How to program lpc1517 by lpc1549 via CAN ISP?
1,822件の閲覧回数
yenchuntung
I boot lpc1517 into CAN ISP mode.Then I try to use lpc1549 to program the lpc1517 and reset it.
Does this way work? Or I must use Flash Magic?
I have read the lpc15xx user manual but still don't know how to use the C_CAN ISP commands at all.
Is that correct to use can_transmit(CAN_MSG1_OBJ* message_object) directly?
What data in the message_object should be?
タグ(3)
1,485件の閲覧回数
soledad
Hello YenChun,
In fact you need to use Flash Magic,  You are correct you can use can_transmit in order to send the command, in order to see how, and what data, please check the following link:
LPC11C24 Can Bootloader Assistance | www.LPCware.com
Have a nice day!
Sol
