How to set the system clock frequency through registers in LPC845brk
968 次查看
tomato
I see that in MCUexpresso IDE there is this useful tool to change the system clock frequency
Can you tell which registers are changed when I set for instance 24MHz?
950 次查看
RaRo
Hello @tomato,
Could you please read the LPC845 User Manual Chapter 8: LPC84x System configuration (SYSCON) (8.6 Register description) and Chapter 9 LPC84x FRO API ROM routine ()?
There you may find more information about the FRO_OSC and System clock generation trough the registers.
Best regards, Raul.
