How to readback hex file from Lpc microcontroller
4,948件の閲覧回数
sameerarvikar
I am using LPC1788 microcontroller ,
I am using  keil software  and PE micro Multlink universal programmer for programming it,
Can i readback the programmed file ,
Or is there any other software or tool available to do it ?
ラベル(2)
タグ(1)
3 返答(返信)
4,804件の閲覧回数
ErichStyger
Specialist I
NXP offers the unlimited/free-of-charge Eclipse based MUXpresso IDE (MCUXpresso IDE|Eclipse-based Integrated Development Environment (IDE) | NXP ) which has such a memory export function, e.g. as binary or S-19 file:
That works with every supported debug interface (LPC-Link, P&E, SEGGER).
If you need the Intel Hex format, you can convert the S19 into that format.
I hope this helps,
Erich
PS: Dump my Device Memory | MCU on Eclipse
4,804件の閲覧回数
sameerarvikar
Can i use this file to program another LPC1788 ?
4,804件の閲覧回数
ErichStyger
Specialist I
