffdXPDenHdfR/0pMhf6q9NcofPqS9u1l/ZrdCeFzutznhsLvltL/tsrwvEJHmwlHmzF72/E761F76yEbi+jHvPpQQ7ogiZvPCKmx0S6K3w0NlFghPEiGkAQvXx5eylwm+4qOYSPXnCPq+KmO6rEhn0N3lr005JmjYuGJFqL3FuP3F0L313lRkdADr6ODcJzfd5zY8F3c9GPRkO6g42Fh5pT4ePAP6HLlKmHaOhZZiREVKAcWQ7cWQ3dXafXi8a+vcPuhAVssIFl1AkzE0vMmAFYB5N00IP3Be+shJgeIlOj/HER8LGB2We9j5jR7NHYR+J4sMUfDYkfqFaDGXSIGVtikRl2gqfqEH0U5j1035bznpt0/97B20sBFLeW/DcXfdioGHTfmfQdGDNmBhpRgxk1wX9nOYCGTLi7EriLeqdaDd1fCz/YiDzYjD3cjD/cjD3cjNHjGm1ERzeiqD/nx9vJp4bs+N7BhKk4YS69sFCTVjnvSgqYYF/ho9927Kvwoe8aVu3cjH0J6pXpXkN5nfNe8+p1JKrRbPm85ns//v3f+coXfusrX/itP/niv3vjS//+a7/zH77+u7/9jd/97W/+p//4rd/7wrf/8xe/8+UvfvfLX/rul7/0PRT/5Uvf+y/Mhy9/6Xtf/tL/+2Xenyjxd778xW//5y9+6/e+8M3/9B+/8bu//fXf/e2v/c5/eONL//5PvvjvvvKF3/rKF/73v/g/v3Tuz74bShX2/bl1Z2bFllyysN5lyrtU7dWi0b9iDm+ifiJ9GXMgb4sUnLGSO1H2piv+dM2fqQUytWC2FszUAukqCn+q4k+Vfaky6iGZDaYjZX5ITU+UvPGSN17yYEFKxoUvWfanKoF0NZCpBbP1UO4wlDsM5V4xcRjMHYZy9WCWjkCmFsjUAumqH/VzmSr7zE//UKX6+Tzd+yPde3OqTPs1XfOna750zZ+p+9Ioar5UzZuqeVNVLzOsghdNSdd96bo3Xfem655UzZNCAx/V3MkqGtrIlag6ExVHvOKIle3Rsj1KD2XI2JQxa5R2Jxdo/CI0nHC0Yo1WLJGyJVK2RCh6OMIIZYmWLegrNKhRlB2RsLwfLo/+o0r1D5uGAIUGKdr0FNZdB6uu/LIjv2jLzlmz0+b0lCk9YUw8244+3gw9XA3cXfbcXnBdn3Vce2m5OmW5Om2je/mfQSVFVBnrorvXZy55bN/6zOUPXdbp4WVuLfiQm+mRfBYxdS0HR1ZDd9bC7DDp4ovyvfXo3dXwnZXgbVQqWvLdWvTeWvTdXqaHw2NCXKJC0wnj73Jj9LJjBLFD8eChZ8Yi3IjdXYuMrITYgQ1YYd/fiDGDxcYfbMbpMRXWmfysYIELfiN2fxMNEcg0YN7JIN2y8Xg3+2gnPUqP+s4OBRi6sxK6s8beo7B1A2gsh+hdZkvvciMUxdl7iPv4UEVot6D06xFmRKP4/c3EA33y4Xaala7Yu9h4hci+WXagX24AYP7YgqOiYEe5f0gXmply83r03joziBNd7UFPvEvffPjpcTWYEaXurjH7lvkx3F0N31mN3FkJ313FAh33tQg3UOA6PVb0w8346FZ8dAsNRpl4tJV4tJ14tJ16sp16spt+spt5vJN+vIOG9U0+0icf6ROP9YnH20ndbuaZMTe+X3huLk1YGO+y0YZ6ifaVHFiwsX0VNbla87EhtG/jgm+oiYKvsZt1zr7sUaH2OTnqXBRbjtrnxdrnhdpnhdpnhSqK1wcoKkf5ylG+cuSIUZvu3Lojs2JLkbxbfTVv8C3th9atsS1nYteT3vPnzKEDe6TkjFHuZBkV5vzpqj9T82dq/nTNn0LSrfhSFV+qwisF0iEYe4A33YNHggt3gh0+iPuWHZMAn4seqiFT82fqgexhIHcYzL1CEWI+BHOHAfrfw0D2MJA9nPolV1P7h/f9qMzqSVW9SKLpmjdd92UOUfiZD97MoTd96E3VPak649SaO1lzp+rudN2TPkThTtGBjelbcyVrzmTNkaw5EjVHvGaP12zxqi1etcUqtiir1YotVrXGq7Z41RqrWqJVS7RmidYsMSaiVTM2RKApgqJsilTMkYopUjFHa1hUzdGqKVLdD1dH/0ml+set3WB5J0Bt+6lNX2ndW1pxF5ddhQXHwZz9YMaaf2nOvdjPjBtSuu3Eo63Iw43QvZXgyLL31oL75oL75rwHlYRuLdClKG4cIWTclRC6tN1bC9+jr3d01eJddixeOthrH3OVpK/1zBD03Eh8WPGIGe8dFSXv0EPqolH2UA1tFJcKFnEk1PvMCOqo1poNtDrafPoUakgsitSoPjWK6lGx4XXpyzc+di+dkg5m8HZaxkxgatcnH+qZ4f+YYi4uXca7Ga4idwPtiigSKjvoPS/Y0XbZgXi3xZuWGuWlT3FD9uLD8WIjNIikS6v3iYE3cGFLgWl7h6m43k493KJzNYoytpV8sEnffDBDLgboQZSZQe8fYD8h3p5HYzui4ZzRD0yPRkROPtpOoXi8k368k36ym3mym9EZMjpDVmfIPjVknxpzT425p8b8M2PuqTGnM+R0hixK9mQ3/WQnjaQ7tnfw3FR8bi5NWKgJC/UC964C+05Ke1ds32lBwVdU9m3Y4HlR2r50qRezr1R7K7J9Q2T1NlXw7ezj3ob9OZtbi1jdFKvtR2r7kepeuGIMUYZgaTdQ3GWHg/Pl9d78hiu3JuPd2V3vwl5w2RxZt6NxALP7gQNLqGiPlpxxypWsuPBB9NCoecmqm65TFQ6f55INejBdccTogfaccRRoIjadS1CmhyakC511X6buy9R92UN/9pUv+8rPDx8dh77soS+DCqaMQUWD8tISZf51pw/p0XlTdWey7kzUnYmaI1FzJGrORN2ZrDuTdWeq7kzVHalDR/LQkTx0JOp2NuJ1e7xui9et8bo1VrPGapZY1RKrmlFE2aiZYzVTtGZCg96jDxE8qsZI1RiuGkMVY6hiDJWNobIhVDaGKsZwdS9SQ2EMV9kwhKu7oepOqLodrG4FKpv+yoavvOYtr3ioJVdpwVGccxRnbAcvbQeT5vzzvczYbkq3k3isjz/cij5YD6OqtjvLwbsrqCwbxKvycOPeXQvfW+cKEExVLRPrvKCHJaebTdGlmQdbXDGXHfSeq2qmHxwyRRnG36gjyQeiIjI9CDwTePlVMH0U+ZIRkrB8xopKzz7CjLNj6N6nx9DFB9DFAjMcP9KjaMR75mUhvGJZ7N3HTL+M9HjA6O4BGzqQG7KeVMREw9fLBjPXLi8xa1xp6TaMXJNi5gn40U7m0XaG25lIveg+jK6RZocsZOrq6buo5Chra+bmg9v/9BFPPdpOoYU/3s083s08MWSeGLJPDFmdMacz5p7u5Z7u5dl4tp9/tn/wbC//bC//1Jh/Sjs4qzOgYXrz4/uMdxn10gIWh1U6bNQLGzUpEVM2asrO9nhFxzQejvIMP2Yd5VlnedZZnsNi3lXmNOyqLLgri+7Koruy5K4suyvLnsqyp7KCwltZRQ5G4auuM7Hhr274q5tsBKpbgepWsLbFb3K1E6rthGsdVG8Ldc5K1Ctt37o5XidMjNXNsfp+lJbuXqhsCJZ2/cVt38G2N7/tzeu9eb03v+XJb7iya470ii21KPZuqfpqetszZwgsmkKr1timM7ntzhh9+f1gwRwu2qIle7xsj5cd8YoTCwcdZWHEJMNOB4XChkdULugqWXZKjLLHyo5YxZmo0HW5ybo7WUcFUDdbAE2/8mDhTr+iPZpmB7qvO5P0v85U3ZU6dKUOncy/ztShM3no5KvUlqjb4jVrvGaN160JPA6tcTos8bolVrfE6MNjjtVNsbopWjdF6/soIrV91pSRmjFcN4ZrdERqxkjNEObFbri2E6rthKo7wcpOoLIdqGwHKnr0IVjZCVZ3QrWdYHUnxIvtUFUfrOqD1c1AdSNQWfdX1nzVFW9l2VNecFFzztKsozRtK01ZCi/Mhef7+bG97LPdjG4n+XgrMboZe7ARe7Aevb8eub8eYYeh5epOmZIrXezjxnUnFDcFwRX+eGOtM9dNxrsPsSLv/U26avT+egx12ozk/YC94OoTTNGtuXikTz0SGZcLTL2jerramQ5UZtrmzf6YCckF4il3kXeFuuV5d5fJBsrAFvPQFBuU/hEyN2fKLBPtFkafGFuRroRNMc2LQ1gdnaZjOz26nWFuO2jvshUP9+hH8jF+7QUxhDdAAu+y6tUZsjpUxhV4d4/x7l6eKQTT8WwvP7Z3ML5fGDcVxk3F56biczMvJsRhIYWVjhfSMWkrTYniJR720jQ/Zhx0zNJBzTnpmEfhohZc1KKLWnRRSy5qyU0tualld3nZXV72lFe85RVveRWFr7zGxLqvvO6vrPsrG0xsBujYClS2AtWtYFUfrG6Hqtuh2nYIOViuX8lG9u2ZeuummKLYj9T2wlVjqGwMUki6ek9O78nqPTm9J7flyW+6cxvODPIuVt49Yr17OLnlntnxz+8Fl8yRNXt805nedmcN/vxesGAOFy1RyhKlLBE0crtk0E8lI2XU/MciEeYwZQ6XGoYpXDKFSqZQyRQumcJFU4iNkjlcskQoS6RsjaHh4qu2eM2eqDkSdUey7kjSpU9n6tCZeuVMvWI+HHJF0uShPXloS9ZR2JN1W6JuSxzyIn5oY1UqkGisZorVuGMQre9H66Zo3RSjzbqHWgpgvyRDpG4I1w2h+i4XyKa1nRCqn+HV0myH6vpQTR+s6dnKHD99m0n/0H3o517d8FWY6ejek+txBvV+vuavrvqqK77qsre65KksuCtzzvKck5qxIe8WJ82F5/sHY3v5p8acbjf9eDv9eDv1SJ8c3Yo/xKpJ72/E6OLsWhS1JBIYl1+nGhdoVRAPBU9ShZEQqRdz9ga9/Ieb3HJG9UmJuuIGIeddvOBL1yHTxSlmRl5Fcash711Uek4x7k/h0sWqglsumHYwON3yq46ZhletxVaKrbRnHp+jB8DMk3IUjX51AhkLBPxoJ/14N/14l1fwpYu/hhxbzGUD1TnrDLmnxtwzY35sD8XB2N7B2D45xgVhOhg3k+O5+WBCGAU2XliEMcmGlY4pJl5aCy9tKIrTTMzY6Zi1F2ftxTlHcZ6JBWdpwVlacJUWXaVFV2nJTccyCk9pxUOteKhVLNa81JqXWvdR6z5qw0dt+KhNf3nTX94KVLYCFX2wsh1k7Buu9aDg23KdM+GSHq2ZmGu7yLvVvXDFGKQMgeKOr7DtyW+5s1vuzJY7u+XObrlzm66s0LvGAOfdYuVwYtM1te2bMQQW9iPL1ti6PbnpzGx7c7v+g71gcT9U2g+V9kOUKUyZQuTYp6NEjL0gHkX5MLIRKBgDBWOwaAygKBgDxb1AcS9Y2guV6DWGy6Zw2RypmKNVc6xmidWssbo1XrfyJWpFwRVJuTDHuDCxH6J07Efr+xE6mLpcOpBHMZXWdkM1drwOnkGDNX2wthVkH4dwVTQbWKwzseavrfmraz6mhsdbXeWisuqtrNJ1QeUVtlLIU1nxVFY9lVVvZZV5ToOaS6DnN4seumXjnLM86yhP26mXttKUtThpKU6Y0HUh/8xIP756vJN+xNTL0deprcSDrfgDdIGjdcsr4z7YiD3YZKNN7wofyLF1zg+2GN1uCpcwKqo37pR3eXXOormYYmvbwZMuPZFX2KUPBNcUi+ddWr2YtgWFVzaMbHRUusyKUB/OzCtGKaa1FLnyQ1FsxLlHFVizKVTjcgf9yT53X48IHm0wERNVyXB3iujHNrqVGNUnH20nmYe+XDzhngFjQf+Z0e1mdLuZpygMmafo2TD9hFgYzwSxJ4wxLMa5yHGxnxvfzz0XxQQKEx0vmJg05ybNuSlLHsVLFNb8NBMztvyMLT9rO5i1FWZthVl7Yc5emLMX5u2FeUdh3lFYcBwsOAqLjgL6d9FRWHLSsewqLLuKKyjcxVV3cc1TWvOU1r3Uupfa8JW3/BV9oKInqle+sVWP65wx4+5Ha/vR6n6kaopUTdEqyb61/UjViLzrL+74DvSe3JYrs+lKb7kyW67sljvb2LvPN5yTW96Xu/65vdCiObpiTaw70pvurN6b3/UXjIGiIVAyBErGYMkYpIwByhgo4WEIlAyBIhu7WOz4izv+Ajl8hR2fxFd0HOz4UBS48BfpCJR2AyVDgDIGKWOI2gtV9sKV/Uh1P0I/HzULb1Jos6Lg+gKNHu5HD/ciKOp7eCE1XDOEaoxQaztBOujGe4GaPlDbDqAPVX2gyrYyQMXNjUBtnSt00ipl35NbQYEJkhf0G+6VJU9liXkGs+iuLLjK4lhE4S4vuMvMawOVBXdlHgXTwmLWWZl1VNDToJc2atJamrSWJizF5+bCc1NhbL8wtn/wDJV6OfsmH+mTo1gt34PNuLgdEyPduPIi78Nmi7wSzh5ljYtKos17Fyu5NhQw/hCXqTHuiHQFpV7m/V3m0WaCrpbfTNCS0KdGd9KCB7GEJ6YGVurCZE86W0Tmd2WFtQWL4Y9jW4+V0AhqUofak/NejgqOrARvrwTpF8OWgyPLIUKgduD8wNoK8No5oxbODzZi9LtDm7HRzdjoVvzhVnxUHx/VJ0b1iUf8eEw3b0aRVBJPBLGTfLKT1EnE052UMHZTT3fTzwRhSI8Z0mNGOsaN6ed0ZCb2uHixT8ckE1Om7JQp+xKFOTttzk6bszMWLKzZWWt21pqds+ZQzNty87bcAgp7btGeX7Tnl+z5ZUd+xXGw6iqsugprnuKGl0JlX0y9DcYy6t4rRtLqZWsraePuh6t74cpeWGRf3LuhCqpk3vHm9Z7cpiu94UxvOtNbrsyWO7vpzq47M2t2xrum6KwxyPPu+IbjxZZnasc/YwzNm6LLlsSqLb3uzG66c9uY6nYDxd1Aaddf2vUXUXAW9KNGXFzovQW990DvOdB78npPfguFN7/lPdB7D7Y8XOiZYKdsevJs0DNi3255D/Tegt5X2PYVd3zFHX9pJ0DtBKndYGU3VDaEKoZQ1RBGDZFqxkgN2XSPPX6iJuyGsLASmKkBRgXW2naQ66WFNivTqA+18UNyXWdH+fDVVn21FW9txVtbpoNrOrjIhru6gMU8Chcdc7yo4I0j5hxM0FN47xKwwY1q4uA1wZiylydt1KSVemEpoUdQ46bCuAl59+CpUL1s/WrioR6VNVmtSum2g/YVloAjpA07AAAgAElEQVTRLDzX4tGSd/FKY6FoFRSO265nFniXK+wyLxHFeG3TNmIPNpMPt1N0kXeX71TxWz1YAytegymJkvFjYclY+TPd7KPdzMPt1IOtBGqFzrxz7L+Fvz/GvmO9pDRuLfpQZ1U3sUb1grix4L0h/S3dDp8L9j1v7hXekeXAHSbQW7z3VkP3VkP3V0P310L31sL31sL318P31yMPxLERedgoRomxGX3UKB5vxsihjz0RhU4fe6qPPd2m49l2nI6d+BgT47tsJJ7vJp4bEs8NiQlDYsKQeGFEkXxhTL7YS07uJaf2ki/3ki/3ky/3k9P7yWlTctqUnDElZ8ypGXNq1pyaNafmLMk5S2rOkpq3puat6QVrZtGWXbZnV535NXdxHak3SKu30VtGNUO41vM6Z1TSRU2lUBPlsjFYNgbLxlCZti9Pvci7ZUOQ2vUXtr15vSe76UpvOFObzvQmz7upFVtqyUry7ti6c2LTM7XtnzYE5/YjgVQ5lqvG8rXEQT1ZOEwWD5PFV8niYap4mCq+YuKQFwVB1JOFerJQT/AjqSASpBAlO0SRKhwmebk64qJ0lC4dpUuv09Rr+l/qdYb6LM2L1+nS65QgirxIiiLBjziKgjBihdexwlGscBSViIggDsgRbjnyR+H8UQiLIBu5o2DuKJB7Fci9CmRfBei234f+zKE/Q7cP96br3lTNk6qhRuxYVNwdCg9qJ9/ZoF+wrnUixEsmp0QvoXUy0JKTFXei7IqzjfwpZ5xyxcvuRMWdrHpSNU+65sHm8jAvkQszz+acn15pZBoFtnZ3supKlJ1xyhkrOaNFR7RgjxzYw/yINB22yIEt3OHgZSxSsEcOHJECHdGCI1p0xohRcsZKLhRx+aCI4eaipCDoxB5BJBoE3WUC/5VOHyn8SbpbITwCKNJ0BEURyrBRCWUq6HM4Uw5nKuFsJZKtRnLVaL4Wy9fjhcNE8ShZQvE6RX2GB7oOpyj6Es2L8ut0+TMUmVYjqywy5deZ8usM9TpDHWVKR+nSKyaOMtRRhnqdKb/O0vFZlk58lC69ShcPU8V6slBPHtQS+WrioJY8qCUL9eRBPZytrjlSK/bG3g35k6XLNx98XfPX3/zzn37rRz/7zo/f/u7Zv8Xif4jib/nx9nd+/PZ3fvzWt//irW//6GfC+Iu3vvMXb33nx29/98dvf/fs26J5//a7Z6WmCzIgmv7jt7/7Y7Tqt7/z47fQh+8KM9/BEO8HiBMQ/J8i94t6u41fVGsZePs7P37r2z/62bd+9Dff/OFPv/nDv8bip9/60d98+0c/Q6cSdzahTP4Fd+p9iwn81PtOg1NPZgMV5/nPf/rNH/71NzT//et/9ldf+8FfvvH9n7zx/Tff+P5P3vj+T772Azz+UjZ+Igqp6W3E93/yBj++JswkMeRzzouv80PZlra1ivZDKpPMXnqTEH/65leZQIf7az/4ydf/7K++ofnv3/rzn377Rz9Dl2XRb6nRGddABx0749hz51s/+tm3/vxvvvnDn37jh3/9jR8iD7Kn21vMFeDt79Apf/rNH/711zXod/7mG3/65hvf/8kbP/jJ137wl2/84C+vjjwKZ6ucdw3S3g1nyl/7wV9RAAAAAAC0yle//5N4vrZiTy1ZEwsy3n0J3gUAAACAtqG9a0stI+8K21WtOyc2PZNQ3gUAAACATtDAu2NrzueMdyPgXQAAAABoD867lsS8KULy7hZ4FwAAAAA6A8+7+5FZYwi8CwAAAADdgvXuEtm7684JZd49HgB6ueMAAAAAoAUae1fJ893j4+P4APDmm2/2ePcBAAAAQFN0wLtIur3PupiRkZE333yzv+Xs3q99cOjXcQcAABgiuPd3LYn5/eiMjHel3iM6HjDv9rGcfTwY5f5+AfUNAAAADVHqXZl+MwbNu/1a7+Dsh37Rr/0PAAAwRPC8a+qsd01atYpDo5PIgkmrVmtNndgY8G5/Ae8CAAA0ROBd0ntEm57J7UCL3uWEatKqJdQL3j0pgHcBAAAagvfP3FXvSvu1m97VaVRCJMvd7a6XsB/4JX61RqNoS+V3iMJaBOW0tv9Jc4F3AQAAGoJ5Ny7p3RfbgZe7bXuX0mmQJjhzqLUmlEyjUWMewWdkP+O+kfCE9HWfWXV3kPOukjsPAQ29q6QWQTngXQAAgB7SS++iv7Gp7ASm3EZrhOBdTDDSnjh93u1EbQF4FwAAoIfwvLsv8u6zjpd3+dWkKpVaq+NbFqUReJdYAhahyLtc8VqjwWqhma+5mmlO8/Kl7Oa9qxOtl10JfY+h1mo1gozJ7lVePjU6ejvQrOy26zTM3uYtnFCjQK9TnE/5WgfwLgAAQEME3p0RjIvQSe9ypVu+SpRYtrPeFRtDXKpGlhKXzqXX2+j5Lv9+grde3J30rYlk4V6yFoFfZ8CXPDdBvHDRthMqr8X7B+0e0n4g7SEAAACABnl32SbnXe/ktr9t77KXbH6NMa0Z3gSeJunre+fqmQUKx0tvRMkJSuekFTddzywsNdJ/02nlbzKkahFEs6Bt1mnUWp1WTX8ySd7lKHmm3ujuB7wLAADQkK9+/yfxfHXZllq0yHm31fIupiysBMXWXzLtqkRewyp31R1uV8UJAyuyid3DbULjB8NNele0Xt5+IUu0wTKJs+g0aq1Wg9bIyLcZ78ruH/AuAABASzTw7ti6c2LLO7UTmDEOTH9V0m2kmveudKmaq2cWFsal1tuMd8UrYW8uRA+85bxLqEXg1wWrGAUzdz6SdfjiJcjtH2JtPXgXAACgIci7K7bUsjWxYIrO7pG8O7kTmDb2d1wEvIlPg/ZNErMT6pl5BXJOxoICOr90Lr1e5fXM4vWK21XJeZdYi8BbBDeJUzArTKln56IlEPYPl0YN5V0AAIAWoL1rl/SuazC8qwjor6q/gHcBAAAagnt33hQhetc3uROcNobBu/LrHZz90C/AuwAAAA3he1f0/u74uusF8q4BvNtgvYOzH/oFeBcAAKAhmHeTZO9ObPmmdoIz4N1G6x2c/dAvwLsAAAANQe/vrtrTy9bkgik6ZwyVed7dcE3ofVO7w+TdYwAAAAAYAIhFEc67luSCKTqLe7eEeXfaGI5kB927iDgAAAAA9BupKkC2n0jau3t87z7fcE3qfS93gzPD410AAAAA6Dty3j2orTjo94jmeN6tHj7fcE/q/eBdAAAAAGgKee+uOlIr1sSi0LuVw4lNN+qcGbwLAAAAAMpR7N0wwbvThtDsXiQK3gUAAAAAZSjx7oI5Nr8f5tUzT2zQ3p3bi0azFfAuAAAAAChBxruJg9qaPbVqSy6KvPvqxaZnats/YwzNg3cBAAAAQDENvOtIr9iSi+bYAsm7gRljaG4/At4FAAAAAIUoKe8uieuZX2x5Xm4HZgzhuf1INAfeBQAAAABFSHr3TzHvWkT1zJN6z8sd/4wxPL8fjYF3AQAAAEAZDbzrSK3aksuW+MJ+pFzHvDul907vBGaN4QVTNJargncBAAAAQAky3k0e1NYdqVVbatkaXzSFed59qfdO7wbm9pB3obwLAAAAAIqQL++uO9Nr9tSKwLtU9dXLbe+sITi7F140x8C7AAAAAKAQ2fJufcOZXrOnVq3xJTNWz0zVXk3v+GcMwfn9yKI5Fst327s6jUqjE/9p0qrVWhOekJ1i0qpV2Hf4dG6ySatWqXhLkFgRkxZBT8KmCJYiB5MBnUYlhF2zTiNcIJ6asCqTVs3sEN7CTFo1t1STVi1YB76pkqvmZ3vIaGeH8I4vaV8BAAC0hHw986Yzve5IrVjjS+ZIhe9d36wxNL8fWbLEY/luP99tzbuYQUjeJZlHyrs6Dbss9tKNX8OVa0mYUrBGZpJGw6USZBTLCzuFUbkwk9jaTFq1Wq0WbYX8qiWzrXwD+0h7O0R0i6ZUvQO0BwAAGEQaeNeVXnekVq3xZUuY592ZXf/cXmhhP7pkiccH07tqrVaDlU353hWUh5teESW4FBP0Saaxd1HhVcfYr+FVHCvsihNy6tFp1Fodm4ScX8GqZbKtfAP7R5s7RDD74GwXAABDjpx3C7VNV2bDkV61xVcs/PLunDE4vxdeMMVWrIPrXZO4mIs+SFSySpd3SZruUnmX1ih2gyC/ZM6SxHsJZvnof1lHC1dN8etaRdXjTFqNRs1OYGbAax3Yv7nEvam1bW+HSB0p8Uap+EeAJ3OpZxPgcAA4vch6t77lzmw402sC75ZrR3PG4IIpsmSOrVgTHfHuCAnmy1a9yyYV1D9LPrGTfr7LzUlyUvPPdyXWyIqASYinZy/jvPpPfHZRJrHF0LYRLlR61fidhbhym72zYb6gU3PLFtTp8hIjiAddwPHxsczulP3ZtLdDhNMEt3K83xj34+L2AH5fhpIQ5lW+HwAAGHDkL1aCC5ecd12ZTWd63Z5YsUQq9dc87y6aIsuW+KotkcjXOuLdYxHMl617l76w8rwrfBhKiZdM/pOZxrvKklPSihS7vYF3+Y15+NdqwhJIVcK8TNI2FZf3iTmTXjXpxoWQRsVflUrFW6JOuC3iIy6g4U9Z9mfT3g4hHinxRplwlWN/Eg+ceF5l+wEAgAGnU95NFep6d2bTmd6wJ1atUZ535/dCS+bIsjW+ak8mDjrmXYkv+dcwglzlvqJrN4XTiZWQEivigdc34qVh2SKvZJ75V3xe8VXi+s3bBKkKW2yx/LZSJq1aoyXNJ161Tuxdvr6IbuZ5V6alkiIUelfBklraIeLnu+KNYr/T8Q8x2bvQLBoATiYd826xvu3ObrnSG47kmg33bv1ocT+0bImt2hLrjlSy697l2wl/6qrAu3ThUzydZF7iioQlW7FXGl9SmdmE5WzeComXen57Zmxb+IVdcibZWUgLIO457E8du0hmV/HtxfcQqZ6Z/11vvdvmDuHvEXZh4g1mPrILkatnJswLAMAJoIPe3fFk9a70hjO5botVDnHvmsIrltiaPbGBvPtn3fUur5KOJ04M/KIvKrgSvEsvQNyMlfDQFmtPRHijl1ijLIRehOAKj3tXVPfNXp251bPlKvILSKTsCO4viDXsEqvmHo+quUe+wnpmNf8RKsoF+/6VuD62Cdos77axQ2SOL+ExO2+R+DMO4eykeQEAGH465d10sb7tyW67M5uO5Lod826lfrRkDq9YY+u2xIazN94FBpLmVdoUnatnBgAA6CId9O6ON7vtzmw5Uxs2vndXzJFVW3zdkdx0ppOFOnj3lALeBQAA6Lh3PRm9M7Vhj1dx765ao2u2+KYzteVKp8C7QHcA7wIAMBR0yruZYn3Xm93xZvWu1JZD5N11e2LTmdK7M6kieBfoCuBdAACGgg561+DL7Xiy2+70lpPn3ddrtuiGI6l3pbY92TR4F+gO4F0AAIaCDnrX6M/terM7npQe92718PW6LbbpTG67MzvgXaBrgHcBABgKOubdUt3ozxt8uR13etuZ4Hl3wx7TO5PbnsyON5sB7wLdAbwLAMBQ0DnvHu4F8kZfbteT3nElarh3t+xxvSu148kafLlMCbwLdAXwLgAAQ0GnvJstHe4H83u+nMGb3nEna68w7+od8W13ateLvHt4yr3biS61TzVSh17mK4UJekO/9x8AnCIG4ZQX01TGRuS9GzjY8+eMvvSuR+BdZ2Lbnd71ZY3+fBa8OzLyJtAq8Xj8BHi333sRAE4FMpeL/tIx71KHpmB+P5A3+jIGT6r26jPOu9uuxK4nbfRl9wL5LAXeHXnzzTdbH8niBBFvEvkTabi82+9cDBYDcmhOMyfyECjx7ghvMFDylI7TKe/mqENz6MAUyO8JvFs7fL3jTiLv7oN3Me/+/rWBjt54V3litN/AuyeSATk0p5kTeQgUeleQpge7orPeNQfz+/7snhf37qvXu+6kwZve8+dMwYMceBe8y9BULRB49wQzIIfmNHMiD4FC7+IF3N48Fe6Ud/PlQ0v4wBI6MAWye7407t3PDJ6U0ZfZD+TMwYMc9arX3sXGimlxNDXy8KgNB98lw3p37fh4bRFTne44enz8zrXjd0KMl0L0V2uYq0Z0x79/7fh7JvrPqIlOw85FL1N3HGUS038Wj793jTSv7jjK1yFaQg8A7wKIATk0p5kTeQiUe5dNRvyTFbPA0MQ0Suicd19ZwwVr6MAcyO770nXcu0Zvet+fNQXzltBBrvyq2+Pv8uGPvi5vXil9kr3LH2Swee9+z8RZE+kwauIJcqRIi3Pt+PidawRDo69GdMe/v3h8zMxFJ0Y2ZSZyixXPi60Ryrs9QNK7+MCUEqNG4t/wxn4mjzZIWohgQMyWb0Y7iuShaXYAzTZp43562BmQs6OzKK9nRtZk/0VzoT/RxUrwlWBGPI0SOljetUcK1vCBJZgz+TM87+750iZ/zhzMW8OFfI+925Ezh+hdtVarwUYmb967AuHRll3kirnvhI7XFklexKagNLjCv2fi5hoJYcVf1rv8ecG7PUaRd7mfE3e3yJeCToM8xPwvTCGxkMF0iZx3iVvRkNY2s4376WFnQM6OztKUdwX/UiTLUpibKYpCiXEU7sMOlnft0aI9UrCGcuZApn7EeLf+6jOTP2MO5iyhA1uk594V3sGy0wRDrGs0am4CNgS6SqOT9K5JfKHklowPUM+7VuDPd9kSLSs/gUHpEjAjKvYrYVEYK++OFLFyM0m3wnnBu72lSe+yfxIlIJrI/tzICxlQlyjzbvcz38b99LAzIGdHZ2mqXRWuUnnvitPgKMlYp7x7UH7ljBUd0YItnLcGs4ecd48+Mwcy1mDeFi44osWD8lFvvUthMhRdeFh9cgKW9atgOnuV466MWNFE4s4c9y5rWfEH7jPfqfjj22PsCS73fDfEq68mFGoF84qe777TJ++qSAj222n0LvqVSWlX8DtjpxAXQpg+ECj1Lr4Vgltn3uMktVbHzsjdRXM2FVfL46sTHQjSjTh9p67W6rRqbFkyCx9sBuTs6CzNelfqg/gzRVHENAoz1invFiqvXLGiM1qwRw5sIcy7h0efWYNZWyhvjxScsdJBpffeZUCPeoXPt7BTlPiATda7FKXTsAnwZNJXN9y7rA7ZMijBu1gZVOYZMBvvhIRp1uQLvoNU3pWSLnWqvWvSqnGRkGbhkPIr87fw9z8Ij3eVe1d0pmFq5M5djU58K4yd/8SqeOHSGlR0CXwvrpMYyPsbGQbk7Ogszb5HRFQp22aK6GCpNMpXqiSxtHeP3PGSK1Z0Rg/s4dzh0eecd22hnD1y4IwWXfFSoY/eZcsN4iIC73rHb4rVwLvMvW9r3kXyW8TMJ36+K/KuvJvpMjG/AXM0JFuPPTDepTD1EvfbqfQulHdZ2FOYf+ssNp/MmSuel7A67H5aMJfUAybiPf2g7WhpBuTs6CwKn2SJ0+BT2OuVzCzENDJ0yrvF6pEnUXLHS65YwRnJH77me9cROXBGi+6ee5d3XaJ9ym9jgl/ROO9K3iJzy+W3cBEsWWE9My2/IuZOUXn0eybeC0WC1svIslyaxeNj0lPbtWNmFnGt9YB5l6IosXSp0+xdeL4r+JN8dvFrBeS8K13EJ95Py9yIE7w7EPUHLTAgZ0dnOen9RL5ZrB55EyVPvORG3sXLu/ZQzhk5cMUK7nipWO11eRd7NoMbWHynLFEV19i72NMlwaNkel2S7aoIL9qS3t9lp4jf1hWnETZgZt/ZxZox8+YVPd9Fa+kB0K6KB1mN/Js5/t3eaW3PLLp1Zj/iz1kl65kJ85JWx95PS9+ICz/ILnywGZCzo7OcBu/6EiVvvOSOFVyR/Cu8vOuM5F3RA3es6E2UitWjN/pWzzwQCL07qAHe7RKKvCvxABb/plPv7w6CheW8S94V/FtnLrH4tkPUroo4LyWYi7c8yRtxwq2S9MIHmwE5OzrLafCuP0n5EiVPvOCOHXDeffX6c1ck744VPPGSL0mBd8G74F3or0rAgBya08yJPAQn27t/8qdvlmpHgRTlT5Z88aJH4F13NO+JFbyJki9JlcC7MB4RA3gXQAzIoTnNnMhDcDq8Ww6kSv5E0Rfne9cbO/Aliv5kKZAql2rgXfAuTTweH2mGk+Tdpjb8NHAs6voH6DEn7xCceO9StaNQuhxMUYFU0Z8oHPG8Gy/4EsVAkgqmyxR4F7zL0NmBrBv+KgbkZwM/AADoDSffu/WjcKYcSpeDqVIgWeS8e/T6c1+i4E+WgikqlClT9dfg3WbHewdwpA79cHm337kAgJOPzOWiv3TKu+X6USRbDmXKoVQpmCwefcZ697PPA8liMEWF0uVwplI+9d7t053fiYK4Y8G7AADgSHm3Z1cqqTO9g96NZiuRTDmcoUKpEs+7wWQxlKbCmXIkC94FugV4FwAAHBnv9qBmTuZM75x3X8dylWi2EslQ4XTp6LN/Y737b+E0FcmUo9lKLFetHIJ3ga7QinexFzOFHTLQX/L6WqH77JV6L5Z9Y5P4Qi2WDfAuAPQAee92e+098G7l8HU8X43nq7FcJZqhXrPeff3Zv4XTJc67UN4FukML3uX1/yfsCd+kVavVamGCxv1ASXUghWVDxrt4jxYKNxwAACKnwbuJfDWeq8RyZaF3I5lSNFuO5irxPJR3gW7RgncJPSZyffHqNILR5BT1eyzdYTKWDeJZpJKg4YYDAEDkxHu3evg6cVBN5KuxXCWW5Xs3mqGi2XIsV4nna+BdoEu04F1CaZT1JPrfpFULSrny4/zIDBCEZUN8FhEtK6NeceeHDRIIuzoUJBVuEmnhojsIweh7PDRa0ZTWOysW5FC8MryDZkGXmKS+INvNk/DxhHQyhZ1FtvC8gzSveOs7sfeHmNPg3eRBLZGvxvOVeK78+nPMu7FsOZ6rJPLV5EGtevgZeBfoBi21qxIPZMGVW2n9NhhXtdHAcxIDYwjyJuVX8nTpuwBuqwTd8+NXcv5MOo1Ko9Hw6s6FC2f3kviWgvQEm9l3clOaQTqH/D/5Twb44yRgWRaPLdF0dvhPH6T82mg8FckFKnneQV6mxAAYAzkYRg9ox7sj/EHsRxSPaY/P0n3vfpYq1FIH1US+ksjj3v3832LZcjxfSRxUkwXwLtAt2mrPzL/0icaGxNzZhfKuQK7yf+LrpIiFUD6EgXl4MyEl6jitSS5csCoTN1AeH2xZklOaQZRD2UOgZdPpNKL8dcI/TZVilXiXOLHh8w6p2QlDNRBnOxW06V183hak0wPv1l59lirUUoVa8qCSyFc+w70bz5UT+UryoJoq1GqvwLtAV2jvPSKBbbjilUmr1mix4loXnu/iZsWrT8XfirNAF0WxcilZ+1LlXbokSi5BiwvGAgsTlKG0kKcYUQ4bHAJG0HxfyeaEq5Jl/a3RoDpr7iveLifbHK/aZSo/tBp20czXhF3W/PMOyY3i3wjKb/hJ5zR4N12opwu11EE1ecD3biJfSeQryYNaqlAH73aPpnouHQQ6exAbLlCcgFcC5Fc/CgZrlqjk7Ex75ja9i8rjaq1OPOIrt36J57tsBTCxmCTtXfozUbIdrWMm5FD0fJd/P0Gn02nE1f6NauXpT7y9RpQ9//GEuEqBq/wQTSH7j79AbH0mqecdkhvF/C1xxE8V3fAufgVruIQeeDdTrKcLtVShmhJ5t5w8qCYLtVQRvNtF0OEZFjrehVsL3uUaEIlGueX7RrJRT0fe3xWYVf5PiqxG/r2CeDPI9cz8jcElIloR7l1yXSY/jfSUpiDksNGtj0mr1ujYYmJD74o3mFh+JR5N9NMQO1XJFCKKn3fQPzHxNhLLu6eVLnmX7Y5KXr29825R5N3PPv83VMOcLtYzpcP60efg3S4hc5gHkEHwbl8gHiaxXOWmix/BmoRtiIQlbZ53sSKR+Mah8fNdSR11vI6ZnEPBQkWveJm0arVaWDktmZ0G3pW/acBq2zviXeXPO6S2Sfqe6BTSPe8S04iX0G3v1o8+y5YOs6V6plhLF6qcd48++zycLoUzVCRbieaq0E9k9wDvDrt3VQrfI+JVuarZ1lx4Wxyp57z4Z/IVW7hw9ntCyZWfoivalc0hP2NiX4rWz78dQbuJVM+M1WjLNAznlXeJ9cwKvEtYIJY9yecd5H0kLv2fak68dyv113FivxlU7dX0TmDGGJ4zxRYtiXi+Ct7tEuDd4fUu1WS/GdgrtlrsKSL9oitWf86URwnV4/z6c4q7aCt/f5d3be94HbNUDgmlWOmnzUTPCbZP8HRVuFXCSmbh4wlivTTRu/SshNegSXtc9nkHcXukHnycVk68d+P56qotuWJNLJojC3uhcv2I9m6uVLs2abo+Y78177677PPES+DdLoEdHsEFT/qRD++SQSq6iO6mVdzjRPGluQnAu0QaGhcYAk7pazsDR5v9ZgiaUBHbVfXXu95E6dFa4OGK9+6iY2TOmqfqtHezpdonE/tXp6w3Zp23F72uvnm36ypiFivuTaZHp2Db3iU9qcNmYbeNUPvWPOBd4GSB1zKc+pLmYNB+f1XHGGgK3q6q4QWn2971xIsPVnz3ljwj8/Zb05Y8Vf/fWO9emjBembJen3XeXvC4YsPlXaUqEs9N/LMB7VUNtetdtVYr3WJV2E6n7SyDdwEA6Crd6CdS+WWkl969PW+/ibz7W6x3nxuvTFo/nXHeWvA4Y8Vh8m4LKhKWhnt359u+d03iewsT8/4CuVgL5d2mAe8CQG/oUv/MA+Xd+yu+u4ueW3MC7xZrF8eNn0xaPp1x3Jx3D513W1IR1vZf2OCCfdGB7hBHizfpIKTHO8ATPFGV6fi31Y0Vd4iAtdogvsLQco0aeBcAgK5y4sdFcMeL95Z9dxbdt+ZsN16ac1SN8+6FMcPlF+Zr0/ah9G6TKiItQGRizldYNriGmqQXG1SiYjdpt7TvXUrQ0Q+bVWLb0jYK8+BdAAC6yunwrvfOgvvmrO36lDlX4rxbRd69Om2/Me8aRu8qVxF/CXh9NL62CGgAACAASURBVA7ebawJ715X0Wt/irzLT0RuESb5FV0aF07nebZN6VLgXQAAusxp8O7dJZJ3M8Xq+THDpQnT1Zf263N99G7XVSRchA73tGzjK/YN+Y55l3+XIerQR35jea/oC1bNvUXUbiNt8C4AAF1FxrsjPaHr3o0V7y55RxbcN2Ztn06ZeN4998xwccJ0pc/e7bKK+Ji0EmNm8uqT8dlxVZPqmZv0Lq+Uzcst/x17ifsPQb5401UajQZfSovlXvAuAABdReoi0/He5mUgZqyD3r2z5L0977o+Y702KfDu092Lz/evvLR/Oudy9M+7XVWRsPAn9DG/1xt+SVquXRXR9Gztt2S7qiEAvAsAQFfp+EWmU3TKu65YcWTRQ/bux093Lzzf/2TK9umsyxHto3dPOMN1QQfvAgDQVU6Dd28vum/NuT6dsV59sU/w7uUp27VZJ3i3ewzXBR28CwBAVzlF3p228L1bqH70ZOf8+P7lSfBudxmuCzp4FwCAriLTrqo3dPv5ritWvL3gvjnnvDZtuTKxnxV499z43qVJ29UZpx282zVGRkbiQwV4FwCA7iF1kUG66TY9aM/sjBVvLbhvzjmvvuR7N12ofvh459zY3qVJK3i3q/TsJq6DdHDzwbsAAODIe7fba++Jdwu3Ftw3Zp1XX1ouT+zxvPvB4+2Pn+1dnLBemQbvAt0CvAsAAM5p8O7NefeNWefVKcul53vZIubd9x9vf/Rs78KE9cpLpz0C3gW6AngXAACck+/daOHmvOv6jPPKpPnScyPPu795tP3hU+P5CesnLx028C7QHcC7AADgnAbv3mC8e3Gc6N3n1svg3W7Sal9mfQOe7wIA0D0Uehe/KHVw7TJnelPXIqnl0N6dc12fcVyZNF8cN/C8+97o9gdPjeeeWy5PgXe7CDo8wwK0ZwYAoKso9y7b0rOD6u2Zdz+dcXzyguBd/Qc68G7XGa4LOngXAICu0pR38T87svbeePc6490LY3zv/hp5d9xyacphixTAu11iuC7o4F0AALpKy95l/xTUP0t9YP/Fnd0z716bdlx+YbowZsgWq7R3U4XKrx/q39cZPkbeDYN3u8VwXdDBuwAAdJU2vYskitc/41/hH1jj4jXVPfCuA/Pu+TFDBveulvOufSC8yx+DqN2BZJtcXdOj5kkP/CcAPzz4OruygWgF3KJNWnVz2wbeBQCgq7TvXbzgi5yKO1gwXazkHnj301nntWnH5QnT+bFdzLsHFe3DrfefGD4et1ycHBjvcoYQj0qvcMbWVtf8jM17lz8IYaNB6lvfKLVaMJwieFcB4F0A6A3d8y7xX/HsXfduhPbupQnT+Wci7/7mieGjMfPFSbt14LzbhhdbW13XZmcPT3Pra+NmQqth5tRp1BpNU8sB7wIA0FVa8C5bXSyeLqh8xj/317tXXtovTZjOCbz7qweD7V12AHmucpYZnV6FD0+v1urwMef5tbiCeeVWh82MZjdp1WqNRo1m1mnVzFKw8q4WK7TqNGgdkuPek/3H5ZDZWGalXK75W6HT8KbzVobypqPFq9PgO0cR4F0AALpKa+/vCsq+gulSigXvNkIoQlF9LvORMRxTGU1Px6umURLCvLzFSz1NZtcsMD2eIy4NmleoW3y3SHuXm5/bFnxdgqzz9oCOUBXP22c6TTP14QjwLgAAXUV5f1XHGOLEgunEz+KJvfHutVnnlZf2i89J3n3v8e5HY+YLA+pdnUal0fFbP6l4TmJmkHrgSpxXcnX89PgCBR/4q6N9K6ldWe/ieRBsBf6BsBU6jYpX1KZvHrg9o9GhLIF3lQHeBYDecOL7iXRECtdmnFde2i4+3//4Kd+7/3p/673Hux+OmS+8GEjvCguUoqQ6kg4FqWSaLhE0zy9WKvMuMq5OIyk3uee7Sr0r2gqpBlP4rYhazdSWg3cbA94FgN5wSrz7Ce3dnSHyLmsbTDuCj6x35OqZCfOSVkfxSqyCWmp576LSprTbZNszk+qZBSsl7AH6P+xOQbRR+P4D7yoAvAsAveHEe9cu693NXz/e/fDZIHkXq07FJMk2eMIEImhdJdWuijgvJZiLtP4mvCvwn2S7KsEqhC2/hLpFOWcfHuPZYmfmmlhJbRR4VyHgXQDoDafFu1O2C8i7hUH27rAi/WiXoqhhu6CDdwEA6CqnwLsHyLvnx/c/0vG9+y+Md8+Dd1umQR0zRQ3bBR28CwBAV5Hx7khP6IF3r2LeTQu9+wi823WG64IO3gUAoKtIXWQ6MZCpUogZ64l3723++tHuB+DdLjNcF3TwLgAAXaXjF5lO0VnvXkbefSLyrpb2rg282z1GRkbiQwV4FwCA7tHxi0yn6Kh3HZenbOfE3n2X9q4JvNtVjoeQDm4+eBcAAJyT790w8q713Pj+hyTv7nzwzHR+ArwLdAvwLgAAOKfCu9PIu3vgXaAPDJF3+1m5DwCniUE45cV0x7vbJO8+Be8CXWRYvNvbinwAOO30+4wn0GHvToq8m+R71wLe7RpdeP2su3T2IDZcYMfXCAAA0AJNXYtGlHh3jODdDeTdc+DdboIOz7DQ8Sog8C4AAENBB717hfXuY/BuP5A6PIMJeBcAgNNJ77z7Pni3y4B3wbsAAAw+nfXuJSnv/moUvNt1wLvgXQAABp+Oe/fjvnmXP7pfM0PSdRA02K0gV3KDCHUQ9vDI5kFuUCN8nEHxSIedBbwLAMDppBfe/eXdXnkXl22Tw8F2irZy0V6e2cMjkQf2xkRCpCatGhucFx+2txvmBe8CQEO6+T7BqWAwT/mmMjaizLsfDIR3+wUvGz3NE3d45PIgVd41adVqjYaQ3S5tA3gXABoyMlQvKQwap6HfjAHzLvqTtgmqeqY/qLU6rZqpi+Yqhlkh0bWtXEUrSsEtSqPj6rRlPcV+FKTHFqVlvlFrTaT0Gh2zHK0Gn0SJDYodHlIeKPJc+GSSYqG8CwB9Q+qaCyjhxHvXFj648rLv3sVFyXqXVZ34A+46nQbzK18+gkXJWY03Davg5afnFsVYENmNyxKtOvqTSatWYfW+EsVP/PCI8sBC9C49kbjpXXpUDt4FgIaAd9sBvNvH8i7fP6IPyDk6jVqr06rpTyZ6CXgzLUJhVKLIKzC6OL2OzaqJK3mL8ywzRWK3cIdHkAcOgnelJN096VLgXQBQAHi3HcC7g+tdSqdRa7UaVLXMyJfXtle8qAY1ryatGpOrOD2pEMoro7fvXUEeeKsSZJ58H9FV6VJD4l28gUZ7uQOAVgDvtgN4d4C9S+k0Kq7aV/S4l1Ewl75xa1+TVq1W45XL/PQ8hWO50UnXMzftXUEeWOTeI+Lvku6+/jTg3kWuxdtogH1PKuxhVXKbRUyjfKJgesNfFHi3HcC7g+xdzIuYlXjFQEGhk2t0JeFAYWmRn57/wFeuXZW4/pfnRql2VcQ8sDmRfJcXqwKQr0nvAIPsXda4+EQ0peEqlCy/Uyi5ane1vH4ybkTYHwb6gCBuGpooSEOcKLM0fDpCPm/g3ZYB70J/VV1nuE7RwfeueHrDPCvJg5IMyIMvREl+ZETSWsaUZ2AoEHgXny6VkgXtWMFc8kvryDUXUMKp8u77JO/ugne7zXCdogPrXcFuFBQWZbKNl37azEPDHCq/gZAXSWsZO2EnoIwpBZtJ3HDl3iVOZ7+VytsQndSDBngXvNt1husUHQrviutp5b0rKP0IahcpvsUFS8b/FMiemBJfvlRlsoxIpJZJXFqzGSBuxcDSe+8SjxfxdzVcJ/WgAd4F73ad4TpFT5h3R5iHfBTfRrjnWCuztb6Cx4SCr/DrslRK4qKkNhm/9Ddc+zHp+aXCDLB7rGH99iDQe+8eYzTM2xCd1IPGafDuJy8dl16Ad/vHyMhIfKgYfO9SiuuZxYolTmzqK2IJSZxSsF0y5iAuULxMqa/Y5ctkQHB7oXy395G+eFd53sC7LdPxi0yn6IV33+W8awfvdo/jIaSDm98p71LSP3SZ01isK6pD3hWUJsUpZbZLYZFLvEziV1LLkdkWcR4GEKmDQonqfsX7kzhRfmng3Z5xSrx7kezd+xta8C7QZTrrXVQixyfKlNFxNbKuoviX4Ha8K59SfH0nbrLUpV+cVamvpBKfJO+yUNIPXMVplE8UTGeP14hEbTx4tx1Or3dTyLuPwLtAd+mgdylGooJacYXFSkp0KRdMYdPgF2Up71L8KzW+EHECSlTP3PArivRYWkohgsRSGRgZKu9S2J7Bb55kEovTKJ9IiaqmBHnAAe+2wynx7gUJ725qH+9+8Ay8C3SRznoXoeQqzKaUmsLOLr7CSl15ZVIKvpJalJJNIHpC5iti4obbQtw5gELAu+1wqrz7GynvngfvAl2jG94FgP4C3m2HU+3df72/qX1s+GDMdP6F3QreBboDeBc4eYwM20sKg8ZgnvI98e6DzfeQdyfBu0C3AO8CJ49joG36fQwJ9NK7ZvBuVxkZNjp7EBsusONrBAAAaIGmrkUjrXn3Vw8233ti+BC822VG+OPWDTgdrwIC7wIAMBT0xrtbv6G96wDvdg90ePpQj8N/30YJ4F0AAE4tvfCu9qH+N08MH46bL/TQu72v5+w7/fWu8sQon+BdAGhIBx/rAL1H6oIj8xUxceve/WjccnHSYQsXe+bdHtdz9p2Rfnu3qXwOhXfxU6i93AFAKzS8jgEDi8wlrgferWof6t/XGT8at1yc6rV3W1GFSatW0Wh09N8aHf4l+5dOg/1BmbRqtdakcBtIq1PhS2se8K78Apv9rQsueWBfoPdIXXOBwafP3v01491Lg+FdlUolrQqdRsXIkxEu5lOTVq1Wq4UJaFr2LjtXwyXIJhBusv/cGUbnZ6fpv89O41+yf02fxf4A77LGxSeiKTInUsMpbUJcRWvF8RH+6LkdAW5KugF4d3jpp3fTheqvR/Xv6/bOPbdemnLYIn32LvKQpCqIYuNcrNOotTo2iU7DK5+2713hEuUTC+Fv8vRZ1ZlzftaxZ6ePj/3nzmCTzpw5I0wA3mVTEn/oTZ1ILVRrN8wVvsAR/mAMyrU3gnWz3H4O8fV2dnsBCrw7zPTZu++Nbn/wdO/cc+vll33wLrIsLl3Z8q5Jq1aJ1MboEP1v0qqZCmheyg6Wd7nKZ3ZNGg1bH03WPt+7mGM5OBdPnz1zbppNMn22Pe2eKO/KX+mksi0odMq3qmgNsXcFy1d+V9HBjHV8M1vLQ8uP4dufpasFffDu8NJv7z7a/uDp3vnn1ssvnX3xLhItLl1ZVbDSE/qQEa5OQ//F12wHnu9y1kVGpT+xNwNNlHf9586oROZlBIv+9587w1RAix3djndVJAT5PJHeZb8i/jnCH/RNPEXwWTyXvHeVr0tQzyzwljgz4tmVLE1qCR0H7QpEC2tp9ncovsfq3p0HeHd46bN3f/N4+8On++cn+uldgXRlvcvAf9Sr0eGlUbXWJKoT7kA9s2gK+ixYc6NNxtWrUqlUnH9pwzLCnT5L/9Wmdgk7U0q6bD5PnnePsWF3xavDrcBeuI9FI/UKPgvmauhddrEN13XMjNYnmOVYejxdmVxJLY2YgY4j3jPdWAu+fKnj1Y11gXeHlAHw7rP9CxPWT/rh3WNRSVdKFSIws+o0Ko1Gg2tYSxd+KWVSlKSL3mXgP+o9O82KFn1ou5ZZYmcSpUuddO8eS9iL5ZivMSnVSc0lvznyyhQsR96yMlOIuVLi7C4pSmbPsFll/8ST4VMEKYlTBNulZHXsn/ILl7pXAO8OL/337kdj+xcmrJ9M98e7x/ynvDKq4LVQxsq76JUh/gtE7JdMOl56xRBUSqpnbse7+PPb6bOqs2fP4ho+Rxd+20HqFyaWLpvPgfUuJf1DV3IijZDGsaeUFSgFU2TmktqcpiTagndlcqV8aY0PQJNI7ZkRUuGbmD1iSsEUwfIFG85+K14dvnyZhRP3DHh3eOmzdz94svPR2P6FCdsn0057v9szN1SFTsOW0wSNlXGr8h1Lz9OCdSVUKnjEbMKbULMZk2tXxWuhjJV30StD/BeIxI+Bm+YktatCKVF/lvhE+WHFxFdh4nVZidiUCEy8OfJekVpXs5npiMWVHIKmkPEuDjuR/fdYdPeAQFPE84qXL94n+CxSPwaZhYs3Dbw7pPTfux+P7V98YbvSW+827CW4G5eAPiK41Zg+y95A4OVZQXsrnpNb5oR5l2LKIoJfi/z1kf2WqCji5ZgSSUI8hTiXeLH4evEpDU0pXpE4MzLbQon00zADCg+BcmS8KPihSu0E4r4VzytenXg/oMQNvSu1cPGmgXeHlJ5695mR4N1z44x3oz3yrhJbdOMS0EdGGhXxu8fJ8y4C30YliWWmCBYl+ApPI55CnEsmh4Ip4nWJv0LpBXcPeGKZbSEuVj4DnUUgQgq7BRFMl0ojTik1r/grsVzFi5XR/IjEk132W/DukNJL734k4V3TxRe2KzOunnn3FALelV8g/GyIEAvNw4XMJhCnE4vg4pQyy5T6U1AZIOVd8cKl7AveHV767N0Pn+ycGzddemG7OuMG73aP/np3pBnAuwMFfij7nZcWkdkE4nT8T/azOKXMMmWWhs+FL1x+dcSdD94dXvrtXd3OuXHTpUnwbnfpo3ebGKSDAbwLAA0B7w4v/ffueca7DvBu1xhR0JRsoADvAoA84N3hReYS10PvToF3u0s/Crrt0sHNB+8CJw/w7vDST+9mMO9eA+8CXQO8C5w8hq4SC8AB7wInHPAucPLoRyUU0EmIh7U33t09P266NGW/NgveBboFeBcAgKGgg969zHj3vUck714G7wLdBLwLAMBQ0EnvTsl49zl4F+gu4F0AAIaCXnj3I/BuT2iq54rhpeVHJg0TUAP2OI14svU7UzyGNIfAKWfwL1aCxODdwQUdnpNNO00EFXq3j60fcaRONsihcqRyCJxyenOpjPekPTPmXT14tw+M9K+/qtZo9jLaM++2fgw6h7zVep8fMcObQ+CU05tL5SB5Nwbe7RbD6F3liUca9eoM3u0xw5tD4JRzurz7KXi3mwypd5vaOvAu5FA54F2AyMnyrv38yfSuSatWqVQaHe9vtdbU0mIQGh1FmbRqhQtRlhK8K7808G5nGd4cAkOPTsO7BOPXVvxSLQF+qZw+y8x2dpp4mRInaDhLw+tbh707cVK9q1Zz5kPHuEnvmrRqbBadRqXSaHvg3emz7E/Df+4M74fiP3dGpTpzzo8+og/sN/ifXeNkeHdEetxy8VcyicUpm7Ua3pCy4cIVZqNTORwRDR2vcBUtZ48C755cdBqVRqPhLor4FVLB1ZK7VHLXOomrnjhBw1kUXN867t0PT6h3tVr2KOs0ao1GqTLxRZgaT1M+txi+d5FmMdP6z505c4b7naDvwbt8mvodNlys+CvlP93WvMvuW3ljSWWjKc816118jQr3Q5v5BO+eUExatUZH6TRk1+o0jUq83KUSK5hgHzHECRrOouD6Bt5VADqozFHWadRaHX2YdRpe5QZX+WHSqgU102JxshO5ShJ2Dm7B/BppnYYragt/Xo3Lu2fOnTvLGHX67JmzZ8+Ad/kcN+ldJAApDfTFu4K8KcxYs9lrNocd967C2cG7JxCkXfyqSi7vSgqYvVTilzq6pMJeElWqs9PCBGfO+cVTWri+gXcVgA4kfTh1Gu6zKA1F6TQqtVanVfMPuJx3TWxi5pMJm51ZHlq1bO22Eu/6p2nxTp89c276nLx3uccY8s8xWkXwu1SREGzdAHr3+PhYLBUWNF08RcmS2/cu+6eg/lmcMTwZcZY2cyiVN2LduMwObCqf4N0TCa1d/LLKe77buG5Qyrtnzvmnz6rOnJs+d4a+5IF3W8x0B+AEqdGhWyhCURUvhoqe7Mt4V3ynRpS6ggYDirxL/1Kmz+K/ILZOmgX7NfnZ32CnEf8upaRLDaR30bX+mBGDYOIx42PxFIUL75R3BRlgv5KaTvyqzRzK5I39PYxglQfi3dVCPsG7JxF+Gyr2OtzMgz8Z79LFDf5VE/8M3u0VzEFF7auwGg6sACowsfBHIP18V6l3ke3lzKvIu8f+c2fOTqPJ/gblXfpzl6wr8bskSpcaVO8eYwXKY0wk+ERiMiUL76B3BSVI9l/idOIsbeZQ3rv4RKm92kI+wbsnELa0S//BXppb8S7hYS3e8IWYYFie736o2zkZ3uXEx3mXVx/MVhqLa4Sl2zMrr2em5M2rzLt0+yr6F9bAu920rvTvUixdalC9K77oD6Z3BXsez5h4OnGWNnPYjndHSFUISvIJ3j15CAzL1UW25l1h42T6ijd9VsWbjH8aivbM6ZPkXdEU/mMFjYZrTCV4v4yeCW+ERais5ouZ1K4Kf3e4lXZVTK3y2enjxt7trnWHvF0VLgPECFYFiq+xL94d4deBC6YTM0ZJ67D9HLbpXakp8vkE7544RCUaVBQhe7dxu6pj3su45+jGVMxkpimMsJXLAL6/exK9OyQo9S5LA+/iT3270r552L17LCpdHUu0opKpC5VZfpvv7x7zPYdPF2eMIj2oJi6q5RwSs9dwosyUhvkE7wJESJfKnl7fwLsnh978mDrIUHuXItmInYJvptQUeVrwrvxaxPkhTpf/qs0cirM3wq8olklJnCKfT/AuQAS8S3MM3m0b8K780jru3a7Smnd7SUdy2NVzGbwLEDm53q3wvTsO4xF1nWH07kgzgHepk5jDhgelZcC7ABHwLk1T5yp4l8jQeVc4TrQCwLuQQ+WAdwEiIyMj8Z7Q8sVKkBi8O7j07MfUX8C7kEOFgHcBIr0sXRAzAN49OfTyx9RfiJsP3u0xw5tDAOgvPfduFLwLdIVOebepR85dRcpq/c4Xx5DmEAD6ywh4FzgZNPxVKPnZtPDIuatADtunqV8RAPQA8C5wQuiIdwEAALpNp7xrRd59bgHvAv0BvAsAwFDQee8+Nb43Ct4Feg54FwCAoaBb3j0A7wK9BbwLAMBQ0DvvXgLvAt0EvAsAwFDQae+aP9QZfz26xffuE+RdG3gX6B7gXQAAhoIeefcceBfoMuBdAACGgt56dwa8C3QL8C4AAEPBsHoXAMQ09C4AAMAg0CnvXsK8m+qqdzvQwy9wQoGfDQAAQ4FC3w2KdwEAAADgNADeBQAAAIDe0dC755B3H4J3AQAAAKBt2vPuJHgXAAAAAJoAvAsAAAAAvaNF734A3gUAAACA5mnfuy7wLgAAAAAoBLwLAAAAAL1jGLxr0qpVHBqddDK11tSB9QEAAABAtxgS73JCNWnVEuoF7wIAAAADT7vevdpr70r7FbwLAAAADDwtevf9Jzsf98u7lE6DSrxc/bNaa0LJNBo1VhuNz8h+xmutwdMAAABAbxkU7xKHd6C/E3oX/Y1NZScwT3/pymiCd7Fqav5iuz5WBQAAAHBy6eC4CL3zruTYDsTyLr+xlUql1ur4lkVpBN4lloCZ3AIAAABAC/TMu/uXXnTYu+TviM93xe2rlFhW2rsAAAAA0Bq98+7FPniX9S2/xpguAfMmcE+CKYrSaVSy9cwAAAAA0Bqd9O6kjHfHeuhd8vu7Oo2gXZWowRTW9EoN7aoAAACAbnDivNslsMIwAAAAALQMeFcGtogMpV0AAACgM3Tcux/oDCfGuwAAAADQYcC7AAAAANA7euTdjwbDu3gzqf48rkU5EK9b+IZxp7PHVZlDhTkwWLRyVrbwfsGpOgUUDg/T1AJb2G3EuU7VgZCgF979zeOB8K5Jq8YOtE7TVfWSf6biHjok0rf82pLkD53ZVv5eIM8LL00BvaLFs7LZn+hpOwUUDg/T4gLbmOu0HQgJuuFd7UB6t7cHUNK7gv44pNK32n6asGzRJKlln9CfODDAtPqba26+03cKdOo+vs0lkHvtxRKc+AMhwanxrszARHhljEmrVmu1GmySeApvLnahXO0J1y+lVB2LeLrUeSJaETtB+LeK6XVasHxiX110qRsfGQKbl7B2iZ0jzg8AKEfirMRfJMD6smnhrGSnn7JToPHwMBodhZc+WQHqNEw3uuLLIGGHEA+WVLcHp/BASNBh746TvbvdM+8Se6CmKPmKX+yTiRsvQTyCAjZeAn+UBd4PivvhElenItakCZ/vspkSrAg/f/iDOUiVpQkbzvZZjbkbX5hooyR3jjA/ckcBOMHIX0SIs0j8OEXnhdT51fisHPpToMW9Sthk7lrG2xw2nU7D8yvxMkjcIfIHi+74b+gPRMvIeKpT3r2oxLv27ntX3Ak1RUmc4fhEsbdkpvAcSbIsaXX49UErqF/hpcdOCsGKmHWLCruyOZG8x5QYGUL5rqD4+WHoVO/hwFDQ8CLS3Fkp+GE3vJuUOitN+NKG7xRofa8SdiyjN2HmaVnpNGqtTqumP5kkL4ykJcgdLPEN0BAeiJY5dd4lfSNjQuyzUu9Kj7IgvTa8KodQFYZPQEkJt5Tc90x9dqOciCexC5fa0iZ+6/z8kLIKnHgUGoL0DVG8WClJ/MMTzyd1VsqsZRhOgTb2qkSJn5h5nUat1WpQeZGRbzPelT1Ywh0/lAeiZXrm3Y8H2LuUidBy0kSovlB2Y8UfVAE/6SXrmblE4mabxPtT8Yq4bRBdbMR3jvjCxG0IiRuBL5tYt0O42PHmAU4h7RiCdFbKjlAiPr8kz0qMITwFOuddditEm0NRaNcwCuY9PSVdBsVLkDtY/IPLrm3IDkTL9NS7TwbVuxS/RkTYBEB8yORurPijLPCmcC0WRLddzMrEXibcGOLLIVQtM8kFCYjrJb0zZ9Kq1Wr+sph58R+9/M4h5Ac4dbRlCNJZiU9RCc84fjMfSv6sxBi2U6Bd73J7ELscEPLKV7CoYQmhACrai8KDxaVREww4bAeiZXru3U2yd69M99m7AMeg3BQCQ0+b3u0bg30KDOtebYHBPhAtA94FRJzQ3zrQe4bVEIN9CgzrXm2BwT4QLdN17/43pd51jmAQywAAIABJREFUgncB4IRxigzRQ2CvDjs98W4evAsApxEwRDeAvTrs9MC7llD+4qRNzrsXwLsAcBIBQ3QD2KvDTi+9+z7Rux8+278wAd6lqH73nzJQ9OtI9Xu7h5WWT7qGCQAxsFeHnXZOGUHilrz7CLzLgXYiEI/H++jdfm/98CFzvMAQ3QD26rDTG+9eeGH7eNz0mycG7QPk3f8DvEsA7cQGPYwNG/Emkb+OwyHoNp09XmCIbgB7ddjphXeD+QsvrB+Nkbz73uj2h0/BuzQn8qL//7d3ps9tnPcdx9+QF5kkk9qSHFm2K9l5U8zU05lmmslMpo3tRHaa6dit6URVqzay05m+6DS2rIuCbsmK7cSHCBDEQZwkJUdNJN4EQNwkrcsSbwLgAYAkKNu15XRGfbEH9nh2sVgsFge/n/mNhgIXu88+1+d5nl3uUp2yQqgcgHdriLblBUNUA+Rqo6OPd9+ivRvhezdPeTd+oWcC3i00aadflkTh3ZqjbXlVYohKris3N8jVRkcn7/ZQ3g0fI813YzX3LuEhkbWgKTt9zfpx/vPtqlRSTVkEZVFX3lV9Xbm5Qa42Ojp5t3vijC9xwhU+Zh8RzHdDp72x8z0T79bOu6THrys8WvnIPn6F1+lPnn/a8PT5yQfF/3L+VxEa7koBWnpX/B6VKhbBlb0Gw94r/Hwz7L0yef5pvv6pbbgfU59c2WsQsvfKA4mvK/lcZkvysWpbXswG8nsraQgVSVUzjC6/OpV3FE2fu6R7rop6RfHrJUhIPBGeh/bZKPUAatWoK7tS/YzqJiPYWMa757vHz3gTJzrDx2wc7y7m7x13Bk97Y+d7xmvnXX0fRFaedw1F88K75PcylY/iIhDkE/1fUu7xx0gCYV/Zy/0feadShXJlL7tfyvqSW5KOpYqG8K7BYJBKqsphdJndQNlHaQTvyudqGYPeJPsewNK5on02kl+4VAFN4N0OkXfPeGNvUd6dq4V3pXKnOGgqvv3K1ML5SPwJ71vElxEVXzrEvFiDVyWE3n36/Pm9nFkOvEts+qI8F757hLdB2UUwKfgPIffkM1TWu+xviftQ/iHxWKqof+9SZSmRVLV+K+97qmbH9e1d2VwVy0zByZTeqjrZqNXCWIV7qA/vnvbGT3SOtgq8e4Lx7ju/v3l9brVuvEt6pyNXrkwHzvuEuy/RuyFlXr7LTaGw0xfPh4rLjGx/vXcv9RHzw9Pnr5ynf5h8wF/w3Hulxt41kBDkgLLru6LXkglG2eK3cYrf3ihfBNyckpmYlsjPSua7gosNJQ+nvXfVlxezgdSvSm7AlgXlAwo2DeKkCqoDl+Lg18Btj5xPlA6j5Y4iHKwX+JVWYpioAr1zlT4TQUMTnUvSZDS2tNDjWiObFS0tBn4nWErfFWaj1MKYYLfF2TU7+C520eIpVpKUMEK9Eie1/AKSL1zBxlLeHZvOne8eO+2Nn3COtnYM8+e7Dnqdub68K/OOSflPDFxIli1rnfnp85NsV1pc5eRcUKSvFzLzMPEPREPUer5r4CPOAWUjbqZJCPKcKQbRZFe6UKSKgKhF4eXVvVfK9a7g6/KfF3/BXXAmbik6Vm3Li9lA6lclN+AawmAwPODrgZjU0lMTmQFx6WG0/FFEg3XB+2vl91kOeucqP73MD6QRrYHzG56uBIaTyYGKs1H4STFxot0aTUlansUPiFMsfp0hLF6L6xVviEEoBdVNRrCxtHez57po7x4leNcTO9899s7vb9TGu8TCV+9dfmmUrhPCFJIWOa/sZWXJ7eJlJsSSU2SDoQ68W+B05cQcULTOTDVhQgso/p5Z2i9VKFJF8IA73BFNfIXbSCEz3y2OokovQrCXemuxzqymvJgNpH5VcgOBIQR6ICe19BSKGZvJNEypYXSStLH8HpTvsxz0zlXeCXK0KzgXdkQrOn3at4KrOlXKRuJ8V7wTJjmeFqPJYzLSPyUlE0Dag1y9KtXPqG4ygo0lvTtFe/e4c/Rox5DQu6c80XO0d+vnfmbR0EZJbeBKoPi1ytaZ2R/37lXrXf69OfXh3UKhIO7EC2V5Vyxe6sdicYpGQ+wGyr1LZdkVUbbzTrGC67vsL0sXiuyVYOKxVKFZeTEbSP2q5AbcshDrQSKpxNLlTD3EjVf8PalhtPxR1A3NVaF7rnLOgStXqRGt+PQ9LYYWD+U10hckPlOXjcTFCaIRPS1Gk6nFaEpy5FuOd2XrVT1415885Ykdd44etfK9a3IEaO9+VDPvFvijFuEyPX9tpVCQz2J2wZ9b47h75t5ar/ymnit7DdRCI2mdubR3mb6YUnB9eFeqjBR7l218wjwXFJ1oA8VFwJbD04T7qwTbqLyfWdamnOlwjee7asqL2UB+b8rvABLoQSqppGE0p5SLC5XSA2LJYbT8UYgrmZxPSu1TOfrnKnvWRiN3hVdiREsY3HhaSNP7qmQj77jsr8W7pY/I6RSKt9CSunrxHuTqFf/UCKWguskINpb27spZyruO0BGCd93Rc11jb39Uq3XmOkLau5yeXXC9T8E6M++CYON6VxcId3uK/5Cav0AnXsvnq0/eu4xbJXbLuSdO6kowN3HN7F3lSRUPo3kLk8IhsoE8y+FtQ+hBSw/WeZ8YlexTITXJVeZ0BBd7OOci513Jy53aZyN/FbroZPFuBQoW3akpPBHRHgj1ipBUcimobjKCjUt41x01OUJHrIOZHNe79sBJV/Scf+ztyzc+noV3m/BhSQ3v3U1GXXm35FsZlCe1mWjAXFX71/ZNig7eTU6tnPUnTrqjJkfgcPtgJrdR9G6rbeSkK3LOP/b25Y/h3abs9OHdxqJ+vKswwQqTqi0GErodXf9creh8yWvMmxp9vHvGlzjpirTaOd79BuXdjpETrvBZfxLeLTRpp59KpSzlAO/WFm3LqxJDACmQq42Oft51R/nefWj7Yv7e0Y7hE53hs77Eb+DdJu305R/CTgTerSHalhcMUQ2Qq42OHt6d5Hp3gOPd3L2j1qHjnaNnfPHfXIJ3FV162STUqqRQBOqohneVzLbrvEVXCeRqo6OPd0974ydckVZ74JCF491MbuOodei4E96l0XFW0wCgCBoLYn5WaIi6XRepLcjVRkcH7yYml097Yic6w0c7Rg6Z+1nvfieT2zhiHTruHD3tjV+4NDExm9/k3gWgyajcEDKmlzIE4U9TSiL7lAPy9uI/UtHr3qEa5KrUH+eoptwMr/BbnMQbW1oU7UTdsZShj3dPeWIm5+jRjpGDbX0C7w6anKHT3viFHngXgGajSoYw1Po9gIJHSNA9e3N7l/hnr6rRxLsKd6LJtzRFH++edEcp774p9G77oMkROuWNvdUzDu8C0GRUwxDUrEXCEGo7SzXepZ8xWCgUCp4WpbMoLai1d7VwErxbbe/eXT7pjh5zhI5Yh4XePWwZOGYPnnLH3uoen5ipmXdxr0FDgGJqODQxhKHe3gPIHoh54jD9eF/BE4tEb8ejX3tEeFkW+4RC5j16xBfnaZqrFXm3Ll6ux3wqsR/JxDP/FR+I90AqYpXQCN3mu2TvHjL3t9qDp9yx893jEzO5GnoX9xrUPyimhkMr7xrq6j2A7CdJ5vn4vKf4ip6VzwqY9zxF0fN+eVuSnx+uYa5W5t3iudXy5XrFVJXaD9ewUqUpeHW3OM0yOV4m+np36MDFXp53D5r7W22Bk+7Iua6x8Vp7V01dNPCo6pPQuI/zLws1t5nUJapvtOFmgbY5oLJQSM8LLu/rut2TUhkaelcg3fK8K5gwSfa8nJ+FrZv/haISmNcuSH1L8Ha8gkA8/CMW161JL87TNFcr8259vFwvKcpbQlJlv8Ur3qRwNUJmn5Whp3cPtw8euNibznK929Z31BY46Yqc8yfr07sG6Ts4NLvmoeiLnLFYOUdReZuJOqrcs6v1Lv91XaVeBVgOKguFNyZX/l1iL1PWQRvTuw/q7j2Axe2TJqPRaORP7GTfjkdMg/gT8ovzSmdayQ20vL5LNJOeL9eryLuiAzG/L766u1m8+8aH19LZAuvdwpttfUdt9KMix6frzrtsUy/vmke5KClUlX2uvn1tfXq3ZDtUjWoR8npnxdVmE3v3QZ29B5A/Z+KOvUTfkvIucZ2Zn3KppZBae5d7zjV9uV5xt8SUEBMvWlVmD1Tce9JkJFYJzdDDu8x9VYfo+S7fu0c6Rk50hs/6E/XgXYPyOzgKSpYvOJWC+H+mtMXrWPxr/sWXXhnJtxKwY2/qvoxSc6niF4utQnzXg4LbTLg3p5BPREPUzncFrZWfTkJWMPe2iHSoTaEUJOa7gpQIP+EkW/oriu5JUZJCjaiBIfhnXK33AMoN5mTfjlcglThpOCX14rza5CovB+vn5Xqc6zyElHASSeqoxQfi7aOR57vPvLgvcXf5hIvx7odC7/Ye6Rg+3hk+66sX7xoU3sFRENZFg7iKCQZW4mGteCFFjLiaFu0t2g/5KhQh3aIbOkR3PZS+zUR20lAF1F/fFTRKmWEyJw8JA2fu/lQXSkGya5F73Te34kjOFUQpFHSCxHIkplAjKjSE6udTNj5yqyDI1UZHP+/aQ4csg298cJXj3WzhzYu9R6xDps7RM77EWN14VyBdOe+KR3lCGRdntKLJLrMBUVeCaYrMYFlmP0Tvyow95T9RdzjtqMC7DOyCkniGQTxx8epi5YUi3LPELSryUwTiBjIpLJRTjtpRiSFkCppLdRJeAoM0Guy91IvzmjVXq0RVyqgy9PJu5Jg9KPRuOls4cLH3cPuQyTF6xhevB+8+KOMODpFm2NsaJQaqxcv1UteKeNtKzIl5PWzJ/ZBMqN67pQ5X/94VSE7JifO+q0mhCDZLki8mqfGugntSFKZQIyoxBJACudro6ObdVlugpHez9eDdB4rv4CD1y3zxJtm/AxP0lxJ3Xgh3xfwouaRZcj/cddMCc5uJ9AJmQaZPFx2uQdaZhXNL3tmRskLyZhrNCoW3a9GBuSsnZa4zK7knRVkKNQKGqAbI1Uan5t69RnvXW0feVTqREnZYbI8mvB2DXdtjNhdsQPgrUN5yIE8V3I0l7uAQJZPdk/Bem/KmfeLbTPg3p6j/G2NFqJ7vcu424uYb6XaMpMnI3CZV+rKs6kLhL/aSC4XwCXMU8aoyZ5bLSyFvGyO5HOHdRgO52ujU2rsfXD3UPnjMETrtjY9N1dK7uNeg/tGjmKq8VL7ZgCGqAXK10dHTuwfNIu++8cHVg5bBY/bgaW+sht6VmUJxEXzLIIHCpIJyUVdM5QHvagoMUQ2Qq42Ovt4deP19vndfZ73ridbQuwCAagBDVAPkaqNTF95ttQdPu+FdAJoNGKIaIFcbnVp79/0/HrQMtNoDp9zRJLwLQHMBQ1QD5GqjU2Pv/vr9Px40D7TaAqfcEXgXgCYDhqgGyNVGpw7mu0XvrsC7ADQTMEQ1QK42OrX37pvmgaO2wClXJDkJ7wLQVMAQ1QC52ujUfp35TXP/UdvISXgXgKYDhqgGyNVGpx68O3DUFtDHuwAAnSlpCKAC5Gqjs1m8q/CpCwAAbZFpsLVOWgODXG10ylUYceMKvRuutncBAACAekZf73aGE/AuAACATUyzrTMDAAAA9Qy8CwAAAOiHZt6dXD7hisK7AAAAgBx6ePd1eBcAAAAoFAraetcdbbUHD1oGX/9A9D4i2rtueBcAAMCmRlvvHrOHDllE773neDcK7wIAANjMaOjdk5Le/VB77wIAAAANShW8e03o3YOWQQ29q89zRgAAAIAqoYd3W7XzLgAAALAZgHcBAAAA/ajMu3Z4FwAAACiDCr0bhHcBAAAA5cC7AAAAgH7AuwAAAIB+wLsAAACAfqj07hvwLgAAAFA+st5dOemOHnPAuwAAAIBGKPJuO8G71+BdAAAAoFykvPtsSe8esgy22kPwLgAAAKCcUt6NHXOMHmofeuNDeBcAAACoGMXe7YV3AQAAgEpR6t2L8C4AAABQMfAuAAAAoB/KvDss9O6Bi72Ud095YvAuAAAAoBD13j3cPtzqgHcBAACAMtDCu1NZeBcAAABQghLvHpby7jF4FwAAACgHeBcAAADQD3gXAAAA0A94FwAAANCP6nrXAgAAAAA+1fLuPgAAAACQqIp3AQAAAKAQJd4dgncBAAAATYB3AQAAAP2AdwEAAAD9KOXdD68dbh+EdwEAAABNgHcBAAAA/YB3QbOxZ5OB3OCiTx0DlVDrOqI34hx4ptT13WuHLEPy7yMCoK7Ys2fPg83Bvn37iK0auQHqGdTJkt7thXdBY0G16lSzQz0KR6F3a53YqqMwN0A9gDr5zIv7EpPLjHeHcD8zaHjYVl3rhFSXcr2rT6pqBbzbQKBOKvHu8DEn5d0VeBfUP2jVXJAboN5AnXzmxX+Fd0FTgVbNBbkB6g3UybK8i3Vm0ADo0ao9LQYaoynJfJg0GYv/S5qMvF9qjs7eTZqMzCkbWjwV7oy/Xy1yCd5tIKrVQgV1SapqaVTlSlK5d0dPw7ugQai6dz0tRfUkTUbWrpz2zN2kSujpXe5Zanxy8O7mA95V7F1vbAzeBY1Alb0rarWeFtpCzG/4lqoWOnq3mh0VvLv5gHfhXdBsVNe7SZNRMNljP6Hasw5T3UKhoKd3Jfqp4lo7dcJJk9FoMrUI1qKLW9GfFBesmUEKvLvJ0Nu7xCqXNBmNLS1G7a+csMC7YBNRde8KPcFMeDmXQHUQb829K9wgaTJy5Wo0JXmDFE+Lge7teMvy8O7mo4reNfChKyGpynFWpcRjaU2Ad8EmopbzXaolU4qpyuGL1N673G5OYFAppwp7RqPJA+9uOnSd70pVOUF1rYJ44V2wiaj59V19rvDW+vouZ3Ahtqycd0WjFnh3k6G7d0lVTlxdNU4NvAs2E/VwP7MO5q31/czscIOwhCy7zsy90NvigXc3H/pe35WocqKPNU6Mau9mcvAuaDzq4+93C9zLndWg5n+/y1vAk5xAiO6rKn6C+6o2Kbrfz0yqckmT0Wg0ihqxhqj37pvwLmg08DQcLsgNUG/URZ2s/l8TwbtgE1EXrbr6wLtc4N0Goi7qZJ179wi8CxqKumjV1Qfe5QLvNhCok/AuaDbQqrkgN0C9gTqp3LtxeBc0BGjVXJAboN5AnZR7/y68CxoRqlVbNgHKvVvrlOoBvNsooE4q864D3gUNw549e/ZtGpR4t9Zp1A94tyFAnXzmxX2JyRXGu8PwLmh49mwykBtc9KljoBJqXUf0RpwDz5b2rpXr3X/Xv5AAAACApkGZd+nruyvPwbsAAABABcC7AAAAgH48+9K+xOTKSU+c6N2NN9vgXQAAAEAznn1pX3Jy5ZS0d/uOWIdN8C4AAACgBc+99G/JySzfuxsc75r7j3SMHHeGqfuq4F0AAACgEp77R8a7zvBhK8+72zO5jUPm/iO2wHFX+LQ3Ebq9dOw3lp+8vH93y6svvPLaT3/+q5/+/Fc//flrL7zy2vOvvPp8y/7nW/bvbtm/++VfIhAIBAKB2N2y/3kmdrfs392y/ycv/7L1gjl0a+mUN2Fyhg9bRw609aVzlHcf3p7J3ztkGThqCx53Rc74Ev7QdOTOyvW5tRvzazcXCrdSG7fSG7dSG7dShZupws2FdU6ssXFjng7uh+JgN9MkbhIOt35zYf1Wav1WqkDF7VThdrpwO73xCRsZYtyTijtaxWIFIdobkzzeWdzObNxOC+OWjiE++u30xu1MJXGPiVJnR9VPupYKKur6DV6s8UJYr1ZvzK1eL0b++lz+Ou8TNfHxXF4uZqUiV1nQ+2HP4sb8KqeR0i2FbiCi5nAns8HUtw2J0LSS12sI2trtdOF2unA7VbidWr+1sH5L0BlKVaHZ/HXJUubFdZmYy2tVIQVxo6yYpytS6ViQifXK42Zdxo2F9Rvzax/PrYXvrPiC06e9SZMzctg6cqCtP5O7942HvmPYtuPPL/z2g9/1xFrtoRPu6Fl/8sKlj3/7P7c+uHrnYt+UZXDWNrJgD6TtgZRtJGUbWbCNLHQMzzMxx4Z1aJYN7ufi4G4pFe2DMxIx3T4wTf1sHZxhDkcf0TY8ZxuZs4/M2wMLjsCCI5hyBlPOUKozlO4czbjCGVc44w4vusOL7siiO7LoiSx6IkueyJInuuRVFMve6LIvVlH4VYV4P2yqPNElT2TJzYQrvOQKL3WGF+kYXXRqEEvKo5MYYZXhCrNntNQZJu580RladIYyjmDGEUzbg2l7IGULpGwjCx2cumodmrcOzRGjfXC2GAMzloFpS9+UuW/K3Dtp7r3bdu1u27W75t675t7Jtr4pc/+UuX/KQse0uX+a+oQQfdyYbKOiVybucuPitbsXr90hxodXPykZF699wm7fdu1OW+9dc99dc9+kpX+qfWDaOjjTMTRrG56zj8w7AgvOYKozlHaNpt2jGXeYbhfeyKI3uuSNLHkjS57Ioie86A5n2PCEFz2RRW9kyRtd9tGNYqX5gmrydESW3OFF92imM5TuDKacwQXHyLx9ZN4+MmenOp+huY6hWevgjHVgun1gun1gyjJAVxVz/6S5b9Lcd7eNit5S0UeXl2T0lxcWttIOEGNaRbBdMT9muSHV6DSKeY6MSsZCx4imMTxvHZ63DjPdCBWDs5aBGXP/dFvf1AdX77x75eZbPROnfUlTZ/RIR+Dd7tiFdz/Y+eR3Dd//0QvbHn0i+kmm1TF60hM71zX29uXrv/vD7Q+v3m3rn24fmrcH0o5QhhfBjCOY5kfKHtAyKMHLh31kgdrYEUxRyXAG085Q2hnKdIYynaOLrvCiO7zkjix5Isue6LInuuKNrfhiWV8s64tnffGsP57jRSLXpSq6E7nupMLIE6OnVHA2pnfFHt2foNPvi+d88Zw3lvPGst5Y1kNFlA63BpErRowfUWF4iBHTKIr7zLqjWXck646suCMrrsiKK7zcGV7upAYBoUVnaNERzDiCGXsgLRHUgJIeVjKSnmsfmGnvn7b0T1HdnKV/yjIw3T4ww3YlHUNzHUPzHUPz1qF56/CcMKh+YZCKWWvR6zIxw4ZlYMbST8U0MfhSJwd3+/aB6faBGevgjHVwtmNozjY8bx9ZcAQWnMF0ZyjjonQbXvJElr3RFV8s649nu+JZfyLrj2f9ccpAtIO9EXoM6out+OPZrkSuS1C9x/ghUeerEol8V7Ui549nfbGsN7rsiSy5Rxddo+nOUMoZXHAGF5yBFD3KD6bsgQVbYME+Mm+jZDw81zE0Z6V8PDhjpeQ0oCCY7UlReuoiEVS9FQU9KSpLY/Mdw/O2kXmJ/pnTrAIpOzUgpofFmkfGHqSspCxCi1pExh7M2INpdohvpfoNnnfvvnvl1luXPj7jHz/uih21hSK301u3P/G97//A8Nw/7PnW1h3vvNf2UWTmlDdxrmfi7Y9u/u4Pn3x4bdLcP2MdXrAHM9Skp5OKMPMDP6g+rvzIEKNU3lGyzziD1PZUGpZcVISXXOEld2TZE1nxRFe80SzlIV8s54/n/Yl8V2KVjuRqd3KtO7nKxFr32Fr32FpP+XGJG+PVD/7Ru8fWupNrXcm1ruSaP7nmT6xS4aMivuqLr3orjwQba5xYJYZPKpKywd9YcofxVV88z4Y3nvfG8t543hunxJx1R1fc0RVXZMUVWaYmys4wNR0XTeWp+hbKOIIZezBDjfk6huetQ7PtAzOW/ilzL+XdacvATPvQnHV4vmOYGvYxY8RAyhZYYP7lB90HzXewwV8l6hjmdX9WqoMemmsf5Dm7nAUhXliHZtk9dAzNdnAXhIIpJ70OtOiOLHmiy15qzhrPdiVy3Yl8F62xnD+e9cfoCR8j3SVfbJmSbvdYvmd8tYeqlhNrlybWObGmKDgVu2d8rWd8lQ5Bs5IP3h60DrqJ5bsSOV+cVq9rNNMZTDmDqU5qRS2U7qRG/KG0M5R2BtOOQNoRSDkCKftIyj6yYBtesA3PU9ExNE/2XzFkbTe8QIeC+YloupKSjECqXOc5AuzUS+A2NhYdMr296hU4gUeIC2yS623LnZHKIrzsDC87Ryn7pm2BVMfIgnV4jl4w659u65u62Dv5/tU77165deHS9TNd4yfciY/C02+/d/FbW3Y88+PnDb/41YG/feGfvvb1b77zvnlsOusYmnzn97fe++Odi71T5oFZ6/CCg7IategXWZaM8DI91SgnylrAZGLRyZYltbAZXuoML7vCVEpWXJEVd2TFHc16YllvLOeN5+gOOpH3J1e7kmtdY3R0j613j9PRM77eM17omSjGpTLjsvL4uLJg9sMeumei0DNe6BkvdI8XuscLXWPrVPipSK77k+s+jcKfVLRDv1SMycSaP7nmT675kmusg71EZ0t73Rtf9cTz1LTYHc25o1mqSlAhXwMdoUW6FVHe7Z829022XbvTdu2upW/KMjBjHZrrGF6wjVCrLHRfQw17yRFI2wNpG+1mavVbsJbDdMSUj1n7DtLLaPQEhd/tlrMQx7vuYxuet40s2OnJWdoZyrhGWemu+GJZH7XqQ08fV7uT+a5E3h9f8UaXqaVmD7sKHV32x7PdyVzP+OqlifXLE+tUnfxoovBRWW1honB5Yv0y62mOOxmVrlNxmRPCD5mj85vk+qWJ4pZ0TKyX267pJja+3j222pXM++NZX2zFE15yjaadgXlnYKEzlKYWDNzUAlt4yU1dGRktXv5wFOsDsRpIRYpXefhBa1Kq7kmE7ERQ5VzQGSJfjWK1J3dNihJheVHUKnMUWkCuogiKVmL+y/YDWVe00uiMrDjDS45RusewDs+3D85aBqbNfVNtfZMXeycZ796+cPlGx8Dd5FT2nffbvvb1b/7l9374z/teNbx24Owrr77+o79/5duPPPGdx3a9/b45W/git/Fl7t6X+Xv3Vz+9v/rZV2u8+FMV4iuNgrPPz+lY58X/0fG/vCg0S6xLxed1FiVS+Kf1z4slKBXrhMKcI+8bAAABrElEQVRli5i/sbIauPrZV6uffrX66f3VT+/n793P3/syf+/L3MYXuY0vqJ/pFvHp/dVPv1r9jBSfKoz74sjTB72fv3c//2kxiBsriRJ7ELQdQn4Wg9jcqF9pXYGFhy58rlnTqHQPbM2kcoCTmRId0VfFekWuIUrKUXmlUhDESqtFyPbJ5fTb5WhCcRokDqGgk5GMz/7EKVCq8Ra7i9zGl7mNL3MbX2Q3vlgpfPH2e+ZHHtv17UeeePpv/u7HL/7La//534Zfnza/duDcL/7j4I9+9ovndv/soe07H96+8+FHd23ZsWvrjie3PvbUtsef2vb4dx9BIKoc2x7/7rbHn9r2+FPbHmPjya2PPbmNF08J43E2NEoAddwdT27dsWvLjl1bHt255dGdW+nm8CR7RI1O+Sn+KYtOk3N2ZZ3gNu7OVe2EzY2tjz25dceTW3bs2vLori07qJ5h19Ydu9jc0DwTthbLXZwP/BoiOkHhPslRXmbWpG4gpMtCvnBLFL1GaRDVh0fp+sDGw4/ufHj7zoe27/yz7+z8i7/6wV//cPcLL+9/ad9//fqg6f8BgDFHGFGD7zYAAAAASUVORK5CYII=" border="0" alt="" />
4,439 次查看
Content originally posted in LPCWare by jgorsk on Sun Sep 16 23:54:07 MST 2012
Is there anyone who has succeeded debugging in the FLASH versions of the LP43 family?
I'm having big problems with that. Also USART0 and SSP1 are giving problems. ISRs are
triggered with all the status bits indicating the interrupt source being cleared.
My guess is that the bootloader is dodgy  but I'm not able to confirm that since
I'm not getting any support from NXP. This is a disaster.
Please let me know if you are using a flash version of the LP43 micro and it works.
I'm sure the romless versions work well enough. I wasted way too much time on this
and only a few features of this micro work properly. I'm going to scrap this project
soon and start over with another micro.
4,439 次查看
Content originally posted in LPCWare by jgorsk on Thu Sep 13 09:00:29 MST 2012
No, I haven't solved the issue. Could you please post a working example?
4,439 次查看
Content originally posted in LPCWare by bavarian on Thu Sep 13 06:08:59 MST 2012
did you already solve the issue with the LPC4337?
I can provide you with a working example if you like.
But on the other hand there should be enough examples in the Boards\KEIL\MCB4300 folder of µVision to show how it works.
Best regards.
4,439 次查看
Content originally posted in LPCWare by jgorsk on Wed Sep 12 23:40:50 MST 2012
It doesn't matter what the code is. I start a new
project in Keil and insert a blank SystemInit and main
functions and the CPU will never jump into either
of them. It's not even staying in the bootloader
code. It jumps into an area where there is no program code.
Can someone start a blank project in Keil for target LPC4357
and let me know if debugging works please? I'm actually
using the LPC4337 but only the LPC4357 is supported by Keil
at the moment. Can this be the reason why debugging isn't working?
4,439 次查看
Content originally posted in LPCWare by mc on Wed Sep 12 18:04:32 MST 2012
Hi Jgorsk,
Could you please post your code here.
4,439 次查看
Content originally posted in LPCWare by jgorsk on Wed Sep 12 03:33:50 MST 2012
Is anyone using the flash version of the LPC43?
