How to restore the pre-program demo for LPCXpresso546xx
1,518件の閲覧回数
cheoklai
Latest LPCXpresso54628 boards are pre-programmed with a demo application showcasing Embedded Wizard from TARA Systems. This demo is gone after a debug session in MCUXpresso IDE with an SDK example. The board only reboots with the screen of the SDK example.  Anyone know how to restore the pre-programmed demo in my LPCXpresso54628 board.
5 返答(返信)
1,377件の閲覧回数
ZhangJennie
Hi Cheok,
Please refer this document to import/export memory.
https://community.nxp.com/thread/389034
Jun Zhang
1,378件の閲覧回数
cheoklai
Hi Jennie,
The Import/Export memory feature is useful. However, I already lost the pre-programmed demo in the internal flash after my first debug test with an SDK example. I should have exported the demo binary from flash before I did my first SDK test run (I didn't, unfortunately). Do you know where can I find the binary of the pre-programmed demo and import it back to the board?
Thanks for addressing my question.
Cheok
1,378件の閲覧回数
ZhangJennie
By default, the export file path is the same path should be the latest imported project locating path.
User can also define the export path.
I have no idea where you put it. Please perform search on your disk to look for your exporting file.
Jun Zhang
1,378件の閲覧回数
cheoklai
Let me search for it. Thanks for the advice.
1,378件の閲覧回数
ZhangJennie
You are welcome.
